Question about Linksys Wireless-G Range Expander (WRE54G)
Setting up wireless range expander
Hi i have the linksys wireless range expander and it was given to me with no instructions on how to set it up it is the 2.4GHz wireless G range expander..thanks
  • 689 Answers
Hi
You can get the online manual which contains all the steps to set it up. go to link below for the manual.
http://www.linksys.com/servlet/Satellite?c=L_Product_C2&childpagename=US%2FLayout&cid=1130267578138&pagename=Linksys%2FCommon%2FVisitorWrapper
Good Luck
Posted on Nov 10, 2008
What range expander should I use with a Linksys Dual Band Wireless-N Router Model WRT 320N?
For this router you can use the Linksys range expander model WRE54G v3 take not of the version number that is important since the older range expander don;t work on all routers.
Feb 13, 2011 | Linksys WRT320N Wireless Kit
Cant find a strong enough connection
You need to buy a Linksys Wireless-G Range Expander to boost the signal
  • Move your wireless router to a central location in your network, keeping in mind that the router should be at waist level at the very least, not on the ground.
  • Plug in the Linksys Wireless-G Range Expander in the room where your wireless router is. You'll move the range expander later, but for setup purposes, it should be in the same location as your wireless router.
  • Press the Linksys Wireless-G Range Expander's "Auto Configuration" button for five seconds, which will allow the range expander to detect your wireless network and configure itself with the appropriate settings.
  • Unplug the Linksys Wireless-G Range Expander and relocate it to a location closer to the Xbox 360.
  • Ensure that the antenna for the Linksys Wireless-G Range Expander is pointing upward, and keep in mind that the higher the range expander is placed, the better performance you will get out of it.
  • Plug the Linksys Wireless-G Range Expander back in, and your wireless network should have a much greater range, ensuring that your Xbox 360 is able to maintain a good connection to the network.
  • Dec 29, 2010 | Microsoft Wireless Network Adapter Xbox...
    Hi, I just got Linksys WRE54G V.3 and was trying to install the CD. But I keep getting "Site Survey fail" message. My house is using a router made by Apple, and does not have extra space to...
    The range expander helps to extend the range of wireless network...
    Anyhow the range expander has to be placed withing the range of your Apple "wireless" router (Make sure your apple router is wireless router, if it is a wired router, then there is no use of range expander...! U need to buy an Access Point instead)...
    your range expander must be connected to the computer(using an ethernet cable) from which you are trying to configure...
    Site survey searches for the available wireless networks in range...
    It should show your existing wireless network...
    You need to select your appropriate network and you need to configure the Range expander wireless settings according to the Apple router's wireless settings...
    exactly the same SSID(Network name), Security type and encryption technique, password PSK (security key) has to be selected on your range expander as in the APPLE wireless router...
    Thats it...
    You are done...
    Your wireless network range would have extended now....
    Dec 09, 2010 | Linksys Wireless-G Range Expander (WRE54G)
    Dear I did everything mentioned above but still light is red
    Hi Friend, In this case I would recommend you to please reset the range expander once again and connect the range expander with the ethernet cable once again. Match the settings of the router to the range expander I mean while configuring the range expander, the wireless network name and the wireless key should be same and the channel should be same and the security type should be same.
    If it still doesn't work then I would recommend you to please try to change the channel to 1 or 9 or 11
    Dec 08, 2010 | Linksys Wireless-G Range Expander (WRE54G)
    I have a netgear wireless router with WPA security. and i bought a WRE54G . I cannot configure the expander as you know netgear IP is 192.168.0.1 and lynksys expander is 192.168.1.240. when i open...
    Try to reset WRE54G
    Resetting the Range Expander to Factory Default
    The range expander can be set to factory default by pressing the Reset button of the range expander for 20 seconds.
    NOTE: The default IP address of a range expander is 192.168.1.240.
    After resetting the range expander to factory default and you're still unable to access the web-based setup page, make sure that your computer's proxy settings are disabled. For instructions, click here. To disable the proxy settings using a Mac computer, click here.
    NOTE: If all the steps above failed, try to disable any security software on your computer before accessing the range expander's web-based setup page. Click here to learn how to disable your computer's firewall.
    If you are using a Wireless-G Range Expander (WRE54G v2 or v3) and you can't access the web-based setup page, perform the following steps:
    Checking Physical Connections
    Make sure that the computer is connected to the range expander's LAN or Ethernet Port. If the range expander is properly connected, check the LEDs on the network adapter. For instructions, follow the steps below:
    Checking LEDs on the Network Adapter
    Make sure that the LED light of the computer's network adapter is lit or blinking. After checking the LEDs on the network adapter, assign the computer a static IP address.
    NOTE: If the network adapter's LED is not lit, try using a different cable to further isolate the problem..
