Question about Cobra Radio Communications
Where can I get a new set of rechargable batteries for my cobra microtalk cxt275
The Cobra CXT275 radios can operate on any type of battery (Alkaline, Ni-Cad, NiHM). Each radio uses 4 AAA batteries. Only special rechargeable batteries can be recharged in the actual radio (see below)
If I remember correctly, they come from the factory with NiHM batteries rated at 300mAH. "mAH" stands for milli-Amphere-Hour and it represents the storage capacity of the battery. (The larger the mAH, the longer run time of the battery)
You have 2 options: A or B
Option A) Buy a set of Nickel-Metal Hydride AAA rechargeable batteries and a external battery charger. When the batteries die, pop them out of the radio, and charge them in the external charger. When they are recharged, pop them back in the radio.
Option B) If you want the ability to charge the batteries in the radio, using the "drop-in charger" then you will need modify the batteries so they can charge in the radio.
Follow these steps: You must be somewhat electrically inclined to do this...Note: By doing this you are going to void the warranty of the radio and new batteries that you just purchased.
1) Buy a set of Nickel-Metal Hydride AAA rechargeable batteries. You can probably find some rated at 600 mAH (this will extend the run time)
2) Looking at the back of the radio with the cover removed, there are 4 slots for batteries.
3) Looking at the battery slot on the far right, you should notice 2 contacts for the negative contact. The one on the bottom, is the contact for the radio to receive power from the battery. The one on the side (about 1/8" inch up from the bottom contact), is the contact for the charger to recharge the battery.
4) You will need to modify 1 battery for each radio. Somehow you need to bridge the bottom contact with the side recharge contact.
5) (look at the negative end of the cobra factory batteries and this should help you realize what you need to do) depending on the manufacturer of the new rechargeable batteries, you may be able to use an X-acto knife and remove 1/4" of the plastic wrapper from the bottom of the battery on the negative end. This should reveal the metal shell of the battery that can mate with the radio's side recharge contact.
If it does not, you need to find another way to have it mate with the bottom contact. You might be able to use some Aluminium Foil to bridge the bottom contact with the side recharge contact. Be sure the Aluminium Foil does not touch the positive contact of the battery to the left! You could have an electrical short!
6) Insert the Modified Battery into the right slot.
7) Insert the other 3 new batteries into the other slots. These do not have to be modified. Only the right most battery needs to be modified.
8) Drop the radio in the charger for the batteries to charge. The red LED on the charge base should come on. If it does not, then the side recharge contact is not making a good connection with the negative battery terminal.
9) If the red LED comes on, then the modification works. Let the batteries charge for 24 hours for their first initial charge.
10) When the batteries die after radio use, then charge them for about 12 - 16 hours in the drop-in charger. Do not let the radios sit in the charger for long periods of time. That can destroy the batteries. Take the radios out of the charger when the allotted time has passed.
11) If you hardly ever use your radios you will want to drop them in the charger for about 8 hours every 3 months. This will keep the batteries fresh without damaging them.
I hope this helps, Thomas (Electrical Engineer)
Posted on Apr 07, 2012
  • ivana
    ivana Oct 24, 2013
    por favor o manual ctx275 cobra em portugues
  • Anonymous Mar 05, 2017
    The aluminum foil worked like a charm! Thank you so much
  • 247 Answers
SOURCE: Brand New Cobra microtalk won't work!
Double check against all the instructions - in particular, make sure the batteries are charged according to "before first use" spec, that the volume is turned up, and that the squelch (if fitted and not automatic) is adjusted properly. If it still doesn't work, take it back to Wal-Mart. If the product doesn't work, there's no need for the packaging to be in good condition - it's not as if they'll be needing it to resell the goods to anybody else. A.
Posted on Apr 08, 2007
  • 109 Answers
SOURCE: Batteries won't charge on new cobra 2VP 270 radios
If radios are brand new then I would take them back to the store for warranty exchange. The other opton is to vist a local radio service center and ask the tech to jump the battery. if the battery falls below a certain voltage it might need a quick jump sart from a power supply with a higher voltage normally 12 volts works well...
Posted on Aug 20, 2008
  • 1800 Answers
SOURCE: I need an owners manual for a set of Cobra
Welcome To Fixya.
I'am Glad to help You Sir.
I can't Find Your specific Model Number But i thought that You may find it your self in this page.
Please click here to get the manuals page for your product.
also Please Give a good Feedback.
So i can help You Further.
Posted on May 13, 2009
  • 14 Answers
SOURCE: Constant RX mode on cobra microtalk PR3850WX
Sounds like the radio was subjected to electrostatic discharge. If you have your manual, and it describes a way to do a "master reset" on the radio, follow the instructions. This usually involves pushing down on one key while turning the radio on. Otherwise you have to find a licensed dealer for factory service, as there is no way to repair the radio yourself. The use of surface mount technology still confuses many Techs unless they have been to a company's two or three week seminars.
Posted on Jul 24, 2009
SOURCE: Our friends have a cobra
yes as long as your on the same channel and freq.
Posted on Sep 09, 2010
What volt charger is needed for (cobra microtalk pr560wx)? Thanks,Richard
Hi Richard,
Volt Charger??? I'm not sure what you mean, but if you mean what voltage to recharge the batteries, then you need to look at the unit, all over to find the AC input, there should be something tht states voltage and polarity there, if it infact has one.
Pease reply with more detail re: your query.
Jan 20, 2013 | Cobra Ga-cs Or Ga-cl Microtalk Charging...
How do you turn on the cxt275
you can contact the mobile service provider.......
Oct 11, 2011 | Cobra Electronics microTALK® PR 3850 WX ...
Cobra pr 3850wx bought new NiMh 800mAh 1.2v rechargable batteries now the base charger lights won't come on when i put the radios in it
  • A Cobra 3850wx Radio requires 4x600mAh NiMH 1.2V AAA Part # GA-3ANH rechargeable batteries.
  • Not just any AAA rechargeable battery will charge in the unit.
  • All will work in the radio but not all will charge inside the radio. It has to be a specific battery.
  • This is an example of what you need. GA-3ANH batteries which will charge inside your radio.
Regards, Tony
May 22, 2011 | Cobra Microtalk 100 FRS Walkie Talkie...
I am looking for an owners manual for the Cobra CXT275 Two-Way radio model.
i just bought a cobra cxt275 walkie talkie i want to know what channel to set it on to get the best distance without breakin the law
Sep 06, 2010 | Cobra Two Way Radio
Microtalks won't charge
I have the Cobra Microtalk 4100 FRS radios with charging base. After changing the batteries with new nimh rechargables the charge light would not illuminate and the unit would not charge. I noticed the original batteries had a metal band around one end. This band makes a small connection inside the battery compartment on the first battery. Seems to be a cheap way to ensure you dont try to recharge the unit with non-rechargable batteries installed. I rapped a small piece of tinfoil around one end of the first battery in the new set then popped it back in and now they will charge correctly again. Dont try this with non-rechargable batteries! I would recomend buying original replacement batteries.
Nov 28, 2008 | Cobra Microtalk 100 FRS Walkie Talkie...
Jun 28, 2008 | Cobra MicroTalk PR 1100 WX (15 Channels)...
Radio Communications Logo
623 people viewed this question
Top Cobra Radio Communications Experts
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
