Question about Electronics - Others
How to format transcend jf v60 32gb - Electronics - Others
SOURCE: Windows 98 SE Driver for Transcend Jet Flash V60 8GB #TS8GJFV60
hi, i srinivas, i am using dual booting of win 98 & windows xp operating systems. when i am using my transcend pendrive in win xp which is easily working, but in win 98, how can we install perpect drivers for my transcend pendrive.
so please give the solution to solve my problem.
Posted on Sep 13, 2008
SOURCE: i have Transcend JF V30 2GB pendrive i m unable to format
go to transcend website and download Jet Flash Recovery Tool and format ur pendrive...... :)
Posted on Jul 24, 2009
Geekman
  • 32281 Answers
SOURCE: Transcend JetFlash V60 16 GB Pen Drive not working properly
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that its Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32.
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Posted on Oct 05, 2009
bob_computer
  • 3153 Answers
SOURCE: Transcend 2GB jf v30 pen drive not getting detected in vista OS
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
7. It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure.
8. If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
9. If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
10. ensure that you have set removable drives for "quick removal" or that you use the "Safly Remove Hardware" option often shown on the lower toolbar.It is possible that files my not be fully written to external devices before they are removed. This corrupts the file itself and even on occasion the drive.
SPECIAL NOTES
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
Hope this gives you the information you need
Bob
Moderator
It would be very decent of you to consider the quality of our experts answers and judge them accordingly as you pass through FixYa.
Thank you
Posted on Dec 10, 2009
  • 523 Answers
SOURCE: MY PENDRIVE JF V10 (4GB) FROM TRANSCEND WEN
Hi Friend,
Please follow the below steps
Step 1: Try to right click and Scan for Virus
Step 2: If it detects any virus please remove it and then try to open
Step 3: Even after that it doesn't open then we have to format the Pen drive
If you have any clarification please feel free to reply
Regards,
Ayyasamy
Posted on Mar 18, 2010
Hello friends, i have one Transcend JF v30/2GB Pen Drive. But when i insert Pendrive then i can't access that. It show the error for fromat the drive. Then i go for do that. Then it display error...
This might happen due to an error or corrupted MBR, which is the sector that allow you pen to be readable and the PC might not recognize the system file being used.
I would try to connect it to another PC with a different Operating system and format it from there.
alternative you can also use Transcend recovery tool. You can download from HERE
Sep 24, 2010 | Electronics - Others
Hii i have JF V30 / 8GB Transcend pendrive.
Try finding a little switch on the pendrive, it'll be pretty tiny. This switch determines if the drive is read only or writeable. If not you can try disassembling it to find the switch. Check your manual if it says anything about a read/write switch.
Jun 24, 2010 | Computers & Internet
When i format transcend 8gb jf v10 it says disk is write protected. I'm not able to add data or format it please help..
I have purchased 8gb Transcend Pen Drive When i Connected the drive in computer a message shows "Please insrt a disk into drive". I have checked in several computers but the problem is same. Although the disk is detected but not shows the capacity when trying to open this message displayed. I have change the drive letter from my computer "Manage" option but the problem is same. What can i do?
May 14, 2010 | Computers & Internet
I had purchased a new TRANSCEND JF V10 USB 8GB. It?s not working
Call the dealer you purchased it from. They will probably replace it.
Sep 25, 2009 | Select Brands ALLPCZONE BRAND COMPUTER...
I have Transcend JF V30 2GB pendrive i m unable to format
Jul 19, 2009 | Transcend (589307) Media
Formatting the 8GB Transcend pen drive
check once whether u hv given read only option in properties
Jun 30, 2009 | Transcend 8GB SSD, 2.5- Inch, IDE, SLC...
TRANSCEND JF V10 USB COULDN'T ACCESS
the transcend you bougth is bad,you need to change it from where it was purchaced
Feb 23, 2009 | Select Brands ALLPCZONE BRAND COMPUTER...
Electronics - Others Logo
89 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
