Question about LG HBM-550 Wireless Headset
Reset a LG hbm 570 seadset - LG HBM-550 Wireless Headset
4 Suggested Answers
award462
  • 395 Answers
SOURCE: LG HBM- Bluetooth- need to find how to link
Strat with headset 'OFF' then hold power button until light flashes blue and red or solid blue, then search for headset on phone, pass key should be 0000, 1111, 1234.
You can get the manual by searching for the FCCID, which should be in the headset https://fjallfoss.fcc.gov/oetcf/eas/reports/GenericSearch.cfm
Posted on May 05, 2010
  • 149 Answers
SOURCE: My blackberry curve recognizes the
Hi, to solve this problem, you will have to do some troubleshooting.
First you will need to disconnect the pairing of both the blue tooth headset from your black berry phone.And pair again with the below instruction.
Instructions
Pair Your Blackberry with a Bluetooth Headset
Turn on Bluetooth headset and Blackberry hand-held.
Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.
Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window.
Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list.
Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically.
Use your Bluetooth Headset with your Blackberry
Make sure the Bluetooth radio on your Blackberry is turned on before you try to use your Bluetooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the handheld.
Tips & Warnings
Pair your Blackberry with any Bluetooth-enabled device using the same steps as those for connecting a Bluetooth headset.
Remove your Bluetooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
After that if still does not work that means you will need to test if the bllue tooth headset is really not damaged by using it on another phone to confirm.
You can also reset the blackberry cell phone if still not working. Blue tooth might be corrupted and will not connect to headset. You can use the below instruction to reset cell phone:
How to Reset a Blackberry
There are three main types of Reset that apply to the Blackberry. These are listed in order below. Instructions for Blackberry Pearl are slightly different - see bottom section of the Tip.
1) Soft Reset - simply press the ALT+RIGHT SHIFT(CAP)+DELETE keys.
This reset stops all applications that are running on the Blackberry and will help if you are having problems connecting the device to computer. This reset will not erase any information from your device.
2) Double Soft Reset - this reset is almost equivalent to a full hard reset. First perform a Soft Reset as outlined in Step 1.
As soon as the screen is no longer black - repeat the steps once again exactly as before.
This takes you to another screen showing an hour glass. Allow the device to reset. This helps if the device has suffered a more serious error. Be aware you may loose some information from your device. A backup is advised prior to proceeding if at all possible.
3) Hard Reset - this is the full blown reset and will fully reset the device to help resolve critical errors with software or hardware. Again back up important information before proceeding if possible.
Note: For RIM models 850, 857, 950, or 957, you must insert the end of a paperclip or similar blunt object into a small recessed hole on the back of the unit and depress the switch inside. The device will reboot and be hard reset.
Other Models: With the device turned on - remove the battery for 30 seconds or more. Now replace the battery. The device will reboot and be hard reset.
Blackberry Pearl: To reset to factory defaults enter 'Options' from the main menu. Scroll to Security Options and press the trackball. Choose 'General Settings'.
Press the left soft key, then scroll to "Wipe Handheld" with the trackball and press the trackball. To initiate the factory reset, your phones security code may be required in order for the process to complete. Your phone will now be restored to its original settings on leaving the factory.
A hard reset can be achieved with the Pearl in the same way as outlined at Step 3 by removing the battery.
Be aware that resets such as these may erase data, such as contacts, ring tones, pictures, text messages and stored Internet files and emails. Make sure to back up important information beforehand if at all possible. You can obtain software to back up the device to your computer directly from Blackberry Below.
software112.com/products/blackberry-desktop-software.html
When you are through with that and still nothing happens, then you blue tooth headset needs replacement..
Hope this Tip helps. If so please do leave a vote for the solution.
Thanks.
Posted on Feb 18, 2011
  • 149 Answers
SOURCE: how to make auto answer
Hi, LG HBM 730 Bluetooth Headset Wireless Headset does have the ability to auto answer a call. But it does that automatically (does not need settings for it).
Also you can set auto answer from your cell phone.I don't know the model of the cell phone you are using at the moment. So you will need to use the manual of the cell phone to know how to auto answer calls.
When you set the cellphones auto answer, then it will auto answer on your LG HBM 730 Bluetooth Headset Wireless Headset..
Have a nice day
Posted on Mar 02, 2011
Need user guide for lg hbm 570
click here
if it helps please leave a 4 thumb rating.
May 28, 2011 | Cell Phones
How to make auto answer incoming phone (hand free) with LG HBM 570 bluetooth headset in case driving car
Have a nice day
Mar 02, 2011 | LG HBM 730 Bluetooth Headset Wireless...
The plastic ear piece broke on my LG HBM-570 Bluetooth® Headset, is there anywhere to get replacements?
I had the same problem and I contacted LG first by email, this was the response: Please contact our Customer Care line at
1-800-793-8896 Ext 2, and they will be able to assist you with a
replacement. I called the number and they agreed to send me a replacement piece free. I got it in 5 days. May I also suggest that you ask for a manual to be sent also because I cant seem to find one and I would love to activate Name Alert for caller ID during drive time.
Good luck with that.
Aug 12, 2010 | LG HBM-760 Bluetooth Headset
Apr 30, 2010 | LG HBM-760 Bluetooth Headset
How to reset passcode for LG HBM-550
The passkey is 0000 (Four Zeros)
Here's the manual:
http://www.megaaccy.com/HBM_550.pdf
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!
Feb 02, 2010 | LG HBM-550 Wireless Headset
LG HBM 710
Sounds like someone "hacked" your headset and changed the code and display name. if you don't know the new code then my only suggestion would be head to your local distributor (probably a Verizon store) and ask them to reset your headset for you.
Apr 23, 2008 | LG HBM-710 Wireless Headset
Bluetooth HBM-730
just set the bluetooth earpiece to pairing mode and start searching bluetooth devices from your phone.
If you don't have a manual, just post back.
Feb 06, 2008 | LG HBM 730 Bluetooth Headset Wireless...
LG HBM-550 Wireless Headset Logo
64 people viewed this question
Top LG Radio Communications Experts
iPhone Technicians
iPhone Technicians
Level 1 Expert
Mohamed Ismail
Mohamed Ismail
Are you a LG Radio Communication Expert? Answer questions, earn points and help others
