Question about Canon PowerShot SD1300 IS IXUS 105 Digital Camera
Error de objetivo se apagara automaticamente reinicie la camara
Esta se apaga y trato de reiniciar pero no se puede hacer nada
2 Suggested Answers
rajdeepdutta
  • 2517 Answers
SOURCE: erro de objetivo apagar automaticamente reiniciar
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated
Posted on Feb 23, 2011
Mensage es error de objetivo
plg 307 te AMO!! hahahaha lo soluciones con el golpe entre el flash!! gracias men me salvaste la vida!!
Jan 26, 2012 | Nikon COOLPIX L18 Digital Camera
Enciende y aparece reinicie camara error de objetivo
tengo problema con mi camara...!!
la enciendo y m sale error de objetivo reiniciar camara... la camara se apagara autmaticameente
Aug 30, 2011 | Canon PowerShot A495 Digital Camera
Mi camara canon powershot A3100 IS se apaga automaticamente y aparece en la pantalla se ha detectado un error. debe reiniciar la camara y yo no se como solucionar eso porque no he podido reiniciarla. como...
TENGO UN PROBLEMA CON MI CAMARA POWER SHOT A 3100 IS LA MISMA PONE EN LA PANTALLA SE HA DETECTADO UN ERROR DEBE REINICIAR LA CAMARA DIGAME COMO SOLUCIONAR ESTE PROBLEMA MI CORREO ES josemm22@yaho.com
Aug 28, 2011 | Canon PowerShot A3100 IS Digital Camera
Mi monitor parpadea y no arranca ? que debo hacer tengo conocimientos de electronica pero no se que hacer
Primero verifica la luz frente a tu monitor si la misma esta parpadeando o de color anaranjada hay un problema con la tarjeta de video de tu computadora. Si esta verde esta recibiendo señal de tu tarjeta de video. La mejor forma de saber si tu tarjeta de video esta funcionando correctamente es utilizar otro monitor que sepas que esta funcionando correctamente y conectarlo a la computadora. Si funciona bien, tu monitor esta dañado. Mi recomendación es compra uno nuevo por que es mas economico que repararlo.
Mar 03, 2011 | LG Office Equipment & Supplies
Tengo una camara kodak c743 que dice error 111 y se apaga,la lleve a un casa de fotografia kodak y me dijeron que la enviaron al service ,me cobraron supuestamente le flete y el presupuesto y me dijeron...
Tienes un error en el tambor de lentes. Según ESTA PAGINA parece que unos engranajes de plástico adentro de la cámara se rompen.
Puedes tratar de desarmarla e incluso arreglarla si consigues el engranaje de repuesto. O lo puedes mandar a hacer.
Nov 17, 2010 | Kodak EasyShare C613 Digital Camera
AL PRENDER LA CAMARA CANON A 560, ME INDICA ERROR DE OBJETO REINICIAR CAMARA,,AGRADECERE SU AYUDA....
fui a tomar una foto prendi la camara y me aparecio ERROR DE OBJETIVO LA CAMARA SE APAGARA AUTOMATICAMENTE REINICIAR LA CAMARA no se como reiniciarla porfavor nesesito arreglarla graciasssssssssssssssssss
Nov 14, 2010 | Canon PowerShot A560 Digital Camera
Tengo problemas con un Multifuncional HP Laserjet M1522, por alguna razon empezo marcar ERROR 5 Y NO PUDO INICIALIZARSE el SCANNER , Funciona como impresora pero no como copiadora o Scaner, , parpadea la...
59c05df4-3e41-4402-8674-16fa865682b6.jpg1e27574a-853d-43f0-83e9-639f0eb8015f.jpg6f9cb0d0-efc0-4725-b485-113c15667e78.jpg639e37f6-dbca-4b87-baf4-9919d68a26d4.jpgf319f64c-35bb-4a4d-b11b-3637a94260fd.jpgdf4c7415-80c2-478b-9083-7ef214ae9172.jpg027f0e9b-f662-4bc9-916c-d62c423d9e73.jpga1eea8bc-2311-4ede-b6b1-2b036b38dc64.jpg7ada6481-ced7-4dab-b710-09760d6b9498.jpg04f42b95-4eec-4796-8556-1ef7ab6cddbe.jpgHola amigos, tambien tengo este problema con una impresora, reinstale el firmware y no funciono, lo que note es que el motor estaba quemado, lo desarme y lo rebobine, compre el alambre me parece que fue calibre 33, aprox 25 mts, 260 vueltas con una resistencia de 10ohms por bobina. bueno despues de esto lo monte y funciono un poco mejor. pero al parecer es la tajeta logica pregunte a un proveedor de hp y su valor es de aprox 3000 pesos mx, lo que hice es hacerle un agujero al escaner.
Detalles.
viendo de frente el escaner del lado izquierdo le hice un agujero de 3mm. y le puse un cincho largo(pueden usar algun desarmador, el cincho se lo puse doble para que no se doblara, el cincho debe entrar con facilidad pero no muy olgado para que no se doble, al introducirlo no es necesario sacarlo ya que el carro lo sacar, es por eso que no debe quedar apretado). esto me permite mover el carro del escaner a lo posicion "0". posicion de partida y hubicacion de la banda indicadora(Empujarlo unos 3 cm aprox, despues solo se calibra).
La finalidad de esto es de manera manual regresar el carro, se apaga y se vuelve a encender y listo. funciona nuevamente.
Este error me aparece despues de haber utilizado el ADF, el cual el carro se mueve al lado izquierdo para poder escanear automaticamente los documentos. posteriormente no puede regresar.
Aqui pues es donde le podemos ayudar a regresar a su posicion original.
Espero que les ayude en algo.
Aug 29, 2010 | HP LaserJet M1522nf Multifunction Printer...
Falla nokia 5530 al responder o hacer llamadas
buen dia a mi me pasa igual y me dijeron una mala noticia. tiene un corto. me ddijeron q lo tienen q soldar y queda commo nuevo eso si, me cobran 500 pesos mex. pero ojo hay algunos sitios q te dicen q se la juegan que puede darse el caso q quede brickeado osea q se quede como labrillo o pisapapeles.sniff no tengo cash para arreglar el mio. waaaaa. eso se debe a q falla ese modelo de la nada. eso me explicaron.
Mar 04, 2010 | Nokia 5530 XpressMusic Smartphone
MI PROYECTOR EMPIEZA A ENCENDER Y SE APAGA.
buenas noches. tengo un problema con mi proyector.. hace unos minutos encendio y se veia la imagen pero luego lo desconectaron y cuando volvi a encender solo prende la luz de power pero no sale la imagen quen podra ser???
Aug 29, 2009 | Dell 2200MP Multimedia Projector
Canon PowerShot SD1300 IS  IXUS 105 Digital Camera Logo
2,556 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
