Question about Canon Office Equipment & Supplies
Canon 6055 error# E000001-0010
Please help me solve this issue it doesnt want to print
4 Suggested Answers
bassplayer97
  • 154 Answers
SOURCE: canon i255 printer error 5100
5100 is a carriage error. check the timing strip for contamination (plastic strip about 1/4" in width). Check for obstructions.
more information on this error can be found at http://www.fixyourownprinter.com/forums/laser/25975
Posted on Jul 12, 2009
xptareq2000
  • 1447 Answers
SOURCE: Getting Error code E000001-0010 on an Img runner
Press "Additional Functions", press "#", then press the "Right Arrow" button till it says, "Printer", then press "Set" then press the "Right Arrow" button again until it says "Printer Reset" then press "Set" again, the display will ask you "Yes" or "No". Press the "Left" arrow for "Yes", then press "Set". Now, unplug the power cord and wait 5 seconds and plug back in
Posted on Mar 12, 2010
  • 693 Answers
SOURCE: My canon C3170i shows error E000001-0010
Product : imageRUNNER 5070 / 5570 / 6570 Title : Fuser noise and intermittent E001 code Error
The upper fuser roller section makes a noise and intermittently error code E001 occurs Workaround : In this case, the UFR Shutter inside the upper fuser roller was installed reversed (180 degrees out of postion). Installing the UFR Shutter in the proper orientation corrected the problem. Note: the UFR shutter installed in the reversed position will cause a noise and block the Main Thermistor when the shutter should block the Sub Thermistor. In turn, the shutter will block the Sub Thermistor when the shutter should block the Main thermistor. This will cause improper temperature for the Upper Fuser roller and cause the error code. suggested to go in service mode and reset the error, and see if it will solve the problem. If the problem presist, a code will appear and that will be the one we should work on. So we did clear the error, and the machine is functioning.
Entering service mode: press Additional Function > press 2 & 8 at the same time > press Additional Function again Clearing the Error: press Copier > press Functions > press clear > press Err > press Ok. Restarting the Machine:Power off then On.
Posted on Oct 12, 2011
Canon ir adv 6055 error 0748-9000
hi. that error indicates there is a problem with the flash board. you need to get technical support. there is nothing you can do to fix it
Apr 25, 2017 | Canon Office Equipment & Supplies
Cannon image runner 6055 E000013-0001 error
i have tried but some time it not work what is the problem it does not completely code not finished
please replay me
Jul 20, 2012 | Canon Office Equipment & Supplies
Error code E000005-0001 cannon ir-adv 6055
I have a problem with my machine,
Canon IR 6570 with error code E000005-0001
beg for a solution
Nov 09, 2011 | Office Equipment & Supplies
I'm using canon MP276 printer and i jz refilled my cartridge, but it shows error 5200 and doesnt print anymore. Please help
Read the thread "Canon pixma mp270 printer error 5200?" @ Link
Download the "Resetter"-Service Tools @ HotFile
Hope it helps.
Nov 12, 2010 | Computers & Internet
Canon ip2700 series error number 5200
when i press for print any word document that time printing processing but after sometimes one message coming that's error 5200. this problem is painful with me .please help me how can solve this problem .please help me immediately.
Oct 05, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Error code E000002-0000
Get in the service mode *28* and there under function, clear, err.
If not replace the fixing film unit
Jan 02, 2010 | Canon (6981A002AA) for imagerunner 2200,...
I have Windows XP and want to use Canon Multipass F50 printer. I have downloaded the print drivers from the Canon website. My system is recognizing the Canon Inkjet BJ S630 . I was given instruction to...
Are you sure you downloaded the right drivers, and the one's needed for your OS? Please check the canon link here. I would try reinstalling them just because your system is seeing the wrong printer to begin with.
The error message in the print queue can be troubleshot by using the windows help & support print troubleshooter (available from control panel>printers & faxes> printing troubleshooter) or using the windows event viewer to see what error code is reported and tracing the cause of the error that way...
Frequently in such a case uninstalling the printer drivers and installing them again will correct the difficulty...also see this MS link.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 13, 2009 | Canon MultiPASS F50 All-In-One InkJet...
Canon IP4000 Error Code 5100
It is a carriage error.
Most times this is a serious error that requires a Canon tech to fix it.
Look at the carriage and see if there is something obstructing it's movement. If you recently had a paper jam, there may be some paper stuck in the path.
You should be able to move the carriage freely with the power off.
Let me know.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 20, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Canon S520 blinks 7 times yellow then once green over and over, won't print
Read the info on the link below:
Solutions for flashing lights Issue: Alarm / Power light flashes orange 7 times consecutively (Print head error)
1. Reseat the print head S520 / S750 2. The Print Head may need replacing - S520 3. The S520 may require repair
spacer.gif http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=231&modelid=6611
copy and paste the complete link into your browser.
Thanks, Joe
Nov 17, 2008 | Office Equipment & Supplies
493 people viewed this question
old marine
old marine
