Question about Canon LBP 2410 Laser Printer
Where can I get Vista 64 drivers for ABS NW-201-PCI wireless adapter
I cannot find any vista drivers for the card above, let alone for vista 64. Has anyone seen drivers for it at all
  • Anonymous Mar 04, 2009
    No driver
5 Suggested Answers
SOURCE: Printer Driver for Canon LBP 800 compatable with Windows Vista
djhdjdjdjdh
Posted on Aug 28, 2008
firesnake09
  • 2923 Answers
SOURCE: Windows Vista 64 bit Drivers
There is an available driver for your printer but it's only for Windows Vista 32-bit OS only. I believe that you need to verify to the printer manufacturer if this printer is supporting Windows Vista 64-bit and where to find the driver online. But you may click this link and then go to "Windows Vista" and you might get a 64-bit driver:
http://driverscollection.com/?H=LBP-3200&By=Canon
I hope this would help you.
Posted on Apr 20, 2009
guru_dev
  • 315 Answers
SOURCE: drivers for vista 64
here is the driver. Goto : http://software.canon-europe.com/software/0026004.asp?model=
click on : L7300ENx.exe
Posted on Jun 01, 2009
old marine
  • 1774 Answers
SOURCE: Failed Wireless Setup/could not create new port
Check this link for wireless setup:
http://downloads.canon.com/MP620/Intro_to_MP620_Setup_Guide.htm
There are Vista 64 drivers on the CD that came with the printer, but if you want to download, you should download the network drivers if you are installing the printer to work on a wireless local area network (LAN).
Posted on Jun 23, 2009
SOURCE: No 64 bit drivers for MF3110
Get MF5700 drivers for vista 64 bit, your MF3110 will work fine with it for printing, although i am still having problem with the scanner.
Posted on Jul 01, 2009
Is it possible to use this card with Win 7 64 bit? cant find a driver anywhere!
Amigo AWI-926W (AWI926W) Wireless Adapter 64 bit driver
http://www.driversforfree.com/dt_dm_os/wireless-network-adapter/amigo-technology/windows-vista-64-bit/devices.aspx
if the one for vista does not work
Rather doing a driver hunt which can take hours
http://download.cnet.com/SlimDrivers-Free/3000-18513_4-75279940.html
Windows XP/Vista/7/8
it might take some time being a freeware driver solution
Note: it will find all of your outdated drivers
This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
Aug 05, 2013 | Amigo AWI-926W (AWI926W) Wireless Adapter
I cannot find the driver for my Zonet Wireless card. ZEW1642 Please help..
Hello you have to buy a new Wireless Adapter because the company no longer exist.
Just make sure the new card supports your windows system.
Hope this will help you
Nov 18, 2012 | Zonet ZEW1642S IEEE 802.11b/g/n PCI...
Need Windows 7 driver
http://www.startech.com/Networking-IO/Adapter-Cards/PCI-Express-10-100-Dual-Profile-Ethernet-Card~PEX100S
download the drivers, use the one that is for windows vista, instead of running the driver installer that comes with the it go to the folder that called WINVISTA then go to a folder called 32 if using 32-bits or 64 if using 64 bits OS, inside that folder you will find 3 files extract then to a place you can remember. then go to control panel, device manager, look for the device that has a yellow icon click on it, click on update drivers, click on browser my computer for driver software, click browse, search for the place where you have extracted the drivers from before select the folder containing the drivers, click next and wait until windows installs the drivers.
usually a 85% of the windows vista drivers will work in windows 7.
Sep 13, 2011 | StarTech.com (PEX100S) Network Adapter
Driver needed
www.bioticaindia.com/bcm94306mp.html This is driver location for vista
May 12, 2009 | Broadcom BCM94306MP - IEEE 802.11b/g...
Would like to install the adapter on a vista 64 bit pc
I'm sorry to say this but Linksys don;t have any driver made for a 64 bit computer for this adapter and that is the reason why it wont work with a 64 bit computer.......
Jan 15, 2009 | Linksys Wireless-G WUSB54G 802.11g/b
Is there any Windows Vista Driver for the ZIO 802.11g 54Mbps Wireless LAN PCI Card???? I can not find any driver specifically for Vista!
for a good quality solution you might need to ask a premium question its worth it you get answers in seconds and for a bit more you can talk live to the person.
Dec 30, 2008 | Computers & Internet
My wireless network adapter's device driver doesn't work
Download the latest drivers for XP or Vista
Note: If you can't find Vista drivers for Vista use XP drivers.
Uninstall the driver from XP or Vista.
If you have PCMICA adapter card in laptop remove it.
Reboot the PC
Note: If the network adapter is built-in laptop or PCI (desktop) leave it along.
Re-install the drivers and wait for the driver to tell you when to install the device if you have this option and don't have PCMICA card adapter for wireless.
If the card still doesn't work it could be faulty or OS is corrupted and needs to be re-installed. (this would be the last step to fix the problem)
Aug 01, 2008 | Computers & Internet
Airplus G DWL-G510 Vista Driver
revision B of this model has a driver for vista 32. go to http://support.dlink.com/products/revision.asp if you don't know where to check the revision of your device. if it's revision B, just click on the link for revision B and it'll give you the option to download the vista driver. make sure also that your vista computer is running 32-bit. if not, there's no available driver for vista 64
May 23, 2008 | D-Link AirPlus G DWL-G510 802.11g/b...
Driver problem
please give me driver.....?
May 19, 2008 | Creative Labs Ensonic PCI Sound Card
Canon LBP 2410 Laser Printer Logo
87 people viewed this question
old marine
old marine
Corne Viljoen
