Question about Samsung HT-X50 System
HT-d720 samsung funchk
After two minutes display lamp funchk and turn off. Why best regards and thanks.
4 Suggested Answers
SOURCE: Samsung home cinema system HT-THX25 Multiregion hacks
Turn on the HT with no DVD. Press the following buttons on the remote: ENTER 8, 4, 2, 6, 9 ENTER
It will turn off. When turned again on it is a region free HT.
Posted on Nov 26, 2008
  • 56 Answers
SOURCE: powering off for protection samsung HT-WX70
the fan is broken on your unit, this is a feature to keep the unit from over heating
check if there is anything blocking the fan from moving/rotating
try to contact your manufacturer
Posted on Jul 02, 2009
dunnbiker
  • 8546 Answers
SOURCE: Fan check shows up on display.
Can you see or hear if the fan is running? Is there sufficient clearance (4 inches) between it and the nearest surface for airflow? Is it clogged up with dust bunnies? You may be able to fix it yourself.
Unplug the unit. Look inside the vent at the rear. Reach in with a non-conductive probe to see if the fan turns freely. If not, it's bound up and needs replacement or unclogging.
If it turns freely with power off but doesn't rotate with power on, it's dead.
If it turns sufficiently fast with power on and you still have Fan Check, it's a sensor.
Posted on Feb 11, 2010
Samsung DLP making noise and is picture out
Lamp probably went out. Refer to your manual regarding lamp replacement.
May 16, 2010 | Samsung DLP HL-P5663W 56" TV
Samsung - HL-S5065W Problem The TV is takes about ten minutes tu start working correctly i have to turn it on and off multiple times, meanwhile the tv either the bulb turns on but no image is displayed or...
Hi Roberto,
Well many thing could be happening here for example,the DMD board could not be working properly,please also listen carefully for any strange noises,like high pitch whirling sounds,that could mean that your color wheel is not working properly,the lamp will only last you from 6000 to 8000 lamp hours if you have a Phillips lamp and if you have a generic lamp that will last you from 3500 to 4500 lamp hours but i doubt that, this is your problem you can go to www.fixyourdlp.com for further trouble shooting
Regards
Jan 26, 2010 | Samsung Televison & Video
Samsung ht-x50 home theater system keeps shutting off
You have probably set the sleep timer. Here's how to switch it off: To cancel the sleep timer, press the SLEEP button until <OFF> appears on the display.
Jul 07, 2009 | Samsung Electronics - Others
My samsung home cinema system - HT-X250; Trips off every couple of minutes with "Fan Check" higlighted on the display
Had this same issue with my Samsung HT-X50, it seems these systems have cheap fans. Mine was under warranty but when I contacted samsung they wanted me to pay to ship it to them. **** that, it would of cost me 70 to ship.
What I did was open the unit take the fan and go to a computer store asking for a similar one, I got all this done for about 10 bucks. **** that samsung warranty
Apr 09, 2009 | Samsung HT-X250T Theater System
Samsung ht-ds610 wont work at all
Loading mechanism is stuck some where in loading or unloading process.
Unplug unit form AC outlet for couple of minutes and replug back in, power up and check.
Feb 11, 2009 | Samsung HT-DS610 System
Just puchased grundig LCD TV,model glcd2205whtdv, tuned the tv stations in okay. But every 3 minutes the LCD display goes off, sound is still there. Use the remote to turn unit off then turn on again,...
Initially it would appear that you have either a LCD screen problem or your CCF Lamps goes out. Of the two I would suspect more the CCF Lamp which could be the lamp themselves, the inverter that powers the lamps or the logic circuitry that deactivates the lamp.
Additionally, this would be heat related or even possibly a loose connection somewhere in amongst the areas above mentioned.
Considering that the unit is new and presumably under warranty, perhaps your best bet would be to call it in for service by their authorized service personnel. Any diagnostic/corrective action would require that the back of the unit be opened for a look & see which of course would void your warranty.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 03, 2008 | Televison & Video
HT-Q70T
Hello..have you tried to disconnect ac-cord ?..than wait a few minutes and reconnect ?...try this......good luck ron...
Mar 15, 2008 | Samsung HT-Q70T System
Feb 02, 2008 | Samsung HT-X20 Home Cinema 600W Theater...
Samsung HT-X50 System Logo
29 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
