Hitachi ultravision 60ux58B power went out while watching a program. Now set completely dead, no power light no nothing.
  • 125 Answers
SOURCE: dead tv
Sounds like a power supply problem. I am sure that the pop is the fuse blown. If the fuse is blown, this means that there is a short somewhere. Rear projection TV are like LCD projectors. And all of them use Switch mode power supply. If you are lucky, there is a chance that a protection device (like a varistor) is sorted. This means that removing this, even without replacing will bring your TV to life, however... Most probably the power supply is defective.
Posted on May 22, 2007
techman
  • 3130 Answers
SOURCE: Hitachi 60ux58b projection tv
If there is no power indicator, you could have gotten lucky and only the main fuse insiude the set blew. You can unplug the TV set, take off the back of the TV. Then where the line cord comes out of the TV set and plugs into the wall, look where the line cord enters the set and look for a glass type cylinder fuse. If it is black, most likely there is a short inside the TV set. If it is not black, try replacing the fuse with ONLY the type that is stamped on the side of the fuse. If the set still does not work, or if the fuse blows again, you will need to have the set serviced by a pro. Good Luck
Posted on Aug 19, 2007
SOURCE: hitachi ultravision digital widescreen
you need a tune up. yeah thats right some guy comes to your house and adjust your tube, like new again. 200 300 buck
Posted on May 21, 2008
  • 927 Answers
SOURCE: Hitachi Ultravision Digital 55" hdtv
Good Day;
Try this:
Symptom: All Front LED indicators are flashing in sequence: Power-->Temp-->Lamp-->Power......continuously
Cause: Replace Lamp . This symptom may happen all the time or it may be intermittent. It is normal if it occurrs from time to time, See OG under TV Front Indicators explanation notes.
Good Luck, big IRISH.
Posted on Sep 09, 2008
SOURCE: Rear projection HD Hitachi Ultravision always has greenish tint
This is what you're going to do, Turn on the Tv and go to the service manual, if the green tint is still there, you have a defective dmd board, but if it's no there, then you have an issue with your video board
Posted on Jul 09, 2009
How do I fix My 50 inch Hitachi Ultravision TV?
Likely the lamp in the set has failed here which does make sense if the picture was dim before---a lot of lamps just before failing all the way dim down.
Apr 25, 2012 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi ultravision projection that is turning off
Ur tv projection bulb,been a long time had not been replaced?If the the bulb been,replaced the ballast might be dead.
Apr 14, 2010 | Hitachi UltraVision 55HDS52 Television
I HAVE A HITACHI 60UX58B REAR PROJECTION TV. WE WERE WATCHING TV AND THE TV MADE A POP NOISE AND THE PICTURE WENT OUT. NOW THE RED POWER LIGHT WILL NOT COME ON.
Power board is dead,know how to solders?Replaced those capacitors that puff up or burst open.Or buy a whole refurbish power board at Shopjimmy.com,Ebay.com.
Jan 26, 2010 | Hitachi 60UX58B 60" Rear Projection...
I have a hitachi 60UX58B. It went pow.
If it is totally dead, then this is likely a power supply issue. If the front panel LED comes on, but nothing else, perhaps there is a problem on the deflection board, or perhaps the convergence chips died and shut down the set.
Oct 10, 2009 | Hitachi Televison & Video
Describe your Hitachi 60ux58b Problem - Now power to unit. Picture went out, and heard pos. Figure projection bulbs, but no power?
Youre in luck. This is a very common problem and an easy fix. Goto TvRepairKits.com to get the parts and repair instructions.
Jul 12, 2009 | Hitachi 60UX58B 60" Rear Projection...
TV power light comes on when first powered up then all green lights on the board turn off (about 10 seconds) and nothing stays on except one red LED
The problem is a blown capacitor and a pico fuse. You can get complete parts and instructiosn for this fix from TvRepairKits.com. They put together a kit for this. I used them for a convergence problem recently and they helped me fix my set.
Jul 09, 2009 | Hitachi 60UX58B 60" Rear Projection...
Dead set
sub power comes from microp to front panel touch boards if absolutely nothing hapen you may not have this voltage.also there is a fuse were the power cord connects to power bd.clay
Mar 03, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi 60UX58B will not turn on
I think there could have been a power surge... ask the repairman if the power supply is blown. :)
Jun 18, 2008 | Hitachi 60UX58B 60" Rear Projection...
60ux58b hitachi
If you have Hitachi model number 50UX58B, 60UX58B, 50UX58K, 60UX58K, 50SBX78B or 60SBX78B and you have the following symptoms you may want to grab a repair kit from www.TvRepairKits.com. They have put together a kit that includes the parts and instructions to fix these models. This is a fairly common problem with the above model numbers. It is typically caused by a blown capacitor and pico fuse. Again, you can get a kit from the above address.
Here are the symptoms...
Primary Symptom: No Audio or Video. Power light will come on briefly then shut off.
Other Possible Symptoms : The green LEDs on the circuit board light up for a few seconds then turn off.
Hope this helps,
Apr 29, 2008 | Hitachi 60UX58B 60" Rear Projection...
No Power
Your set is going into high voltage shut down. Might have been the high voltage transformer that has gone bad.
Mar 09, 2007 | Hitachi 60UX58B 60" Rear Projection...
Televison & Video Logo
96 people viewed this question
Top Televison & Video Experts
