Question about Philips 50PF9966 50 in. HDTV-Ready Plasma Television
PHILIPS DVI CONNECTION TO PS3 FLICKER
PS3 HDMI TO DVI FLICKERS WHEN SWITCHED ON PS3 MENU BUT WORKS FINE WHEN THE ACTUAL GAME LOADS
5 Suggested Answers
SOURCE: Small flickering green line on my lcd screen.
I had the same problem, and I just updated the tv's drivers to the new 1.15 version. I don't see the green anymore.
Posted on Mar 20, 2009
  • 90 Answers
SOURCE: philips 42" HDMI connection to VGA on laptop connection problems
why dont u just use the vga input and select vga from your input selection. it should work just fine. if not, email me back.
Posted on May 25, 2009
SOURCE: My Philips 42PFL3603D/27 that does not connect to hdmi device.
At the rear or side of the PC there should be either or both of a 15 Pin DIN Plug, HDMI socket. or a Yellow RCA or 4 -7 pin DIN. Now IF these are present then YES you can connect to a TV. Now some TV's have a connector a DB15 MALE, so that the cable from the PC to the TV, is DB15. this plugs in directly, with appropriate DB15 cable. This, however, will ONLY take the VIDEO to the TV, Audio is delivered via the "Audio Out" Jack on PC, and Plugged into the AV Sockets on the TV, with a dual cored coaxial cable, they are Red & White. Some PC's also have a Yellow RCA Connector, OR a 4 -7 Pin DIN Socket, that requires a Special Adapter Cable (That generally came with the unit, and are colored and marked as to output) to use, for Video/Audio Out to TV. This signal is Composite or SVHS Video & Stereo Out. This connects up TO the TV's Composite/SVHS input Jacks and the Red & White Audio IN, RCA Jacks, &/or DIN SVHS socket.
First you need to know if your PC can output to a TV. Then you need to get the adapter & cables that connect the PC to the TV. Then you need the correct TV drivers installed for your video card. When they are all installed, you need to "Enable" that Monitors, the TV's, Desktop. You need to set either a "Cloned" display or "Spanned, Extended Desktop". Go to "Display Settings" Now ensure the TV/Monitor connected has the correct input/output display settings. Adjust the screens resolution via the resoloution "Slider", it is best to start with, 800x600 32 bit color. or even lower. and once working OK, THEN increase to max resolution, your TV can handle, find out from manual. Once it is all connected up. It should all just work great. Now, from then on, &, to get it to work every-time, the process is. Turn everything OFF. Connect the leads between PC & TV, Turn the TV, ON. Then, startup the PC up. It should "Detect" that it has TWO "Monitors" ie: One Monitor & One TV/Monitor, & you should see your desktop appear after a bit. Now you have screen 1 & screens 2. Now, if you are using "Cloned" mode, then whatever is displayed on the Master monitor, will be displayed on the TV. If you used Spanned, mode, in this mode, however, you will have to."Drag" the Video window, over to the TV, and it is though, you have one "Big Desktop". Now IF using Nvidia or ATI then BOTH of those have thier OWN, Control Panel, this, all then can make it all a lot easier to do it. So I would suggest that this method be used. But if you get stuck, or just want to do it by hand, then the the "By Hand" method is the only way.There is a great program called MultiMon, this allows great control over dual displays, and is well worth installing.
Posted on Mar 10, 2010
Testimonial: "While my problem did not get solved, he helped me as much as he could. Thanks!"
  • 10 Answers
SOURCE: Philips LCD TV "47, model PFL 8404H/12, NO SIGNAL on all 4 HDMI
This is quite tricky as it was working until last night and suddenly stopped receiving signals. What can happen wrong?
Do you have any other Player or other HDMI cables to try out. Sometimes the cables would be damaged or PC may fail to detect the HDMI.
Try this out from Philips helpdesk where there is new SW and FAQs are available.
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=42PFL8404H/12&slg=en&scy=CZ
Let me know if you are not able to upgrade the FW (if you do not get the support on ugprading)
Posted on May 11, 2010
Ps3 old school tv flickering
Just get a newer tv. The tv you have is just getting old and if you get a newer flatscreen tv with an hdmi cable, you wont be dealing with the flickering.
May 04, 2013 | Video Game Consoles & Games
I have a Pioneer PDP-R05FE 43'' TV. When I connect my PS3 to show Blue Ray films I get a flicker in the picture. It is connected using a good quality HDMI cable. There is no flicker when playing SD films...
go into your dispay menu and adjust the response 50-60hrz or if your tv is capped at 1080i then drop the ps3 to 720p and that will smooth it out alittle too as the interlaced picture is alittle choppy apposed to progressive picures and finally sometimes they just do it no rhyme or reason to it so dont go crazy about this ok :)
Jan 01, 2011 | Sony Playstation 3 (PS3) Console
I have the same problem with my Samsung LE46A656 A1F Full HD
If it was doing it on your old console then its the TV not the PS3.
Causes: HDMI cable (Replace cable), HDMI socket on TV (Get it repaired), If it happens on all HDMI inputs then the video board maybe faulty, Interference - location of PS3 to other equipment.
The first thing to do is move everything else away from your TV except for the PS3, now factory reset the Samsung TV and make sure your firmware is up to date my records show that an update came out in May for your TV, also factory reset the PS3 and setup the HDMI video settings using the wizrad in the PS3, now connect the PS3 through all HDMI inputs to see if its one input or all, if all inputs are the same then the TV maybe faulty.
Let me know how you get on.
Thanks
Sep 05, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3 Flickers when set to 1080P on 32LG70
This may help... open Display settings, scroll down to the Deep Color option... switch it from automatic to off. So far this is the only solution that I have found
Jul 30, 2009 | Sony Playstation 3 (PS3) Console
PS3 does not work in 1080p
My ps3 didn't like a HDMI connection very much. I tried the Composite input cables and they worked great with no screen flicker.
-Captain Jake
Feb 13, 2009 | Sony Playstation 3 (PS3) Console
Screen flicker when selecting Blu-Ray player w/ HDMI-1 selected.
Something to remember is that most HDMI setups on TV's have what is called a DVI/HDMI port, I would suggest not using anything on that port that isnot converted from DVI to HDMI. I bet if you look, that HDMI 1 on yours....
Feb 10, 2009 | Mitsubishi WD-60735 Projection Television
Ps3 won't display on hdtv via dvi
Re-Set the PS-3, by pressing and holding down the power button (front panel) this hard re-sets the unit and yo can then reconfigure via the composite video cable it came with, back to HDMI / DVI
Dec 17, 2008 | Sony Playstation 3 (PS3) Console
It sucks to see ALLLLLLL these solutions, when I have the solution. Turn off DEEP COLOR in the video settings. It will immediately stop. If it doesn't, then you don't have the typical snow/flickering problem.
Oct 02, 2008 | Sony Playstation 3 (PS3) Console
PS3 - Screen Flicker
You need to try a new HDMI cable.. Cheap HDMI cables do that? I had the same thing happen to me... I switched the HDMI cable and it fixed mine.
AV
Jan 14, 2008 | Sony Playstation 3 (PS3) Console
Philips 50PF9966 50 in. HDTV-Ready Plasma Television Logo
42 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
