Question about HP 17bII+ Calculator
How to name custimized equations
Could someone please help me on how to name the equations so that I dont have to scroll looking for the equation by just seeing the equations inputs, I want to save serveral equations and organize them by name so when I look for the equation I can find it by looking at the name.
Thx
Naming the equation via MY_NAME:ABC=0*L(A:blah blah and so on) will help somewhat, but if you want to search for the equation by your assigned name, you are out of luck, that functionality is not there. The best you can do is SAVE your equations in alphabetical order (by name) by creating the new equation at the right place in your sequence of equations. Then you can get to the beginning of the list by (gold or blue, depending upon which version of the 17bii+ you have) up-arrow, and down-arrow for the end of the list. It would be great if you could search for the name, but HP has not included that functionality.
Don
Posted on Dec 22, 2008
Use the colon
EQUATIONNAME: EQUATION
Posted on Nov 07, 2008
I dont know how to do this with the ()'s! :( Please help! CONFUSED 7Th GRADER HERE WITH HELPLESS TEACHER!! :'(
Sorry to be frank about it, but your sentence ..I dont want to have to read something that looks like it was typed in a forien language!! is not flawless English.
Be it as it may, here is how you solve most, if not all, high school algebraic equations.
The secret is in the use of the mnemonic known as PEDMAS, or BEMDAS, which lists the priority of operations. USE IT BACKWARDS, and recursively (look up this word in an English dictionary).
  1. Starting from the end of the mnemonic (A or S) look for a minus sign or a plus sign. Here you have 4-12, the result is -8.
  2. Your expression is equivalent to -8 -(X+3)=10
  3. To get rid of the -8 term on the left ADD +8 to BOTH sides of the equation and simplify. -8+8-(X+3)=10+8=18 or simpler still -(X+3)=18
  4. A minus sign in front of the parenthesis is in fact a multiplication by -1. Get rid of this factor : It is safer to get rid of the - sign in front of the parenthesis by multiplying BOTH sides of the equation by (-1). This gives you (X+3)=-18. MINUS signs are always signs of DANGER, to be handled with care.
  5. Now you can safely open the parentheses: X+3=-18
  6. You have an addition in the left member. To isolate X, perform the operation that is inverse of addition, namely subtraction. Subtract 3 from both sides of the equation: X+3-3=-18-3, or X=-21
  7. X is isolated, and your equation is solved.
Basically one tries to use PEDMAS in reverse, identifying each operation and doing the inverse of it. If you have an addition, do a subtraction. If you have a multiplication, do a division. If you have a power, extract the root, and if you have a root raise to the corresponding power.
When the factor to the left of parentheses is +1 (if nothing appears it is +1) you can safely discard the parentheses.
After opening parentheses start again A/S then D/M, then Exponent/roots, parentheses, etc...until the unknown sits by itself on one side of the equal sign.
I hope that my English does not sound too much like a foreign language to you. I did my best because English is my third language.
Sep 30, 2014 | Office Equipment & Supplies
How can I graph Y= 2X+3 on an HP 48GX? I have
Enter the equation as 2*X+3. Make sure that the name of the independent variable X in the equation and that on the INDEP:X line are both Capital letters or both lowercase letters.
Aug 28, 2013 | HP 48gx Calculator
Fx-82MS equations
There is no equation solving mode (utility) on this calculator. Sorry.
Apr 06, 2013 | Casio FX82MS Scientific Calculator
On the TI83 calculator the equation solver dont workequation solver dont work
Most probable that you are not using the correct syntax.
Press MATH, then scroll down to reach the SOLVER line. Press ENTER. Create the equation, using the ALPHA keyboard to type in letter symbols.
Press ENTER. The screen that opens displays the equation and a list of the variable present in your equation. Each letter (variable) must have a value, except the unknown. If there is a 0 after the = sign on the same line as the unknown, you must clear it so as to leave a blank.
Specify the lower bound and the upper bound to speed up the search.
Once finished press [ALPHA][ENTER] to execute the (SOLVER)
Oct 20, 2011 | Texas Instruments TI-83 Plus Calculator
My TI 84 plus silver: whenever I push the graph button the message ERR: Syntax 1:quit 2: goto appear on screen please help
Press the Y= button.
