Question about Samsung HLP4663W 46" Rear Projection HDTV
Samsung DLP4663W Is my Samsung DLP TV possessed? After I have it on for a half hour or so, it turns itself off. I turn it back on and half and hour or so later, it turns itself off again. I turn it back on and then it pretty much operates quite well. Any advice, anyone?
  • 1,197 Answers
    1. Ensure that the TV is off. It may be advisable to unplug the TV as well.
    2. 2 Using a Phillips screwdriver, remove the single screw affixing the lamp cover (the small, grill panel on the back of the set) to the chasis. There is also a grill that is held in place by tension. Just "pinch" the thumb clamp on the bottom of the grill and slide it out. This is the same procedure you would perform to change the lamp, except in this case you will not need to remove the lamp itself.
    3. 3 Inspect the spring-loaded blue safety switch to ensure it is making good contact when the panel is secured. The switch should deflect downward when the panel is replaced. If the contact with the panel is suspect, very gently bend the metal bracket on which the switch is mounted.
    4. 4 Replace the grill cover and the lamp door, and continue to enjoy your TV.
    jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
  • 5.Check some basics first. Make sure the sleep timer on your TV hasn't been turned on, telling your set to turn off at a certain time. If your DLP TV is acting erratically, Samsung recommends turning the set off and unplugging it for 30 minutes. After 30 minutes plug it back in and turn it back on. Unplugging the set resets it, and that may fix the problem.
  • 6 Check your power supply. Make sure your Samsung DLP is securely plugged into a working outlet. Plug the TV into a different outlet to see if the problem still exists. Make sure that a fuse hasn't blown in your house or a circuit breaker hasn't flipped.
  • 7 Replace the lamp. If your Samsung DLP is shutting off or won't turn on, a bad lamp is the most likely cause. To replace the lamp, remove the lamp cover from the back of the TV by removing the screws with a Phillips screwdriver and slide it out and away from the TV. Remove the screws on the lamp assembly and slide it out of the TV. Disconnect the old lamp and insert a new lamp into the assembly. Slide the assembly back into place and replace the screws. Do the same for the lamp cover.
  • 8 Check for signs of overheating. Samsung DLP TVs generate a sizable amount of heat. If the components inside the TV get to hot, the TV will shut itself off as a protective measure. Make sure your DLP is out 12 inches or so from the wall. Make sure that all of the vents on the set are clear of any obstructions. Allow the TV to cool down for 30 minutes before turning it back on.
  • 9 Contact Samsung. If none of the above tips help, it's time to contact Samsung, as the problem is likely something that should only be fixed by a qualified service technician. More serious problems may include a bad power supply or a bad ballast. Attempting to repair those yourself will void your warranty and may cause more serious damage to your set.
  • The safety switch exists so the user does not accidentally remove the lamp door while the TV is on. Doing so could, theoretically, result in burn or electrocution. This spring loaded switch causes the TV to shut down when the door is opened.
  • Since the TV's chasis is plastic, expansion and contraction can cause the switch to lose firm contact with the lamp door. The TV's behavior could then be such that after being on for a while (getting warm) the plastic expands and the switch loses enough contact to cause the TV to shut down. The frequency with which this phenomenon occurs is not only dependent on the internal temperature of the TV, but also the ambient temperature of the room as well as the relative tension on the switch itself. The user's perception is that the TV starts up fine, but then "randomly" turns itself off after being on for a while.
  • If you have recently moved your TV, it is very common for random shut-downs to occur. This is because the move has shifted the flimsy plastic chasis of the TV, thereby loosening the contact between the lamp door and the switch.
  • Make sure your TV is off and cool when performing this procedure.
  • Posted on Aug 31, 2010
    Samsung DLP TV shuts off
    sounds like your power supply is going south...check the voltage coming out of the wall first
    Feb 25, 2008 | Samsung DLP HL-P5663W 56" TV
    TV has started to make a really loud humming noise, then sounds like a siren noise after you turn it off and now it has started to turn off by itself. Thinking maybe a fan? Worried it may cost more to have...
    It could be 1 of 2 fans (fans are around $30.00 each) or more likely it is the color wheel beginning to fail. Color wheel will cost around $180.00-200.00, plus labor. I would recommend calling 1-800-samsung to find the nearest service center. Part should take an hour to an hour and a half to complete repair.
    Jun 30, 2010 | Samsung DLP HL-P5663W 56" TV
    I have a Samsung DLP 56" It will turn off by itself. However it is not consistent all the time meaning it will stay on for hours some of the time and others it will turn off frequently.
    IN the back of the tv, where you replace the bulb is a plate with 4 screws. Unscrew and take off plate. there is a little switch there that goes up and down. I can't remember if you have to tape it up or down but turn the tv on and play with that switch. I'm not a tv expert but when i had bulb replaced on my dlp this is what i had to do. So basically that liitle switch is a safety switch and it needs to be locked down or locked up. i used tape. Hope that helps.
    Nov 27, 2009 | Samsung DLP HL-P5663W 56" TV
    Samsung TV , black screen
    Check for the timer settings if possible reset to default......
    Sep 28, 2009 | Samsung DLP HL-P5663W 56" TV
    Samsung 2006 56" HLR5688W DLP TV Right half of screen turns black. Left side normal picture. Corrects itself when set is turned off and back on. Randomly occurs - sometime picture is ok for half a day...
    Possibly a bad light tunnel assembly if the part is only a shadow effect. If not then probably a bad DMD board. The DMD board is part of the light engine but needs to be replaced by a technician.
    Aug 15, 2009 | Samsung Televison & Video
    Samsung dlp HL56A65 turns off and on by itself
    It looks power board problem.
    You need to get service from Samsung.
    Mar 04, 2009 | Samsung DLP HL-P5663W 56" TV
    Samsung dlp hl-r5667w
    This Tv make a lot problems with the color wheel and fan thermostat, lamp cool. Need be check the color wheel first. I am suggested dont have nothing on the back cover ( make hot or not ventilation). More information parts at Thank you
    Aug 12, 2008 | Samsung DLP HL-P5663W 56" TV
    Samsung dlp hdtv turns itself off
    Have a 46 inch behaving the same way. I have the extended service contract, so they are getting a calll tomorrow. I ll post what they say
    Dec 27, 2007 | Samsung DLP HL-P5663W 56" TV
    Samsung HLP4663W 46" Rear Projection HDTV Logo
    198 people viewed this question
    Jerry Greenberg
    Jerry Greenberg
