First off all Hello to everyone, The current situation is a technical problem based around the Behringer B125A speaker when the power lead is plugged in and turned on the speaker only comes on for precisely 2 seconds and discontinues also a perfect example would be the back of the speaker featuring the clip light comes on for 2 seconds and then it dies off along with the speaker which indicates that the power goes off.In regards to this matter i have checked the fuse and replaced it with another and the same problem occurs and i believe there is a solution to this problem. regards Michael Tylor
The Marv
  • 72 Answers
SOURCE: Crossed speaker wires...did I destroy my amp?
Most likely what you did was burn out the output transistors to the center channel. and probably the Bias resistors that control them. The parts themselves would be inexpensive. But they would probably have to come straight from Onkyo. And you would have to know there part number. And to get matched complimentaries. Mark up. And how far into the circuit the damage went. If I was to repair it I would probably put $100 to $125. But depending on the age of the unit and what a new won would cost is what I would use to decide to replace or restore.
Posted on Jan 16, 2007
techman
  • 3130 Answers
SOURCE: Denon AVR-810 going into PROTECTION mode
It sounds like there is a problem with the differential circuit. The bias I am not sure about, as every unit is different. You should get the service manual to be sure or call Denon and see if they can give you an idea. Good Luck
Posted on Jun 05, 2007
SOURCE: denon avr-1404
I got the same problem and on my AVR1404 it is the regulator
-15v (7915). You can control voltage on
R145 : +15v and
R146 : -15v.
The other side of these two resistances are joined together.
Good repair....
Luc
Posted on Feb 03, 2008
SOURCE: NO SOUND
I am also having a similar problem. I am using a classic 1985-87?? reciever. I dont want to give it up however, i blew a fuse after plugging in an input while the unit was turned on. The system light up and that was that. After replacing the required fuse correctly, everything turns back on. No sound output. no indication of sound off the needles either..
Posted on Oct 25, 2008
  • 4234 Answers
SOURCE: Kenwood Receiver KR-a5020 receiver won't come out of standby
The unit is in what is commonly known as "protect" mode. This means that a problem has been detected in the final output stage of the amp and the outputs are shutdown to prevent further damage to either the receiver or speakers. This should not be a difficult repair for a service shop. Expect a parts cost in the $25-$40 range. Add in the local labor rate for the total repair cost.
Dan
Posted on Nov 28, 2008
Can't hear playback through Headphone socket, only through speaker monitors!
i suggest you contact Behringer Customer Service for advixce. Without the setup in front of me, it's hard to figure out the wire routeing, switch positions, ect. that may be leading to this problem. As they would be the people most familiar with the gear, they'sd be the people to ask. http://www.music-group.com/support/behringer/askquestion
Oct 28, 2016 | Behringer Music
Is there a common reason the big speaker stops working on the ultratone k3000fx?
Hello there,
From your question, it sounds like you have had more than one Behringer 15 go faulty on you !!!!!
IF that is the case, then it seems time to turn attention to the Amplifier Perhaps over-driving the Speaker or a crossover component faulty (if it has a crossover unit inside)
The best people to ask are Behringer themselves friend, as they are the ones selling them and would know if there are 'common' failures.
Go here for 'contact us' and knowledge base.
http://www.behringer.com/assets/K3000FX_P0379_M_EN.pdf
Sep 25, 2014 | Audio Players & Recorders
How do i connect a Behringer 1202 mixer to a Behringer B215D Powered speaker
Looks like both units accept 1/4" jack & I think the 1202 is unbalance out, so just use a standard screened mono (i.e. 2 pole "TS") jack to jack lead & you should be fine. Good Luck! :-)
Jul 28, 2014 | Behringer B215D Powered Speaker (550 Watts...
How do i put my behringer inuke 6000 dsp in stereo mode?
Behringer iNUKE NU6000DSP
Stereo mode is set by the DSP processor ( I/O amp mode). The link above will lead you to the manual. On the main page go to "documentation" and to "manual , English". Review and study the functions of the DSP processor. Yo'll nedd to find I/O amp mode.
Jun 02, 2014 | Behringer NU6000DSP iNuke 6000-Watt Power...
My behringer pmp3000 doesn't seem to have much power to use my two peavey 12" speakers and use a mic. I have to push the gain and faders up more than I think I should have to, to get a decent level of...
Where do you have the gain control set on the Mic channel ?
If you have no issues with either the speakers or the Mic, and the gain control for the channel you have the Mic plugged into is set at a somewhat "normal" position, you might have a problem with the mixer itself.
Oct 28, 2013 | Behringer Pmp3000 16 Channel Audio Mixer
Where (on-line) can we find download for advanced manual for Behringer PMP 4000 16 channel powered mixer? What we found on-line was the exact manual that came with the mixer.
There really ISN'T and "advanced" manual... Everything you need to know is in the user manual that comes with it... Service manual with schematics will not give you much you can use unless you are into electronics detail.
PLEASE read my tip about Behringer PMP mixers on here regarding a hazard if you use Speakon to 1/4 inch cables or adapters. Essentially, the sleeve, NOT the tip is the HOT lead for a speaker on channel A. Ground it inadvertently and goodbye channel A amp.
Be VERY careful of speaker leads with this amp as it is easy to pop a channel IF a speaker comes loose or shorts. Loop cables through the handlesto avoid cables being yanked out or breaking plugs.
Feb 09, 2011 | Behringer PMP4000/B212XL Mains & Monitors...
How to connect mixer to a crown power base 2 amp and speakers
just use the main left and right outputs of the behringer to run xlr (3 prong balanced) to 1/4 inch (looks like a big headphone plug) cables into the inputs of the crown amp. the mixer has the xlr outputs and the amp has 1/4 inch inputrs, sop the cables will have to reflect that on both ends. run the outputs of the amp (rca outputs, i believe, you may have to get a rca plug to 1/4 inch jack adapter, and then use a 1/4 inch speaker cable) to the inputs of the speakers, again, the amp has rca outputs and the speakers will likely have 1/4 inputs, so you will have to address that wil an adapter. have each speaker in its own channel.
Nov 22, 2010 | Behringer *new* Behringer X1222 16-input...
B300 speaker blowing mains fuse as soon as power applied
The power transformers in these and some other behringer speakers have a habit of short circuiting.
Good luck trying to get any details from behringer about spares or tech info..they act like they have something to hide...and maybe they do ;).
You can unscrew the amplifier part from the speaker and disconnect all leads except those 2 going to the power transformer..if it still blows the fuse then the transformer is history.
Mar 21, 2010 | Behringer Eurolive B212A Speaker
Can this all be hooked up?
There was never anything mentioned about the 18 yamaha sub in the hook up process
Aug 17, 2009 | Crown CE1000 2-Channel Amplifier
Amp keeps blowing speakers
If the amp blew the speakers , it sounds like the amp pumped HIGH levels of DC voltage into the speakers.
Get another amp and not Behringer,not Pyle,not Gemsound and not Numark.
Feb 02, 2009 | Behringer EUROPOWER EP2500 Amplifier
 Grubhead
Grubhead