    Assigning the Computer a Static IP Address
    For instructions on how to assign a static IP address on your computer, click here. After assigning a static IP address, check the computer's connectivity to the range expander.
    Checking the Computer's Connectivity to the Range Expander
    For instructions on how to check the connectivity of your computer to the range expander, click here. If you're still experiencing difficulty accessing the web-based setup page, reset the range expander.
    For instructions on how to restore the range expander to factory default, click here.
    If you're still having difficulty accessing the web-based setup page, make sure that your browser's proxy settings are disabled.
    If you're using a Wireless-G Range Expander (WRE54G v1), you need to do the following:
    For instructions on how to assign a static IP address on the computers' wireless network connection, click here.
    Connecting Wirelessly to your Range Expander
    NOTE: In this example we used WUSB54GS V1.0 (Wireless-G USB Network Adapter).
    If you're using a Mac computer, click here for instructions on how to connect to a wireless network using the AirPort card.
    Step 1:
    Run the Linksys Wireless Network Monitor by double-clicking this icon 3719-001.jpg at the bottom-right corner of your screen.
    4146-005.pngStep 2:
    Click Site Survey then select the SSID of your wireless range expander and click Connect.
    NOTE: The default SSID of the range expander is in this format linksysRxxxxxx.
    4146-007.pngChecking the Computer's Connectivity to the Range Expander
    NOTE: If you're using Windows 98 or Windows ME, click here.
    If you're using a Mac computer, click here.
    Windows 2000/XP
    Step 1:
    Click Start, then click Run.
    Step 2:
    When the Run window appears, in the Open field type "cmd", then click OK.
    3984-003.pngStep 3:
    When the MS DOS Prompt appears, type "ping 192.168.1.240" then press [Enter].
    Step 4:
    See if you're getting 4 replies, Packets: Sent = 4, Received = 4, Lost = 0 (0% loss)
    Nov 08, 2010 | Linksys Wireless-G Range Expander (WRE54G)
    I am having trouble installing my linksys wireless expander . What do I do ?
    hi , you need write in the page settings , the ip adreess, the mask and getaway, go to the page settings router , take this adresses form there , but when you write the IP for example , you router say 192.168.1.2 , this number 2 you need to changeit for 3 or 4 or anyone that not exist yet on router or any pc
    Aug 12, 2010 | Linksys Wireless-G Range Expander (WRE54G)
    Can't connect to the internet after range expander set up
    Ok, what you need to do is reset your Linksy wireless connector box, hold button for 30sec. After, you need to try to connent it to your phone and or computer. Try to see if you have a connection.
    Jan 11, 2009 | Linksys Wireless-G Range Expander (WRE54G)
    Wireless g range extender
    Hi there ....
    before anything else, can you please what is the version of range expander is is wre54g v1,v2,v3?
    1) either which, please do verify your wireless settings of your DLINK router
    -- the network name or ssid
    -- security if you enabled any on your router
    -- wireless channel
    -- please check the default gateway of your router if it is 192.168.1.1
    ** please take note also that the best location for your expander would be inbetween your router and your computers
    2) once you have gathered the wireless settings
    -- you would need to manually configure your expander coz it didnt work .. Please remember that the LINKsys expander is designed to work with linksys routers, so it may or may not work.. I just need to set your expectations on this ...
    3) once you have verfied the default gateway of your DLink router ... please reply to this thread and let us proceed in configuring your wre...
    Thanks and good luck!
    Oct 31, 2008 | Linksys : WRE54G Wireless Range Extender...
    How can i configure Linksys Wireless range extender
    hi ,
    i went through the problem ur facing and the only solution that comes into my mind is that u will have to do the wireless settings on the router and copy the same settings on the range expander as well .... no changes.... and do remember that range expander at that time should be connected to the router at that time with the help of an ethrnet cable .....
    ity would be working like a horse then ...
    Oct 23, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
    Linksys wireless G range expander
    Hi David,
    I need to know that what type of router u r using.
    If it is Linksys router just follow these steps,
    with the help of the Ethernet cable connect the range expander to any one of the 4 ports in the router...
    ur computer shuld be directly hook up to the router..
    open internet explorer in ur computer..in the address bar type in 192.168.1.240(ip address of the range expander)
    it will prompt for a username and password...leave the user name blank and the password will be admin.
    u can see the linksys range expander set up page...
    u can find SSID at the bottom of the page...
    ur router's SSID and the range expander's SSID should be same..and also the password should be same..
    If the ssid or password mismatch between the router and range expander u can find these kind of Error messages...
    Good Luck....try it and revert back
    Jul 03, 2008 | Linksys Wireless-G Broadband Router
    Linksys Wireless-G Range Expander (WRE54G) Logo
    563 people viewed this question
    Top Linksys Computers & Internet Experts
    Prashant M
    Prashant M
    Michael Galve
    Michael Galve
    Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
