Question about KitchenAid KSRP22FNSS Side by Side Refrigerator
No power at door dispenser
I have a KitchenAid side by side refrigerator model KSBS25FKWH01. My problem is that I have no power to the door dispenser. No water or ice or light. The ice maker is working fine. Is there a power supply for the door?
TurbineTech
  • 172 Answers
Hi TurbineTech.
There is a power connect inside the door hinge located at the top of the door. If this is loose it can casue this problem. If it is pluged securely then you most likely have a bad control bracket. This is one of the most expensive controls if have seen for a dispencer. Here is the part number
#2252162 retail price is $208.45 I can save you a little on this part but it is still expensive.
I can ship if to you for $188.00 I am sorry for the bad news and I really hope it is the plug in the hinge. One other possible problem could the be the touch pad ribbon has came loose from the control, check that and let me know if you need anything else. I am glad to help.
Mike Anderson (owner)
Anderson Appliance
(865)945-3808
Posted on Oct 28, 2008
What is the price on this refridgerator
The lowest price I could find for this product was $1449.00, but the model has been discontinued, it is replaced by the KitchenAid Architect Series II KSRG25FVMS 25.3 cu. ft. Side by Side Refrigerator (price $1479.00) with 3 Spillproof Glass Shelves, Humidity-Controlled Crisper, External Ice/Water Dispenser with In-Door-Ice Dispensing System and FreshChill Temperature Management System: Monochromatic Stainless Steel
Apr 04, 2011 | KitchenAid KSRG25FKSS Side by Side...
Water and ice dispenser and panel light stopped working.
02227c0.jpg Look at above diagram. #18 needs to be replace. Trim pops off then there will be several screws. Goodluck...
May 30, 2007 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid no water, but ice
first thing i would check here is my water resivoir, on these models it has a tendency to freeze,, hit the tank and upper line with a hair dryer for several minutes then give the water a try....
barring that it may be time to change your water filter even if the sensor has not picked it up yet
Oct 26, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice dispenser does not work in the door of my kitchenaid side by side refrigerator model no KSRS25ILBL00
I had the same issue; take out the ice bin, empty it and set it to dry overnight/24 hrs. There are tiny bits of water frozen in the gears, once they thaw and evaporate, voila, ice through the door again
Jun 21, 2008 | KitchenAid Refrigerators
In door water/ice dispenser not working
check the connect part, see if the gears in the right position.
Jun 17, 2008 | KitchenAid KSRS25IL Side by Side...
Kitchenaid refrigerator dispenser not working
possible bad switch, but that would only control onr of the features, sounds like your have an power supply issue to the entire door assy , check the incoming waire s eiterh on top or bottom of door hinge, look for broken/unplugged wire harness
Apr 07, 2008 | Refrigerators
Ice won't dispense, no power to water light
I would check hte wire harness leadngto the door under hte freezer hinge. itll be wrapped in a black web like covering. Just under hte unit itself follow ht ewire and unplug hte harness. then carfully cut hte black webbing and inspect wires. there tends ot be apinch point there and the wires will sheer from one another, . if so there is no replcing hte harness, the door would have to be replaced at a cost of nealry $600. not enough room for a wire nut, but hav had sucess using stright inline bullet style connector, or others have sucessfully soldered connections back in place
Mar 21, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Kitchenaid refrigerator in door water/ice dispensor
Look here.
http://www.fixya.com/support/t219770-kitchenaid_superba_kscs25fkss00
Jan 07, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Door front water and ice inop
the bord is usually where the switch's are in front. There behind the push buttons. I would make sure your getting power to the bord and go from there. If you do have power there replace the bord. If not you will need to locate the tech sheet for the wireing diagram and trace the circut for the dispensor. Good luck
Jul 18, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid KSRP22FNSS Side by Side Refrigerator Logo
98 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
