Question about Palm Tungsten T5 - Multilingual Handheld
How to install Gps ViaMichelin
Everytime I try to install this programme I get an error message saying uninstall then reinstall. how do I do this?
0 characters
1 Points
GPS Not Running on HTC P3300
This is a common problem if you have lots of other applications installed and/or running at the same time on the phone. I would recommend going through and making sure you uninstall some programs if you can and also use Task Manager to unload what other programs you can.
Feel free to contact me via the website of my smartphone repair business in Rockville Maryland if you have any further questions.
Oct 19, 2009 | HTC P3300 Smartphone
Error Code 0x80040fb3 - Blackberry
Use this
Connect USB
Select option 4
Reinstall OS
Apr 20, 2009 | AT&T Blackberry Curve 8300 Smartphone
ActiveSync Not Working
it might be trying to configure a microsoft exchange sync thats why its giving you that message you may want to try and uninstall activesync and download the lastest verizon 4.5. during install do not click on check box that says connect to exchange server and try to sync again, should get you taken care of,
Apr 06, 2009 | Motorola Mobility Q9m Smartphone
Palm Treo 750 , when I start to sync it stops and says "attention required" but when you try to access the "attention" it just shows the log of when it last was synced. Should I re-install something??
Try going to File: Delete mobile device and trying to sync. If you have something like an addon that syncs (like quick gps, etc) try unchecking it when you are re-setting up the sync settings for your treo (after you 'delete' moble device from activesync)
If an addon was causing the problem, uninstall it on your pc, then reinstall it, then it should work.
Mar 07, 2009 | Palm Treo 750 Smartphone
Selected com port not available
Please un-install and re-install the software,, that should fix the problem,
Jun 09, 2008 | Palm Treo 755p Smartphone
I get an error message everytime I tr to sync.
I had the same problem. I found that by removing Addit from my Palm and reinstalling Palm OS without the Addit software, it cured the problem. Never had a problem since I removed Addit.
Apr 01, 2007 | Palm TX Handheld
Can't run software on dell computer
This sounds like an issue with your desktop. Something has got corrupted maybe. Try going to the cd driectly to install a program. It only needs internet explorer when it runs the menu for the cd. It can all be installed by finding the setup for the particualr program your installing. Might need to reinstall internet explorer on your desktop and if that doesn't help, I hate to say it but might need to reinstall windows on it. Are you using ME or XP? I had many problems with kernel32.dll errors with ME but have not had any problems at all with XP. Only way I ever fixed those errors with ME was to reinstall. ME was the least stable version of windows.
Sep 14, 2005 | Dell Axim X5 Pocket PC
Cannot hoysync with outlook 2003
After installing, reinstalling, deleting, hard resets, hitting head against wall... I tried installing the Pocket Mirror conduit as a last ditch effort. An error message popped up saying it could not find the mapi32.dll file. I looked at another PC, located that file in the windows32 directory, copied it to my PC, and I was able to hotsync with Outlook. To test this, I uninstalled the Pocket Mirror and Palm desktop SW, then deleted the mapi32.dll. Installed the Palm 4.1.4 sw, outlook 101 update, plus the conduit update, had same error messages. Added the mapi32.dll to the windows32 directory - was able to successfully sync with Outlook!
Sep 11, 2005 | Palm Tungsten E Handheld
I have the same PDA but unfortunately I am not the expert. In my opinion it is not possible to install IE separately. It is not known to me that there is any possibility to download IE for PDA as an individual program. If you have already removed all programs why don’t reinstall the OS and it should work properly again. Did you already install Windows Mobile 2003 SE? Please go to and download iExplorer! Try to install it!
Sep 08, 2005 | Toshiba e800 Pocket PC
Unresolved Items when synching
Try the following.... Open Active sync on your PC. Double Click on Calendar. Change the settings such that it syncs only 0 past and 0 future appointments. SYNC (this will clear all calendar items on the IPAQ) Now go back in to those Calendar settings, and set it back to the default which is 2 past weeks and All Future appointments. SYNC (this will now reload all appointments into your Ipaq)
Sep 08, 2005 | HP iPAQ H2215 Pocket PC
Palm Tungsten T5 - Multilingual Handheld Logo
47 people viewed this question
Top Palm PDAs Experts
David Payne
David Payne
Nataly Roberts
Nataly Roberts
Are you a Palm PDA Expert? Answer questions, earn points and help others
