Question about Panasonic NN-SN657SMicrowave Oven
How do you remove the Child Lock on Panasonic Genius Sensor 1300W?
bestdarngood
  • 3037 Answers
SOURCE: My Panasonic Microwave Genius 1300W will not heat
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
Posted on May 26, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: Panasonic Genius Sensor 1300W
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://www.microwavedisplay.com/safety.txt , http://www.microwavedisplay.com/disassembly.txt and http://www.microwavedisplay.com/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
That may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Posted on Aug 30, 2009
  • 1531 Answers
SOURCE: shuts off after 15 seconds
sounds as if the magnetron has gone bad.this part of the machine is still under a warranty,and you need to call for a service technician to look at it.
do not use the unit until you get someone to look at it and or replace it.
Posted on Jan 31, 2010
SOURCE: How do I unlock the child lock on my Panasonic
March 2009 press the function key,select option #5, select option#2. This should take it out of child lock. If this doesn't work enclose your model number and I will try to look up the manual
Or, press "Cancel" three times to clear the (child) lock.
You set the lock by pressing "Start" three times.
Posted on Apr 01, 2010
SOURCE: how to unlock child lockout. Genius
press stop 3 times
Posted on Dec 24, 2010
Turn off demo mode
Jeanine,
Here is a copy of the manual for your microwave. Check page 11 for instructions on taking off demo mode. http://service.us.panasonic.com/OPERMANPDF/NNH735BF.PDF
May 16, 2015 | Panasonic NN-H765BF 1250 Watt Microwave...
Trouble code H98
H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
R
Oct 03, 2014 | Panasonic NN-H765BF 1250 Watt Microwave...
Turn off demo mode
Unplug it if doesnt its work it may be the pc board
Sep 13, 2014 | Panasonic NN-H765BF 1250 Watt Microwave...
Microwave genius sensor 1300w
I don't believe it is possible to change the display angle/tilt on this microwave. The unit ships with a protective film over the display that should be removed to make the display easier to read. However, this model is known to be difficult to read unless looking at straight-on. That and needing a flashlight to look at your food with the door open since the internal light does not stay on when door is opened. Good luck!.
Jun 13, 2014 | Panasonic NN-SN657SMicrowave Oven
HOW DO I UNLOCK THE panasonic dimension 4 Genius inverter NN-C20035
Its a child lock if your suffering with the same thing as us,My six year old brother managed to lock the microwave,all it displayed was a frustrating 'LOCK' message.to fix it i just hit the 'stop/reset' button three times
May 14, 2011 | Panasonic Microwave Ovens
Where can I find manual for Genius Sensor 1300w
http://service.us.panasonic.com/OPERMANPDF/NNSN657S.PDF
Feb 07, 2011 | Panasonic NN-SN657SMicrowave Oven
How do I unlock the child lock on my Panasonic Genius Microwave?
Apr 01, 2010 | Panasonic NN-T888S Convection/Microwave...
[Identical to earlier posting by stefeckstein]
Check for a circuit breaker on the back. If nothing, pull the plug and remove the case. Look for a blown fuse. If so, look for a shorted high voltage diode in the magnetron power supply or a shorted stirrer bearing located above or beside the cavity area where the microwaves enter. The stirrer is a metal fan-like device with a plastic bearing that often arcs internally. That shorts the microwaves out and blows a fuse. Replace the stirrer.
Aug 24, 2009 | Panasonic NN-SN657SMicrowave Oven
My panasonic genius sensor microwave says lock. How do i get it unlocked?
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes. Then let us know if the hard reset does not fix it.
You can download most Panasonic owner's manuals here. It will tell you how to turn off the Child Lock.
Jun 04, 2009 | Microwave Ovens
Panasonic NN-SN657SMicrowave Oven Logo
122 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
