Question about Bosch Washing Machines
Bosch wff2001 drum not turning
Drum doesn't turn
SOURCE: Bosch Maxx WFL 2850 - the drum will not turn around
Check the electronic board for a short.
Posted on May 31, 2008
  • 14 Answers
SOURCE: bosch wff2000. goes through program
it sounds very much like the carbon brushes in the drive moter. the best way is to remove the motor and then you can also check the commutator for wear as well. model no and serial no needed to get spares, sometimes moter type.
Posted on Oct 06, 2008
  • 31 Answers
SOURCE: BOSCH MAXX AUTO WASHER. FILLING AND EMPTYING
sounds like your brushes have worn down hey are not that much only 20 min job
Posted on Jun 22, 2009
  • 57 Answers
SOURCE: The drum doesn;t turn during wash or spin cycle
Kindly remove the back panel of the unit and check whether the belt is properly fixed if it is ok means check the wire connection if everything is fine. kindly check the motor humming sound once the water is filled if you find the humming sound means kindly replace the motor
Posted on May 18, 2010
barkencoa
  • 3463 Answers
SOURCE: Have a WFL2480AU Bosch Front
Most likely to be the brushes in the motor that need to be replaced, check them for wear, and if less than 4 or 5 mm long, replace them.
Posted on Nov 08, 2010
Testimonial: "Great quick response."
Bosch maxx drum not turning during any cycle
What is the model number of your unit?
Nov 18, 2012 | Bosch Washing Machines
Dryer drum doesn't spin
If the motor runs and the drum doesn't turn then most likely the belt is broken.
Oct 23, 2012 | GE DBVH512EFWW Dryer
Siemens xlm1600 drum doesn't turn - motor running - full load of wet washing. Inlet/outlet checked and cleaned - ok. Won't even turn when empty. Whats up?
something jammed between outer drum and inner drum or bearings jammed, if any off these then belt will be burnt Re: Jeff
Apr 12, 2012 | Siemens Washing Machines
Ld lg3788w gas dryer drum won't turn
not a good model number,most likely you have a broken belt as long as it starts,heats but the drum doesn't spin,if you get a buzzing sound and it doesn't start you could have something stuck in the blower wheel,the motor is jammed or the motor is bad,you can open the door,push the door switch in,spin the drum with your other hand and have someone push the start button,if it starts you have a bad motor.
Nov 27, 2011 | Dryers
We've been given a spare Bosch Maxx 900 washing machine by friends which hasn't been used for a few years. Have plugged it in, connected the hoses, and switched it on for a standard cycle 40...
Hello is this a front loader machine and if so in the back of the machine there are 4 bolts that go thru a 3' piece of plastic. they should be around the drum area they use these to keep drum stable while being transported so look for them. Hope this helps you out
Jul 21, 2011 | Bosch Washing Machines
Turns on, fills with water, but then won't spin and makes a high pitch squeel. Belt maybe?
While the belt IS a possibility, you should check to make sure that the drum is not out of balance or that it is wedged somehow.
When the drum is empty, try to manually turn the drum. You should only being turning the resistance of the motor and belt; and the internal working of the tub, so it should turn under some pressure. BUT don't put excessive force into trying to turn it! If it doesn't turn with moderate pressure then something has come loose and wedged the mechanism. Which means that the drum system would need disassembled and repaired.
Jun 25, 2011 | GE WCVH6260FWW
Drum will not spin on any cycle.bosch nexxt 300.
http://www.searspartsdirect.com/partsdirect/part-model/Bosch-Parts/Washer-Parts/Model-WFMC2201UC13/1794/0153200/50033052/00003?blt=06&prst=&shdMod= If the drum is not turning on any cycle then I would suspect either the belt - Item 308; or the motor - Item 327.
If you are saying that it doesn't go into the spin cycle (but the drum turns in other settings) then I would suspect the control board - Item 333
Jun 24, 2011 | Bosch Nexxt 300 Series WFMC2201UC
I have a brand new front loader and the drum is not turning during the cycle....it turns freely if I do it by hand
If you hear the motor running and the console doesn't put out an error code during the cycle, it sounds like your drive belt may have come off the motor / drum pulley. You should be able to access it by removing the back panel. Be careful- and unplug the machine first.
Good luck.
May 14, 2011 | Bosch Washing Machines
Bosch WFF2001. Works OK in wash cycle but leaks heavily (from drum seal?) on rinse. Not from door seal. Any ideas?
This video will show you how to change a door seal on this Bosch WFF2001 front loader washing machine
May 02, 2011 | Washing Machines
Bosch AXXIS dryer # WTA 3510 uc slipping / grinding sound when drum reverses direction. Difficult to turn drum by hand. Belt or motor?
drum baring or rollers if you can get belt off try to turn drum if it still hard to turn you will know its not the motor may be something in blower give it a try
Sep 30, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Washing Machines Logo
24 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
