I have 2 towers connected, how can I use printer & internet from both?
I purchased a KVM switch & connected my 2 towers together but I don't know how to get both towers to use the Internet or the same printer. One tower is a HPwith Windows XP. The other is basically a Heinz 57 with Windows XP. Both have been connected to the Internet & the printer separately. I'm not sure what I'm doing wrong, I've tried 'sharing' the networks, other than that I don't know if I'm on the right track. Please help!!!
    Sergeant:
    Champion:
  • 317 Answers
Try using the same network name for all PCs under the same network, you can change this on the Computer Name tab of the My PC properties.
Posted on Oct 28, 2008
Can I connect 2 computers sharing a KVM Switch to 1 USB printer?
You need a USB printer share device such as this one http://www.amazon.com/IOGEAR-2-Port-Printer-Sharing-GUB211/dp/B001SEB45M/ref=sr_1_1?ie=UTF8&qid=1328912939&sr=8-1
Feb 10, 2012 | Brother Office Equipment & Supplies
Kvm switch is not detecting my g5 mouse , tried diff ports and tried alternating keyboard and mouse. think the switch has gone bad
this is not uncommon. many kvm switches cannot work with those types of wireless mice. the reason for this is due to connection codes. these mice require a connection to secure the use with each computer. you can attempt to do this with your setpoint software. located in C:\Program Files\Logitech\SetPointP you will find the program CONNECT.EXE
run this to redo your mouse connection. i will however inform you that even if this works there is a large chance that upon switching to the next pc the mouse wont work and you will need to repeat this process with each pc switch everytime you toggle pcs.
rule of thumb. if the mouse is wireless don't use it with a kvm.
Jun 29, 2011 | IOGear GCS632U 2-port KVM Switch
Problem:HP 336044-B21 8-Port KVM Switch do not seems to function properly, green light is not coming, sometime blinking, rack monitor do not show any signal coming from server, although the cable from...
You may have a bad ethernet cable. I would try the easy thing first and just go to Best Buy, Amazon etc... and purchase a new RJ45 CAT5 or CAT6 ethernet cable. Since you are receiving an orange light it is indicating that the port is not active. Also check the cable make sure its seated properly at both ends even with a new cable. Cheers! Hope it helps! J the Guru.
Oct 16, 2017 | HP (336044-B21) 8-port KVM Switch
My computers seem to have become somehow linked by the KVM switch
The GCS632U is just one KVM switch. But if you're going to check it out, it has actually two separate connections.
It will just switch once you toggle from one computer to another.
Try to power cycle the KVM switch.
1. Shut off both computers.
2. Disconnect the KVM switch from the computers. (make sure that not even a single cable is connected to the computer, even the audio).
3. Leave it disconnected for 10 minutes.
4. Reconnect the KVM and boot up the XP first.
5. Boot up the Vista, try to toggle from one computer to another.
6. LASTLY, shut off the Vista and see if same problem will occur.
If you get the same problem, then you need to contact IOGEAR and have them RMA the device. Because this is the first time that I heard of this problem.
Thank you and good luck!
Jan 25, 2010 | IOGear GCS632U 2-port KVM Switch
I want a picture of it to know how to put my two computers together
The KVM switch is visually intuitive.
Instead of connecting the monitor into a particular computer you now connect it (and the other computer) to the KVM switch.
Similarly for the mosque and keyboard.
Dec 19, 2009 | Aluratek 4-port KVM Switch
Switch
KVM switch: This is a Keyboard video and mouse switch. It is used to connect multiple computer/servers to the same Keyboard Monitor and mouse. It is typically use in Racks housing multiple servers to swap between server without having to use a Keyboard Mouse and a Monitor per server.
SMC switch: I believe is a brand for Ethernet switches, used to connect computer together in the same LAN.
Nov 29, 2009 | SMC EZ Connect SMC2671W Wireless Network...
I am unable to get my computers to recognize my mouse or key board? System is connected to two dell towers.
Do they work fine if you connect the keyboard and mouse directly? Does the video connection work correctly? Check that the appropriate ports are enabled in the BIOS (USB or PS/2).
Jul 19, 2009 | Belkin F1DK102P 2-port KVM Switch
KVM Switch
The reason why this is happening is because the notebook keeps on loosing it's resolution and the GCS62 can't remember what's the resolution set to the notebook.
To resolve this problem, please follow the steps below:
1. Disconnect the tower from the GCS62 and leave the problem computer (notebook)still connected to the KVM switch.
2. Set your desired resolution (ex. 1280x768) to the notebook.
3. Restart the notebook while it's connected to the KVM switch.
4. The GCS62 will remember the resolution you set to the computer.
5. After rebooting the notebook, you may now reconnect the other computer and try to toggle to see if you will get the same problem.
But doing these steps should resolve the issue.
Mar 20, 2009 | IOGear MiniView GCS62 2-port KVM Switch
I had to purchase a new computer tower and it has windows vista on it and i tried to connect my lexmark 6170 printer to it and it will not work because of an install error, i need to know if the printer is...
According to Lexmark's website:
Download: http://www.downloaddelivery.com/srfilecache/cjrX6100EN.exe
Description: Driver for Microsoft Windows Vista. This driver is a minimum function driver. Please use Windows Scanners and Cameras or Photo Gallery for Scanning.
Sep 28, 2008 | Lexmark Office Equipment & Supplies
KVM functionality
This happens on KVMs, some more than others. I have a couple of Avocents that work great with Dell and HP servers, a Belkin OmniView that works great with two Dells and OK with a home built. Bottom line is some switches work better than others just like some PCs seem to behave better than others. If you?re looking for suggestions I would stay away from the cheaper $50 and under switches unless you find a good, used, guaranteed one somewhere. I like the Belkin OmniView and Advocent (really expensive, meant for servers and other medium sized sites). I would stay away from LinkSys, they make good wireless equipment but haven?t heard much good about their KVM switches. The original post was a few months ago so this is really intended to help anyone in the future who is researching a similar problem and winds up here.
Apr 26, 2007 | Linksys ProConnect Compact KVM Switch...
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
