SOURCE: Reset Lexmark T644
1. Turn off the printer. 2. Press and hold (check) and .(right arrow). 3. Turn on the printer. 4. Release the buttons when Performing Self Test displays. The message CONFIG MENU displays on the top line of the operator panel. 5. Select Reset Maintenance Count from the Configuration menu. 6. The message Reset Maint Cnt=Reset displays momentarily. Press (check) to reset. When the reset operation is complete, the menu returns to the Printer Setup Reset Maintenance Count Screen. Scroll down to the Exit Configuration Menu and Press Select to Return to Ready status.
SOURCE: setting print count on Lexmark T644
I'm assuming you mean the maintaince counters...
Press and hold the check and right arrow buttons on the front of the printer
The message Reset Maint Cnt=Reset displays momentarily. Press Check to reset.
SOURCE: Lexmark T644 network settings missing on menu
These are options that you must add via the Network Setup Menu.
Don
SOURCE: lexmark t644 error code 917.00
This error indicates that there is a charging problem with the transfer roller. You could start by cleaning the contacts for the transfer roller (power off printer first). The transfer roller is the black foam-like roller under the toner cartridge. Handle it with paper because the oils on your hand could damage it. To remove it, just pry under the far left side with a screwdriver. Lift and pull to the left to remove. If this does not fix it, then you have a more serious problem. It could be one of the arms or the HVPS.
SOURCE: My lexmark X4650 gives me a message that the
Make sure there are no print jobs stuck in the queue then unplug the power adapter from the printer. The power adapter is the black box behind the printer where the power cord is attached. Wait at least 30 seconds before plugging it back in. When the printer's ready, try printing again. If the problem persists, I suggest you contact Lexmark Technical Support to further investigate the problem. Thanks.
