Question about Skil Octo Multi Finishing Sander
Skill octo sander instructions for changing sanders
2 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: how do i change the
On the link below is the manual for the sander. It will tell you how to change parts.
https://mdm.boschwebservices.com/MDMCache/English%20[US]//t10/0000000/r00908v-1.pdf
Posted on Apr 23, 2011
Where do l buy spare drive belts for skill 560 watt belt sander
From any hardware store, just bring the old belts with you.
Oct 26, 2016 | Sander Tools & Hardware - Others
My skil octo sander won't rotate with the bottom plate on. With the plate off it rotates just fine, is there a way to fix it? I've tried both tightening and losening the screws.
This happenenrd to my sander two days ago.
I searched online for answers and useful information to solve it but couldn't find any thing.
But, I have good news.
I fiddled with the sander till I just figured out what the issue is.
I've discovered that the ball bearing appears to be busted.
It's bearing #608-2RS
im gonna take it to a shop to have it pulled and I'll replace it and see if it flys.
will update later.
Dec 18, 2015 | Bosch Skil 7207 100W Octo Detail Sander
I have a pressure control skil octo Sander .i think i pressed down to hard now the pressure light stays on and it won't sand but Motor runs good
The transmission between the motor and the sanding belt has been damaged by the excessive pressure you applied. Check it carefully to see if something got bent and operation can be restored. If it is gear driven and you broke off some of the gears then .....................................
Sep 16, 2015 | Skil Tools & Hardware - Others
Where can one purchase sanding belts for a skill 593 sander 2 1/2 X 16?
Search on Amazon for 2-1/2 x 16 sanding belts and you will get a plethora of options
May 07, 2015 | Sander Tools & Hardware - Others
Skill 7292 hand sander won't turn on
a lot of times sawdust gets into the switch contacts and won't allow the tool to operate. I would try turning the switch on/off several times and see if it temporarily helps. Also check the cord. Let me know if you need more assistance.
Feb 23, 2012 | Tools & Hardware - Others
I just aquired a used Skil Model 409 orbital sander and am having trouble inserting the paper. Is there a technique peculiar to this machine that?
Sorry, I was missing that part. You got it right, though. three hands is the answer. Orrr, you could go get some nice sticky back papers and cheat. They come in a variety of sizes or can be cut from full sheets. what you have there is a good sander to use while you figure out what kind of sander you want:)
Best regards, Farmerbear
Sep 07, 2010 | Skil Octo Multi Finishing Sander
Skill belt sander belt stops moving
most belt sanders are simular,if you have right size belt,there should be a lever between the belt wheels,pull lever out,put belt on,then close lever,some also have adjusting knob,turn clockwise to tighting.
Sep 30, 2009 | Tools & Hardware - Others
Changing the sanding pads
You use a 1/2 inch socket wrench to remove the nut at the top of the spindle shaft, slide the old sanding sleeve off and the new one on.  Replace the nut.  You may also have to insert a different size table insert if you are changing the sleeve size.
Instruction manual is available free at: http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Delta/a20932,sa350k.pdf
May 30, 2009 | Delta SA350K Shopmaster Boss 1/4...
Skil Octo Multi Finishing Sander Logo
54 people viewed this question
Top Skil Tools & Hardware - Others Experts
ray gallant
richie46
Are you a Skil Tool and Hardware - Other Expert? Answer questions, earn points and help others
