Question about EuroTech Dryers
Eurotech dryer vent hose adapter
Looks like an"adapter" plugs into vent hole on rear of dryer to connect vent hose? Need to find one.
jsrock516
  • 5911 Answers
SOURCE: how can I connect my
The dryer should not be pushed all the way against the wall. For the ventilation to properly work, you should leave about a one foot space between the back of the dryer and the wall. Using 90 degree elbows on the dryer and wall can also eliminate crimping. Also, it is strongly recommended that use use the semi-rigid metal type vent hose ducting. It is not that expensive and comes in adjustable lengths. The semi-rigid ducting is recommended by most builders and it resists crimping and rodent damage. If you continue to use a dryer with the exhaust vent clogged it will lead to eventual heating circuit failure due to overheating. If you have any questions, please post back and let me know. I hope this helps answer some of your questions.
NOTE: If you purchase semi-rigid ducting, make sure you purchased the hose clamps that go with it. This will prevent the hose from slipping off the connection points.
Posted on Jun 15, 2008
jumptrout51
  • 3361 Answers
SOURCE: burning smell from gas dryer. outside vent was plugged.
This service manual will show how to access your dryer.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/479b6231e5693a13852571650061e709/$FILE/8178559.pdf
Posted on Feb 14, 2010
FixinFax
  • 3085 Answers
SOURCE: Maytag Dryer sparks when connecting foil exhaust hose to vent
You have a bare wire inside the dryer laying on a metal part of the vent system. FIRE HAZARD
Posted on Mar 04, 2010
heatman101
  • 43501 Answers
SOURCE: My EuroTech dryer turned on for a second then I
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The electric heating element broke and is touching the metal and shorting out...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 14, 2010
Macmarkus
  • 2605 Answers
SOURCE: My WTL 5410 dryer (electric condensation) has hot
Welcome to FixYa.
You are correct, the unit being a condenser model doesn`t require any additional venting or exhaust to outdoors, that is the purpose of condensing the moisture internally.
As to the issue of air flowing out of the unit I`d suspect perhaps the heat exchange may need cleaning, if it is plugged it will cause the air to be directed elsewhere.
I`ve attempted to attach below the procedure for cleaning, if unsuccessful for whatever reason, too small for example, you or your landlord can email me at macmarkus@live.ca and I can send you the "pdf" guide for your Bosch dryer.
Keep me posted on your findings and I`ll try to assist you further if need be.
Thanks for choosing FixYa today and good luck.
Please take a moment to rate the info presented and leave a testimony if you feel it warranted.
Regards,
Macmarkus :)
Posted on Sep 28, 2010
Who services eurotech dryers near zip 98368
Clean out your vent before calling a repair man.
Apr 18, 2012 | EuroTech EDC158 Electric Dryer
I bought a DeLonghi PACC120E portable a/c with no manual. Also, how do I vent it? It did not come with the vent.
All units of that sort come with a hose which goes on the back or the side, if you don't have this unit is useless
Sep 01, 2011 | DeLonghi PAC C120 Portable Air Conditioner
Will not dry after 2 hours
Hello. Actually this is not a ventless dryer, there is a vent hose whic typically comes with the appliance. If the appliance is not vented out-of-doors it should at least be vented into the room. Pull the dryer out from the wall so you can inspect the rear of it and you will see the vent hole. If need be, go to any hardware store and purchase a dryer vent kit.
Here is a clip from the Asko T712 literature.
Easy to install Simply plug it into an electrical socket and connect the ventilation hose provided.
Dec 19, 2009 | Asko T712 Electric Dryer
Brand new vented dryer causing condensation in
Hello, I would recheck the exhaust hose connections, as it sounds as if you've either got some holes in the vent hose/line or the connections are not fully around the dryer exhaust vent, etc.
You might also want to look at the dryer to see if the internal exhaust pipe came loose during transport and installation. It might be possible that the exhaust vent pipe inside the dryer is loose or off the fitting. An easy way to check this is to remove the exhaust pipe from the back of the dryer and (with the dryer unplugged from the electric outlet!) check by looking into the back vent on the dryer. You can also feel inside to see if it's loose, etc. Just be carefull as the metal pipe could have sharp edges, so wear some gloves to be safe.
As this is also a new dryer, you might also contact the place where you purchased it, as there might be an quality issue that they've received a service bulletin on and could provide you with further assistance.
I hope you find this Very Helpful and best regards!
Dec 14, 2009 | Tricity Bendix Dryers
My lint screen has no lint on it after drying a load. it also takes more than 1 cycle to dry. I have checked venting and it is clear. Heating element seems to be working, gets hot and goes off, comes back...
generically: Danger Will Rogers Danger...Better try to get inside the cabinet and check the venting....
..possibilities:
Vent pathway plugged (hence no lint) and lint backing up inside cutting flow and thermal sensor shutting down heating element.
..Vent hose in hole of cabinet but not connected to duct inside cabinet and lint is just filling cabinet. (common reason for premature heating element failure--3 times for my aunt fixed by tech--before I saw the vent hose connected only to the cabinet)
...both of the above is a hazard and can burn out the heating element.
..might possiblly be able to back blow through the vent hole and/or lint trap with a shopvac/vacuum cleaner (try **** and blow); but if works still need to verify that air pathways are clear and vent hose connected properly inside--should be fairly obvious inside.
...hope helps
Aug 09, 2009 | Roper RES7648E Dryer
How do i connect my whirlpool
Connect dryer vent in rear of machine as per instructions. Make sure no kinks are present in exhaust hose as you move dryer into position. Insure proper outside vent is correct for your unit. Plug into 220 volt electrical outlet.
Jul 07, 2009 | Dryers
Dryer steaming up my house
ck vent againalso be sure dryer is not pushed back too far crimping vent hose..to double ck leave rear vent hose off and dry a load ..may be some lint and moisture in house but if dryes in mormal time will confirm vent problem ..vent may only be partially blocked also look for hole in vent hose or better yet replace entire vent hose
Oct 27, 2008 | Roper RGX4634KQ Gas Dryer
Dryers Logo
Top EuroTech Dryers Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Are you an EuroTech Dryer Expert? Answer questions, earn points and help others
