Is there a seperate fuse for the rear amp?
SOURCE: replace rear brake pads
Remove right saddlebag, pull the two caliper mounting bolts and remove the caliper. Do not open bleeder or disconnect line. You will need to push a large screwdriver between the old pads before removing them in order to push the pucks back into the caliper or the new pads will not spread enough to reinstall. Then pull the two smaller bolts from the caliper and the pads will fall out. The pads are different for inside and outside, so pay attention, and remember, after reinstalling, before riding, be sure to pump brake pedal, and it may take a few stops before brakes stop as effectively as before.
SOURCE: fuse box
Looking at the bike from the front, it is located under the side cover, on the right hand side, you we need remove saddle bag. Once removed the fuse box is located under the plastic cover.
SOURCE: air in rear shocks
Depending on your weight and if you carry a passenger as to the air pressure. I normally run about 14 but 24 if riding 2 up.
Recommended pressures:
up to 150 lbs- 0
each addition 25 rider pounds > 150 lbs add 1.0 lbs
each additional passenger pounds > 150 lbs add 1.5 lbs
each additional 10 lbs of laggage add 3.0 lbs
Max Pressure 35 psi
SOURCE: I need the torque specifications for the rear
Your wheel is 95 to 110 ft lbs
Brake Disk is 30-45 ft lbs ( lock tight)
Pulley i( belt Sprocket) is 55-65 FT Lbs Lock tight red on both.
SOURCE: How do I change the front and rear brakes on a
Not too hard - Undo the two bolts on the caliper and then seperate the caliper and pull the old ones out. Insert the new ones and put the bolts back in to hold the caliper back together and then install them back on the bike with the two retaining bolts. Use a bit of lock tight (Blue) on the threads. Warning do not let anyone apply pressure on the brakes while you have them off the bike or you will have a mess and/or a problem.
