Question about Lexmark X5150 All-In-One InkJet Printer
Keeps paper jamming on my printer Lexmark S300
Paper jams every time i want to print
SOURCE: Lexmark X3350 Printer
i think i found a solution for this.
its happen when you insert the papers to deep in the paper
jam jusy try to pull out the papers.
if its print its great , if not it should say load paper so in that
moment push the papers a little deeper.
Posted on Dec 22, 2007
Ajkill
  • 2035 Answers
SOURCE: Lexmark X5470 printer says, "Clear paper jam, then press check mark."
  1. Turn the printer off and open the access cover.
  2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
  3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
  4. Watch the paper as it feeds through and try to determine where the jam is occurring.
  5. Check to see if all the rollers are turning.
    If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
    If not, there is probably a feed motor or a gear problem and the printer may require service.
  6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
  7. Turn the printer off.
  8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
  9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on May 28, 2008
SOURCE: PAPER JAM ERROR MESSAGE
your sensor flag in the back is broken or missing
Posted on Jul 22, 2008
SOURCE: Lexmark X73 paper jam
please solve my problem
Posted on Sep 26, 2008
d2704
  • 101 Answers
SOURCE: 202 paper jam
try to find paper or peice (bit, partm particle) of paper under back cover.
Posted on Mar 07, 2009
I own a canon MP210 printer. Recently a paper got jammed but I was able to get it out. Now, every time I try to print, it will only grab the paper but wont feed while printing and says "Paper Jam".
Some times when paper jams a printer it damages the sensors that continue the printing process. I suggest you revisit the area where the paper jam occurred and check for the tiniest particle still lingering between the rollers. Remove what rollers you can by hand and inspect the surfaces and alignment. Put them back in the order you removed them and try again to print.
Feb 19, 2018 | Canon Office Equipment & Supplies
I have a Lexmark Platinum Pro905 all-in-one printer.
Dust and dirt are usually the main causes. Using compressed air, gently blow out along the underside and inside of your printer. Please be very careful not to hit the print head as they are very easily damaged and Lexmark isn't making any new ones any longer. Sometimes, little pieces of paper can get in there as well. If you use the 'Clean heads" option on your printer, you will use an exorbident amount of ink! I was amazed my first few times (I couldn't believe it so, naturally, I had to check it again!).
Apr 25, 2017 | Lexmark Office Equipment & Supplies
Red light is constantly blinking and when try to print, there is always a paper jam
Every time there is paper jam, the printer knows the job is not completed and hence tries to re-print after the paper is removed and cover is shut.
Clear the print job from computer.
Power off the printer and Clear the paper jam (if any)
I would try to use different tray. The paper pickup roller in one path may be worn out.
eg Sheet feeder or multipurpose tray.
Load paper in new tray
Set the application to use new tray
Ensure you sue the right thickness (gsm) of the paper. Quality of paper is crucial. Too thin; too thick can affect functioning.
Mar 16, 2016 | Ricoh Aficio Sp 3300DN Laser Printer
It wont feed the paper it keeps say paper jam but the paper is not even going in
Lexmark Impact S301 Printer won't take the paper -
printersquestions.com/lexmark-impact-s301-printer-wont-take-the-paper....
Dec 19, 2013 - Feeding paper is the first step of printing materials. However, what will you do when the Lexmark Impact S301 Printer won't take the paper ...
Paper Jam Troubleshooting on 2009 Printers - Lexmark
support.lexmark.com/index?pmv=print&page...en...
LexmarkLexmark Impact S301, Lexmark Impact S302, Lexmark Impact S305 ... When troubleshooting paper jams on Lemark's 2009 printer models, make sure you also ...
[PDF]Solving paper feed problems - Lexmark
www.lexmark.com/publications/pdfs/w820/eng/prfedprb.pdf
LexmarkUse the following table to find solutions to paper feed problems you are ... For detailed instructions on clearing paper jams, see Clearing print media jams.Missing: impact ‎s301
How To: Clear a Paper Jam on a Top Feeding Lexmark ...
? 2:30
https://www.youtube.com/watch?v=H1-J1xDbDsY
Jan 14, 2016 | Lexmark Impact S301 Wireless All-in-one...
Fix paper feeder that keeps jamming. How to clear jam and fix on-going jamming problem
What thickness of paper are you using? Also is the paper new/fresh or are you re-using paper that has gone through the printer already?
Mar 03, 2015 | Lexmark X4550 Wireless All-in-One Photo...
My samsung scx-4623f always "paper jam in exit area" every time i print even though i always put out the jammed paper in the exit area.
While Samsung SCX-4623f printer always "paper jam in exit area" you get paper checks or trigger sensor paper cup
cong ty bao ve support
good luck
Jul 07, 2014 | Samsung SCX4623F Laser All-in-One Printer
Printer says papper jam but thier is not any paper jam
Be sure that there is a paper jammed inside. You cant just see it.
May 09, 2014 | Lexmark S515 Multifunction Printer
Light flashes 3 times
Which light? Orange? You probably have a paper jam or an obstruction in your paper feed path:
e.g.
Orange light blinking 3 times
1250/E17
Description:
The front door is closed.
Resolution:
Open the front door to allow prints to exit.
1300/E03
Description:
A paper jam has occurred during printing.
Resolution:
Locate and remove the jammed paper from the printer.Press the button on the device to continue printing.
1303
Description:
A paper jam has occurred in the rear tray.
Resolution:
Remove the jammed paper from the rear tray.
Derived from: http://www.canon.co.uk/support/consumer_products/product_ranges/printers/pixma/error_codes/
Apr 14, 2014 | Canon PIXMA iP3500 Printer
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
Lexmark X5150 All-In-One InkJet Printer Logo
171 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
