Question about JVC XV-S30 DVD Player
JVC XV-S30 dvd player what cables needed to hook to tv?
  • 3 Answers
SOURCE: JVC DVD player stuck in Split screen
the player is set to progressive scan mode.use relevant button on remote to reset to interlace mode. Duane,S/Africa
Posted on Sep 01, 2007
SOURCE: Unlock code for jvc XV-N652
Below is the only known process to unlock that model of DVD player. Does not work on 100% of dvd players.
1. Turn on dvd player
2. Open the tray
3. Press 0000 in the Remote Controller
4. Change to any region you want (0 for region free)
5. Press Pause to confirm your change
6. Turn off
7. Turn on again and enjoy
Hope this works for yours, please post back if it does. Thank you for trying Fixya!
Posted on Mar 24, 2009
SOURCE: JVC dvd player model XV-N650 unlocking codes
From another site...
Region code hack posted by mairel, December 18 2007:
A greeting to all, good after point to look for and to break the head, I could convert to multizona my DVD, I count them that I stay fillet. here they go them the procedures, I hope it serves them. 100% guaranteed.
1. Turn on
2. Open the tray
3. Press 0000 in RC
4. Change to any region you want 0 for region free
5. Press Pause
6. Turn off
Posted on May 15, 2009
  • 325 Answers
SOURCE: Region free code needed for JVC XV-N670B DVD
try this one, its not the exact model number but its close enough.
Open tray
Press 0 three times
Brings up a menu
Press 0 for the multi region
Press ENTER
Press PAUSE to exit.
hope this helps
Little Dish Fitter
Posted on Sep 17, 2009
SOURCE: JVC XV-M555 DVD player has the parental control
Found the manual for the player buried in a box from moving. Procedure is
1) With no DVD in player
2) Press enter while holding down shift to display parental lock menu
3) If you dont remember the password enter 8888 to access the options
4) Use cursor to move arrow to country code option
5) Use right cursor to select country code, then down cursor to move country code to US
6) Use left cursor and down cursor and right cursor to move to set level
7) Use down cursor to toggle through level options. (None removes all blocks)
8) If setting a level toggle down to password and set new 4 digit password.
Posted on Jan 02, 2010
How do we connect a DVD to a TV
Hi, Go to Radio shack store and get a cable signal splitter. Its a small device that splits 1 line into 2 or 3, so that you can run more players or recorders on 1 line in. See the guys there for more options.
Feb 26, 2012 | Televison & Video
Only getting very low sound on front speakers on my jvc th-s51 system
if you are only getting the front speakers, you are hooked up in stereo mode. Are you using red white and yellow cables? Is the source in stereo? Try a digital coax cable.
Aug 19, 2010 | JVC XV-511 DVD Player
Split screen
First step is to read your manual,it will tell you what to do
May 06, 2009 | JVC XV-N50 DVD Player
DVD is hook up and no picture on the TV.
You have to make sure that the RCA cables are properly connected to the TV. Check the TV/Mode if it's set to AV1 (Audio/Video1) or AV2. You may check the TV remote to set it to AV1 or AV2.
From the DVD, the cable should be connected to OUT. And on the TV...video and audio should be connected to IN.
Apr 05, 2009 | JVC XV-S300 DVD Player
Lock problem with my DVD player
Dear friend,
press and hold stop+play button on the front panel of the dvd player more than 15 sec the player will be unlock
Dec 08, 2008 | JVC XV-S30 DVD Player
Picture but with blue screen
YOUR CABLES TO THE TV ARE NOT HOOKED PROPERLY OR DAMAGED
Dec 02, 2007 | JVC XV-N55 DVD Player
JVC DVD player problem
You have set the DVD to progressive output for your big tv. The little one will not accept this. Your manual will tell you how to reset it. The remote may be needed. Reconnect it to the big tv and check the menus.
Sep 01, 2007 | JVC XV-N422S DVD Player
Hooking up DVD player to HD wires.
Have you tried to go to a different channel?
Apr 16, 2007 | JVC XV-LTR1 DVD Player
No Colour
what is a jvc xv player? how about if u connect ur tv to a cable program, does it give u the same problem? if not, ur xv player is not compatible with ur tv or tv needs to configure setting and also that means ur tv is ok. if yes, there is a problem in the color circuit of ur tv. have it check by a serviceman. but if its not economical to do it, just buy a new one.
Jan 15, 2007 | JVC XV-N312
Player freezes
If its in a specific disk: Try to clean it... Is it possible your DVD disks are China bootlegs? If so, then you have disks that are bad as a result of bit rate down conversion problems. If not: Try cleaning the lens, all you need is a q-tip wet with alcohol. Just don't push to hard. If this does not correct the problem, you may need to have your TV serviced.
Dec 27, 2005 | JVC XV-S30 DVD Player
JVC XV-S30 DVD Player Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
