Question about Olympus Stylus 600 Digital Camera
The shutter wont close when turned off the lens go in a biot then thats all
When i try to turn off my camera the shutter does not close and it just makes the lens go in a bit.......
  • 62 Answers
SOURCE: Blue screen and lens error
i think its in the flix of your lense,
coz the flixible wire of your lense and motor are one
try to test it!!
there is something wrong in the FW i think!!
Posted on Nov 12, 2008
  • 20 Answers
SOURCE: lens
see this site -- may help - but follow carefully
Posted on Dec 02, 2008
  • 3600 Answers
SOURCE: on the lens makes a clicking noise shutter goes in and out turns.
Did you drop it? if you did you have damaged the gear drive motor for it. Are the batteris good?
Posted on Jul 06, 2009
SOURCE: When power is on the the lens goes in and out then
non riesco ad utilizzare eMule-gratis
Posted on Sep 03, 2009
  • 11967 Answers
SOURCE: The lens is open and is stuck (stuck on highest
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jun 25, 2010
  • 178 Answers
SOURCE: camera stuck with lens out & wont turn on =/
This happens with many cameras, whatever you do, do not force the lens back. You will see this as a suggestion on some blogs. Doing it might further damage the camera lens and other parts.
Here is a repair place that is very reliable:
WHen sending it in make sure you cushion it so it doesn't get worse when shipping.
Posted on Jul 08, 2010
0 characters
1 Points
My camera says..lens error will shut down automatically restart camera..! so my lens wont close even when i turn my s100 on or off. please help???
Make sure there is no dust or foreign material that could be jamming the lens and lens shutter. Have you tried removing battery or battery pack or try to reset camera? Just a suggestion.
Oct 02, 2013 | Canon PowerShot S100 Digital Camera
When trying to turn the camera on, the lens will not extend fully. it extends partially, and then the camera turns itself off, leaving the lens in the partially extended position. you have to try and turn...
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 23, 2011 | FUJIFILM FinePix JX250 Digital Camera
Cannon powershot610
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Dec 28, 2009 | Canon PowerShot A610 Digital Camera
Lines on screen and photos, too bright photos outside
Lines across your pictures or pictures too bright are due to the shutter not closing correctly or at all.
to check this- turn camera on, turn off flash, turn camera around and look into the lens. Adjust the zoom so that the shutter and internal lens comes up to the end of the lens and whatch as you take a picture. You should see the shutter close completely over the lens. If it doesn't move or does not close over completely then there is your problem.
If camera was dropped it could have jammed the shutter open or obstructed it in some way from closing completely.
camera will require repair/ service.
You may have some luck if you power up and down your camera numerous times before taking a picture. The action of the lens opening and closing may free the shutter.
Aug 07, 2009 | Fuji FinePix V10 Digital Camera
My Samsung won't turn on :(
Try to move the lens a bit or straighten it out, that usually works when it makes the three beep sounds.
Jul 22, 2009 | Samsung L100 Digital Camera
I take out door photos during day time,Iam getting white screen.
First make sure the mode selector dial is set to the red camera without an M next to it (ie you're in Auto mode and NOT in manual mode). If so...
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
Now the A410 is not capable of taking 15 second exposures as recommended for the fix. Instead try setting the camera to manual mode, turn off the flash, got to a darkened room, and take a picture. Open the battery door while the red and yellow light are flashing. If after many tries this does not work, then consider trying Fix #5a on the site. But do so with the camera turned off and the lens retracted to lessen the chance of damaging the lens mechanism.
Jul 05, 2009 | Canon PowerShot A410 Digital Camera
HELP! dropped camera, lens won't go back in, shutter won't close
I have a camsung L830 that had similar problems and and after I would turn it on, it would beep three times and turn off....but I somehow fixed the lens by turning the camera on and then either pushing/pulling on the part the stickes out and hopefully it might activate the mechanism and it'll go in...that's what happened with mine...the shutters still won't close though. But I'm happy I can use my camera now.
Sep 24, 2007 | HP Photosmart R927 Digital Camera
Shutter will not close!
very small dust particals are the reason of this problem.I m suggesting an idea but apply it on your own risk.Keep camera in off position then slightly strick with ur fingernale around the lens ring evenly.This can make the lens shutter contrct.Once the shutter closed,clean gently with a painting brush over the edges where shutter slides this for several times so that any hard dust partical causing may not insert anything inside.
Aug 12, 2007 | Sony Cyber-Shot DSC-P73 Digital Camera
Olympus Stylus 600 Digital Camera Logo
15 people viewed this question
Top Olympus Digital Cameras Experts
Steven Wander
Steven Wander
Are you an Olympus Digital Camera Expert? Answer questions, earn points and help others
