Question about KitchenAid KBHC109J Convection/Microwave Oven
LED light says "door" when trying to use microwave and ultimately will not turn on because it thinks the door is open.
Kitchenaid KBHC109JSS03 microwave oven. I need help with two things: 1st. the interior light needs replaced. Seems simple not too worried.
2nd. The microwave thinks the DOOR is open. When trying to use the LED light says "DOOR" and the unit beeps 3times.
Does anyone know of a place to get a repair manual? Or anyone tell me step by step what to do?
thanks...
my email: lcplr35@yahoo.com
5 Suggested Answers
SOURCE: Kitchenaid microwave oven KBMC140HSO
I started having the same problem with my KBMC140HSSO. You cannot see the error codes without disassembling the control panel (the codes are on another display that covered by the front panel). After doing so I found the error code to be F2, E3 which is "Key held down too long, or key shorted". I am ordering a replacement keypad and will report back if this fixes the problem.
Posted on May 07, 2008
MicrowaveSvc
  • 9011 Answers
SOURCE: KitchenAid Superba Microwave/Oven, Microway Door message
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you only need a switch, you can order one from us for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Posted on Sep 27, 2008
THENTHEREWER
  • 131 Answers
SOURCE: How do I replace a lightbulb in my Kitchenaid microwave?
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=KEMS307DBS&siteCd=KAD#parts_list HEY ANDYCOOL,GO TO THIS LINK IT'LL SHOW YOU ANYTHING YOUR HEART DESIRES ABOUT THIS UNIT(DRAWINGS,USER MANUAL,PARTS LIST,INSTALLATION GUIDE,ECT.)SORRY BUT FROM THE LOOKS OF IT YOUR GONNA HAVE TO PULL THAT PUPPY.BUT YOU BE THE JUDGE OF THAT.GOOD LUCK,HOPE THIS HELPS!!!!
Posted on Nov 08, 2008
MicrowaveSvc
  • 9011 Answers
SOURCE: Broken torsion spring needs to be replaced
There are indeed two springs that "cross" each other, and they must be both be replaced to ensure full strength.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 25, 2008
SOURCE: Microwave Oven Door Spring Replacement
Remove the front panel by removing the screws located on the inside of the door (note hold door inplace, since it is heavy and will fall out after screws removed). Unscrew screws located on bottom of plastic retainer (2 each) Remove tension spring. Note 2 are included right and left. Note color of spring on end, different springs for different door types, stainless, black,beige or white. Replace all in reverse order.
Posted on Mar 26, 2009
Makes random beeping noises all hours of the day & night. Annoying but wondering if something is wrong or if there is something we can do to stop it? Works fine otherwise!
I have never heard of that happening before. I think you need to ask Kitchenaid direct. Once the machine is off and dead, it should stay quiet until you press a button or open the door.
http://www.kitchenaid.ca/en_CA/contact-us/
Help Contact Us KitchenAid
Mar 28, 2016 | KitchenAid KHMS2056SSS Microwave Oven
KItchenAid microwave KHMS1850S: interlock switches replaced, but fuse keeps blowing
http://kitchen.manualsonline.com/manuals/mfg/kitchenaid/khms1850s.html
Jan 27, 2015 | KitchenAid Microwave Ovens
Kitchenaid microwave open door switch does not work
on my microwave, the door sticks some times & I put my fingers under door on latch side & push up, & I can hear it release & open. other than that there may be a broken part. follow the link below.
KitchenAid Microwave Door Won Open
Jan 23, 2015 | KitchenAid Microwave Ovens
Why won't my interior microwave light turn off and my microwave won't start?
It sounds to me that your door switches aren't working.Your oven is protected by a couple of switches that engage when you open or close the door.They control a couple of safety features and also your interior light.One of them seems defective.
Dec 17, 2014 | KitchenAid Microwave Ovens
I have a Kitchenaid microwave model KCMS145JSS-0. It is no longer heating. What can I do to repair it?
Check the door safety interlock safety switches for proper operation. You will find them inside the cabinet.
If they have failed, the oven thinks the door is open and therefore will not turn on the heat. This is the most common reason for failure.
May 30, 2011 | Microwave Ovens
Model KHMS155RSS microwave is not heating food after the maid service cleaned the microwave
Hello, does microwave have power? Plugged in etc, lights working on front? All microwaves have a safety backup, the door may press onto a latch which will allow the microwave to work, this is to ensure that if you open the door during cooking, it will stop immediately so you're not exposed to microwave radiation. Maid may have disrupted the mechanism for this purpose, make sure door latches are OK, and door closes smoothly, also try unplugging and then plug it in and turn it back on. Hope this may help..
May 22, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
When I open the door to the microwave there is no light. The key pad still works until I hit start and then the pad says "door". I can not get it to turn on. Any suggestions.
It sounds like the door interlock is broken.
Have a look for any hooks or latches that may have snapped.
If the door interlock is faulty - do not use this microwave untill a replacement is ordered and fitted.
Aug 28, 2009 | KitchenAid Microwave Convection Oven
Kitchenaid microwave (builtin) door jammed
I believe the only way of gaining access to the door latch assembly is by removing the cover. You can use needle nose pliers to grip the sides of the screws to slowly turn them out. You might want to visit this web site www.applianceaid.com enter your model number then scroll down until you see an exploded view of your model. Click to enlarge the diagram of your model exposing the latch assembly. I hope this is of help to you. If you found any of these suggestions helpful, please rate my solution. D. Lange
Apr 11, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
KitchenAid KBHC109J Convection/Microwave Oven Logo
71 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Stu Ungar
Darial Jr Lasaria
Darial Jr Lasaria
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
