My PHILIPS SLC75ELA lcd tv won't retain certain channels. i have no trouble with stations such as BBC1, 2, 3, 4, ITV1, 2, 4, channels 4 and 5 and the +1's but if i which to view ITV3, Dave, yesterday, viva and alot besides, I have to retune the tv can you help me please
  • 6 Answers
SOURCE: no digital yet tried to retune but greyed out.
Just got through to Samsung support. Turns out the freeview card had frozen and needed a reset. To do this put tv on standby. then press in serries these buttons on the remote: 'info' 'menu' 'mute' 'power' TV will then turn on with a default screen. Press 'arrow down' button untill you reach option 12 'reset' . then push the 'right arrow' and tv will reset and start in plug and play mode and commence a scan when you've set the time. Just retuned mine and its back to normal. Hoorah!!! :-)
Posted on Oct 05, 2009
  • 8457 Answers
SOURCE: Cannot get ITV1, ITV2 or CH5 anymore after
Go in menu,Picture setting go down to reset,to back to factory seting.Go to retune or CH. again will get everythings back.
Posted on Jan 12, 2010
  • 3 Answers
SOURCE: can't get BBC1 or BBC2 - but did retune but now
do a factory reset on your tv, I did and its found all channels again
Posted on Feb 13, 2010
Testimonial: "very helpful, thank you"
  • 3 Answers
SOURCE: bbc1 1nd 2 not on my freeview TV after several
reset the TV to factory settings and try again
SOURCE: i cannot receive bbc1 and bbc2 after retuning
cant get bbc1and bbc2 on the hitachi digital television fter retunining it
Posted on Mar 04, 2010
Philips tv won't hold programmes
try replacing channel up and down tact switch..this probably helps..
Feb 05, 2013 | Philips 27PT543S 27" TV
TV won't pick up channels 7-13
These are what once were VHF channels and are still mostly assigned to local stations.
You didn't mention the source for your received signals, if antenna, cable or satellite and it does make a difference as to the possible source of the problem.
If you are receiving via antenna, then the problem is within the set itself. If from one of the other two sources requiring a 'box,' then the problem is likely within the cable or satellite box that is between your incoming signal and the set.
Jul 29, 2012 | Magnavox 39" LCD 1080p HDTV 39MF412B -...
My tv have roaring sound in certain channels.What is the cause of this?
Not the tv problems,this problems are the tv stations channels broadcasting tv stations,it is the problems of the tv stations.Some tv broadcasting stations channels are roaring sound some are normal or smaller.Just use the tv volume control + - adjust the tv suomd that all.
May 12, 2011 | Samsung HL-P6163W 61" TV
Trying to hook up converter box to Westinghouse flat screen the converter is magnavox sdtv. I get autoscan but no channels are found. I do not have an antennae. Do I need one? Help!
If ur tv a LCD tv it is a digital tv.U do not require a Digital converter box to get the new DTV free air signal broadcasting tv channels stations.But u do require a good digital antenna for it to recieve a long an strong signals to recieve a DTV free air broadcasting tv channels stations.
Dec 07, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Philips 32pf732198 no sound on certain channels
Unplug,replug the tv an hour later.Go to ur tv menu reset the Audio setting.The setting will go back to the factory setting,should work solved ur problems.Not than ur Tuner signal board have problems,must change.
Apr 06, 2010 | Philips 30PF9975 30 in. LCD HDTV
I have lost bbc1,2 , 3, from my free view help
get your freeview to do a search for an update of the channels, then it will pick up those that are missing.If it does not then check the signal reception as this may be the cause of it to lose these channels..Try somethng like high efficiency antenna with an internal booster.
Nov 12, 2009 | Televison & Video
Vizio 32lcd turns itself off on certain station
Do a full channel scan again. It should solve that problem.
Jun 14, 2009 | Vizio VW32L 32 in. LCD HDTV
Constant sub-titles on bbc1,2,itv 1, only veiwing through virgin
I'll suppose you've got a digital cable receiver.
If so there's a text option witch you can change.
Hope it's works out for you,
Kind regards,
Gerard
Jan 27, 2009 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
358 people viewed this question
Top Televison & Video Experts
