Tv was working well, and after been shifted, picture went pal whitesh, and shadowi peoples images while written immages can been seen better the immages of peoples, any idea about the cause and how to fix it, and which area involved to rectify the picture again
many thx
Horizontal hold IC and circuit is failing The remote signal will cause it to spasm because of this faulty set of parts. It needs professional intervention to fix this properly
hello that is a common problem with this sony tvs, just replace the vertical IC am sure that is your problem, now if you do not the skills to replace it call the repairman
There are no adjustments for this problem,if the unit has been working good for 3 years and suddenly gives you this pix is time to call a qualified technician,among many reasons you might have loose solder conections in the horizontal drive circuit or poor regulation problem in the power supply,if you dont know how and where be safe and call a Technician.
Your symptom description is a little vague. Is there sound? Is there a full screen? Assuming there is a full screen and sound I would look for bad solder joints on the boards. Particularly the CRT board but really just resolder all the connections in the set. The KV series has been plagued with more than their share of bad solder joints. Give this a try first and if this doesn't solve it give us a more detailed explanation of the problem. Good luck.
