Question about Solis Master 5000 Espresso Machine
Accidentally put water in the coffee grinder. After cleaning out and drying, the grinder spins but no beans to in
The machine was taken apart, cleaned, dried, and everything seemed to be working. Upon pushing the button to make a cup the grinder spins the beans but they don't actually go down Into the machine anymore.
Richie_asg1
  • 1036 Answers
SOURCE: Solis Palazzo - Coffee grinder seems blocked
Hi there!
This is most likely due to a build up of ground coffee at the edges, and the whole lot has become a solid lump.
Disconnect the machine and clean with a small stiff paintbrush.
This is caused by damp beans, or using dark roast beans, or keeping beans refrigerated. Often it is the coffee oil that causes it.
If there are beans in there and the unit is not rotating, please contact here again.
Thanks......Oh, and rate as Fixya! if it helps you.
Posted on Jun 19, 2008
encyphered
  • 11 Answers
SOURCE: solis 5000 coffee maker
You may have sprung a leak in your machine that shorted out the electronics , that burning smell is not good :(
Find an electronic type to open up the machine a take a look inside. The top cover comes off without to much pain.
Good Luck,
Lane
Posted on Jan 04, 2009
  • 1089 Answers
SOURCE: After using oily coffee beans the machine drops
Hi
The ventilate is just opening the steam valve for just water. Don't push the button for steam. Your grinder needs to be a little coarser. Turn the big know in the bean hopper to a larger #, about 2 to 4
# higher.
You need to clean the brew head in the brew unit.
Holding the handle, the top left side is the brew head. There is an outlet pipe that exits the front, towards the door (looks like an "L" pipe). 2screws hold it to the top. Remove the 2 screws while holding the manifold ("L" pipe assembly). Once they are removed, lift the l assembly off (be careful, there is an O-ring, spring with a black seal (don’t loose it or your out of luck).
Now remove the brew screen, by holding the screen with your finger and twisting the thumbscrew (remember thumbscrew, DON’T use the key to install the screen, use your fingers...
Once the screen is out, look at where the screen was. There are 2 holes. 1 big one in the center and a small one to the side.
With the brew unit upside down over the towel insert a paperclip into the small hole and force anything out the other side. I have gotten worms almost a 1" long from this passage. The paper clip has to go from this side to prevent damage to the seat on the other side.
Clean then reassemble. Brew unit on towel right side up. Then the spring with black seal down.
Now the O-ring over the spring, then place the manifold on top of that with the pipe towards the handle side. Insert your screws (I turn them backwards a little with a little downward pressure until they feel like they drop into the threads. They should turn down easily, if not back them up a little more ( we are trying to find the old threads) and tighten. Install screen, and tighten with your fingers. The screen just needs to be flush with the bottom of the brew head.
Install in machine and test
Posted on Jul 06, 2010
  • 1089 Answers
SOURCE: I accidently poured about half a cup of water
Taking the grinder apart is not easy to do and get it back the way it is suppose to be is not easy. The first thing I would do is turn the big knob to the 18 or max and the small knob to the -, and try again. If that works leave it there for a couple shots to clean everything out. If that works continue. Then while the grinder is grinding, turn the big knob back down to 8-10 and make some more drinks. 6 to 8 is a good start.
If it didn't work you will need directions but the damage may be already done. The burrs ghave no coating on them and they can rust very quickly. you may need new burrs or a new grinder.
I have a saying " If you are working on the water, keep the bean hopper covered and vice versa". Cross contamination will damage the machine very quickly.
Posted on Nov 08, 2010
SOURCE: Coffee bean light won't go out when full and coffee won't work
Hi coffee friend I have just answered this question. I think
After you have done all the cleaning you have done, you can try this: do check that all knobs correctly set. That the steam spout is closed. that the water tank sitter correctly
Disconnect from power, wait 2-3minutes connect again and hope for the best.
Kolbrun
Posted on Apr 16, 2012
I accidentally put water in the grinder will it dry out
no,will not dry .You have to take off the beans canister and get out the grinder knife to clean it.
Jul 11, 2014 | Saeco Magic Comfort Plus Espresso Machine
Put water in coffee grinder
No, let it completely dry out. Better yet, use forced air to dry it out such as a hair dryer or compressed air.
Sep 03, 2012 | Saeco Magic Comfort Plus Espresso Machine
Poured water in my delonghi magnifica beans hopper.
Have you tried grinding a few cups of uncooked rice through the mechanism to see if this will shift the dried on coffee grounds. It worked for a friend of mine after several attempts
Dec 31, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
The grinder spins but no beans get grided. sometimes if i push them down it will work for a while.
Remove all beans from grinder and with the remain beans adjust the grinder to more gross grinding and the make 3 to 4 coffees.
Then Use a vacum cleaner and absorve as much from the grinder. Wash also the Beans hopper with soap and hot water so all oil remianing go away. Dry it very well and put back in place.
Now add new add some new beans and try to make an espresso and when the grinder spins then rotate back to the original grinding position. Remeber that you must go back to fine one step at a time not at once since this will blocked the grinder blades with grounded coffe and grinder will not rotate.
You should to this often is you use oily dark roated beans beans. I sugest to find also a better quality beans which are more light color thus less oily.
Aug 25, 2010 | Saeco Vienna Espresso Machine
Our bean grinder has stopped grinding. It spins but the beans do not grind. The machine works fine on the ground coffee option.
Did you put water in the grinder by mistake? If the grinder is wet it won't grind anymore,have to cleaned the blades physically .
OR are you using the beans from the fridge? It's a NO NO.
Jul 30, 2010 | Saeco Magic De Luxe 30092 Espresso Machine
Grinder is not functioning, apparently, resultant brew is between tan and clear.
HOw oily are the beans you are using ? cause oily beans will clogg up the grinder causing none or little to come out. Try running some really dry beans threw decaf beans are generally drier than most. If the amount of coffeee being ground doesnt increase then the grinder will have to be taken apart and cleaned out.
Dec 17, 2009 | Saeco Talea Giro Espresso Machine
Poured water into coffee grinder
easiest thing to do is put it outside to dry or use a blow drier to dry it up, it should be ok
Jul 01, 2009 | Saeco Magic De Luxe Espresso Machine
Fill beans message keeps coming up on jura capresso impressa s9
You need to open the grinder, it`s probably packed with old fine powdered coffee that blocks the outlet. Clean this out and try again. Since it works normal when you use pre-ground coffee, there shouldn`t be any problems with any other parts.
Let me know if you want a description for have to open and clean the grinder.
Jun 01, 2009 | Jura Capresso Impressa S9 Coffee...
Saeco magic comfort coffee machine grinder
Make sure you not get any water in the grinder, if you got water in the grinder then you have to clean it.
You can try to set grinding to coarse and try to make 3 cup of coffee.
Jul 22, 2008 | Saeco Magic De Luxe Espresso Machine
The Coffee bean holder
You may have accidentally dropped water into the grinders. Email me your email address and I'll send you grinder cleaning instructions.
If the grinder cleaning does not work.. You may have to have to machine serviced.
Please include the model of machine and that you would like the grinder cleaning instructions.
Email: support@cerinicoffee.com
Oct 06, 2007 | Saeco Magic De Luxe Espresso Machine
Solis Master 5000 Espresso Machine Logo
26 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
graybeard32301
Colin Stickland
Colin Stickland
AZBen
AZBen
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
