Question about Hobart Food Mixers
How to remove handwheel hobart h-600 mixer
How to remove handwheel h-600 mixer
  • 109 Answers
SOURCE: Hobart Mixer bowl won't go up
If the worm screw is turning but not lifting the bowl, the bowl lift nut is stripped.
H600 part number is 24198.
To change it, you need to undo the screws down the right side yoke slide to release the yoke. You will need to lift the yoke to reach some of them. If you have some wood place it under the yoke and over the legs to protect the paint. On top of the yoke are two blots holding the keeper plate over the nut. One is the stop screw for bowl height. Don't loose this setting. remove the slide, edge the yoke forward a bit to free the worm. Run the old nut down the worm and off the bottom. When you run the new nut on, all the excess grease and metal shavings will start to build up. Clean as you go, or better still, brush with solvent or similar to clean the worm threads . relubricate, run the nut up above the yoke, reload the yoke and attach keeper plate, reload slide.
To adjust slide, snug screw near bottom keeping slide close to yoke, run yoke to top and tighten top screw just enough to hold slide in place, lower yoke to bottom, gently tap top of slide in a 1/16" and tighten top screw. Run yoke to top of slide. It should start to bind slightly in the last 2 inches of travel, which will stop the bowl from dropping in use. Tighten remaining screws.
Posted on Aug 08, 2009
Cuisinexpert
  • 61 Answers
SOURCE: oil leaking from hobart d300 mixer
DEFINITELY contact the manufacturer (Hobart) on that one. Sounds like you're having some sort of an internal problem with it (something might be cracked), and in this situation, the best way to go is to contact the manufacturer rather than try to repair it yourself. If you're still under warranty, and you try to open the machine up to fix it yourself, you could wind up VOIDING the warranty, and if you're out of warranty, most repair places won't touch a machine that you've messed with already--too much of a liability.
Just give Hobart a call, and they should be able to help you (if you're in warranty, sometimes even for free!). Their phone number (according to their website, www.hobartcorp.com ) is 1-888-4HOBART (1-888-446-2278)
Good luck! :)
Posted on Aug 27, 2009
milten1
  • 1304 Answers
SOURCE: how do you change the oil in a hobart h 600-dt
there is an oil case drain pulg under the top by the clutch, you can drain the motor housing through there, \
i have used 5w30 in a pinch
but it would be better if you ordered hobart oil from the website
its cheap but very very good
Posted on Oct 16, 2009
  • 110 Answers
SOURCE: PLEASE HOW TO CHANGE OIL OF A HOBART MIXER
underneath trans. you will find a drain plug remove, drain oil,replace plug ck the sight glass @ this time if not clear would recommend replacing glass remove top cover where the front cover screw theaded into remove that is your fill hole. add new oil till you hit level line in sight glass,reassemble
Posted on Jan 09, 2010
  • 110 Answers
SOURCE: what is error code 99
error 99 stands for communication fault between timer board and the sr drive.there are 5 things that can cause this error.1.rs-485 cable disconnected or malfunction 2.1 con monitordisconnected or malfunction. 3.run/stop wiring disconnected or malfunction. 4.timer board malfunction. 5.sr drive malfunction. hope this helps, dont forget to vote, thanks, monomoy
Posted on Feb 05, 2010
PLEASE HOW TO CHANGE OIL OF A HOBART MIXER H-600 C Cooper Lebanon PA
Dec 31, 2009 | Hobart Food Mixers
What type of oil does a Hobart 60 quart mixer use?
a H-600 takes part#102973-71, thehl600 takesthe same just less. dont for get to vote tks. monomoy
Dec 11, 2009 | Hobart HL600 Legacy Stand Mixer
Hobart h 600 parts guide or service manual
I need a gear helicoidal of mixer Hobart h600
Sep 02, 2009 | Hobart Food Mixers
Electrical connection of hobart h600
it requires 3 phase with ground it is a four wire system
Jul 24, 2009 | Hobart H600 Stand Mixer
Oil change for hobart h-600 mixer
Needed to know which part to open up to add or change oil on Hobart Mixer h-600
Mar 05, 2009 | Hobart H600 Stand Mixer
Manual for a Hobart H600, please. M Martinello 2347 Pillette Windsor, ON N8T 1P7 519-566-6677
Hello, i´m in mexico, i have a h 600 mixer from hobart. I need to know what kind of lubricant need for gear box and planetary system
Jun 28, 2008 | Hobart HL600 Legacy Stand Mixer
Food Mixers Logo
70 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