There are several possibilities:
1) Scroll through all equations, Y1 through Y9 and Y0. Make sure they are cleared.
2) The equation you typed in is not entered correctly.
3) Make sure Plot 1, Plot 2, and Plot 3 are NOT highlighted.
Feb 01, 2011 | Texas Instruments TI-84 Plus Calculator
I am trying to solve a quadratic function using the calculator but i dont seem to be able to do so. For example if i had a question like 5x^2 + 15x +3, how would i use the sharp el-w535 to find the x...
This expression 5x^2+15x+3 is not an equation, therefore it can have any value depending on the value of x. You have to make it an equation before looking for the particular value of x that satisfy your equation 5x^2+15x+3 =0
This calculator cannot solve equations because it does not have an equation solver.
Dec 15, 2010 | Sharp ELW535 Calculator
In complex number mode, how to get out?
"Is there anything that I can do about this to stop my answers being complex numbers when solving cubic equations?"
You are making an assumption that is unwarranted.Namely that a cubic equation must necessarily have 3 real roots. This is not the case.
Let your equation be
If coefficients are complex you should expect some complex roots. Right?
If the coefficients are REAL then depending on the discriminant
you can have three cases
DELTA positive : three distinct real roots
DELTA=0 , the equation has a multiple root and all roots are REAL
DELTA negative: the equation has ONE real root and 2 complex roots that are complex conjugate of each other.
It suffices to look at the Tartaglia/Cardano expressions of the roots to know that more often than not there is going to be complex roots.
May 05, 2010 | Casio CFX-9850G Plus Calculator
I have an equation: 6-2(5x-8) = 3x - 4. I need to
I will not ask what you want to do with the equation I will answer your question about the equal sign. Press [2nd][CATALOG] you access the catalog of available commands. The equal sign is near the bottom of the list. So it is faster to scroll up from the top, and keep scrolling up till you reach the =. Select it and press [ENTER], it will echoe at the place where the cursor was before you press [2nd][CATALOG]. Complete your equation.
Hope it helps.
Oct 21, 2009 | Texas Instruments TI-84 Plus Calculator
How do I solve a polynomial equation: x^4+5x^3-3x^2-43x-60 on a TI-83 plus graphing calculator?
Sorry, but what you wrote is not an equation but a polynomial expression. You want to solve the equation x^4+5x^3-3x^2-43x-60 =0.
The solve( command, can only be used with real numbers.
The solve( is available through the CATALOG : [2nd][CATALOG], scroll down till you reach the command. Highlight it and press [ENTER]. The command echodes on main screen as solve( .
You complete the command by entering the expression (not the equation), the name of the variable you solve for, the initial guess , and { lower limit, upper limit} between curly brackets, and the closing parenthesis.
Exemple:
solve (x^4+5x^3-3x^2-43x-60 , x,0 {-5,0} ) [ENTER]
should give you the negative root,
solve (x^4+5x^3-3x^2-43x-60 , x,0 {0,5} ) [ENTER]
should give you the positive root.
It is implied that the expression is 0, so you should not insert =0, otherwise you get an error. Here for the lower limit is -5 you must use the change sign symbol (-) under the 3 key, not the regular MINUS.
You may ask how I knew that there were two roots when the equation is a quartic? By first graphing it to have an idea about where the roots lie and how many there are. You should always do that to speed up the search.
There is another way to zoom in on the roots: by drawing the graph and using the tools accessible under the [2nd][CALC] menu, namely the option [2:Zero]
The resolution of the TI83/84 is not good enough for this function that grows too fast, but I am inserting a picture of the curve from another calculator with a much better resolution.
Hope it helps.
Oct 18, 2009 | Texas Instruments TI-83 Plus Calculator
Please suggest me how i use the v lookup and h look up
Select a blank cell in workbook. Click the function icon located informula bar("fx"). In the popup Insertwindow Select category as ALL.Select the function you want to get help and click on "help on this function " located in the left down page. You can get all the formula help bu using this method.
Feb 03, 2009 | Microsoft Excel for PC
HP 17bII+ Calculator Logo
349 people viewed this question
Seeker5211
Seeker5211
