Question about Toshiba Satellite A75-S211 Notebook
Laptop will not stay powered.
I have a toshiba satellite that started to occasionally not charge the battery and ultimately shut down because it wasn't able to be powered with the AC cord. This would occur with no movement of the laptop or power cord at all. I could leave it working find for hours only to return and find that it had powered off on sometimes back on again. It went from that to just powering for 10 seconds and back off again.
  • Anonymous Nov 11, 2008
    My lap top stays on about 25 seconds with the fan running and then shuts off. This is with the ac cord attached.
  • velut_umbra May 11, 2010
    The adapter is faulty.
    Sergeant:
    Champion:
  • 310 Answers
The power convertor sounds bad. also the plug-in. the outletin the wall or on the mother board
Posted on Nov 17, 2008
Laptop would start up but shut down immediately and the battery w
How long does it stay on for? I had a similar problem. Mine would stay on for 10min then shut down. It ended up being an excessive build-up of dust around the cooling fan. If your problem is similar its worth taking a look at. Good luck, Todd
Dec 22, 2009 | Toshiba Satellite A25-S207 Notebook
Shut down computer but some lights stay on
Your are not "shutting down" the laptop. It is going into "Stand-by" mode.
#1:
When you want to shut down,
select [Start]
then select "Shut down" and not "Stand-by"
The power button will also work.
#2:
Press the power button and nothing else.
The laptop will log you OFF and "shut down"
Nov 08, 2009 | Toshiba Satellite A135-S2386 Notebook
The fans run but the computer fails to turn on
Likely either a bad power connector (common) or the charging circuit on the motherboard may have a problem.
Oct 12, 2009 | Toshiba Satellite P35-S611 Notebook
Toshiba satellite lap shut down. charged and now will not turn on
Try on AC if works replace battery!!swampratt200!!AAAEEE!!!!
Jul 21, 2009 | Toshiba Satellite A60-S1561 Notebook
Toshiba satellite m35 power issues
Hi !
While power off, disconnect the power adaptor.
Take off battery.
Plug the power adaptor back and try to start !
Is it running?
If yes, than the power adaptor is OK.
Now shut down and disconnect the power adaptor.
Put back your battery and start!
Leave it untill you 'empty' the battery.
Do not start your laptop.
Plug the power adaptor and do not start your laptop yet.
Is there a led idicator showing that the battery is charging ?
Does it shows when the battery is full charged (e.g. red/yellow=charging, to green/off charged)?
If not, leave it for at least 3 hours. After that, start your laptop (adaptor is plugged) and see if you still have an icon saying charging 99%.
If that is the case, then something is wrong with the battery.
Check your warranty, and replace it.
DO NOT OPEN the battery - nothing interesting you will find inside - nothing you can do !
Regards.
Mar 28, 2009 | Toshiba Satellite M35-S456 Notebook
Toshiba satellite x205-s9800 - Frozen boot screen
hi,
try this one
take out the battery and take out the Ac adapter now press and hold the power button for 15 sec this will release any static charge residing in your laptop.
now try start your laptop with battery in.
Further Queries are welcome
Jan 21, 2009 | Toshiba Satellite P205-S6287 Notebook PC
Always running on batteries
You can still use your laptop even if you take out the battery and run on ac alone. You can also leave your battery in with the ac plugged in for 4 hours to charge it even if the laptop is off. Hope this helps. Thank you.
Sep 20, 2008 | Toshiba Satellite P35-S611 Notebook
Toshiba Satellite 2410-PS241L laptop does not start.
Plug it into the electrical outlet and then turn on your laptop. if it comes on and works fine, then your battery is just simply dead, and if it will charge, just needs to charge. If not, then you are going to have to replace your battery. But assuming all of this is true, and your laptop will power on when using your electrical outlet, then yes, feel free to use it whenver you like when plugged in.
Sep 04, 2008 | Toshiba Satellite 2410-S203 Notebook
Toshiba Satellite A135 laptop
Try disconnecting power adapter and removing battery for two minutes. If the laptop still does not boot then there is an hardware problem. You can try taking out and putting back ram modules, but my suggestion is to take the laptop at a repair shop, if you cannot fix it by removing battery.
Jul 29, 2008 | Toshiba Satellite A135 Notebook
Toshiba Satellite A75-S211 Notebook Logo
63 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
