Question about Water Heaters
Is there an exploded view diagram of worcester 24i boiler
Try www.heatingspareparts.com - they've got thousands, and the registration for viewing's free as well.
Posted on Oct 28, 2012
  • 234 Answers
SOURCE: worcester boiler 2 years old keeps loosing pressure
http://www.worcesterbosch.com/Go there see if you can get some help.
Posted on Mar 19, 2009
  • 234 Answers
SOURCE: wiring diagram worcester 24i junior
http://www.worcesterbosch.com/ gothere and see iu get help for what you want.
SOURCE: Worcester combi boiler losing pressure & water through o/flow
having the same problem and its a new bolier. thanks , adriano.
Posted on Jul 12, 2009
  • 150 Answers
SOURCE: worcester 24i combi when in shower hot water
This is lack of water flow through the diverter valve.
First have you got a good flow from any cold tap? If yes then see below
If I remember there is a pipe carrying cold mains crossing the lower front of the boiler with an in line filter usually clogged. Remove clean & replace
check also any filter in rising mains to boiler
another cause is the diverter valve itself - diaphram inside may be punctured/split
Posted on Sep 02, 2009
  • 150 Answers
SOURCE: flashing red light on Worcester 24i junior combi boiler
Pressure is ok? at 1 bar or above
I think on this one there should be a reset button [red] on the left hand top of the casing - or lower the control panel [ phillips screw on each side] and the button is on the left of the base plate. Press this and try the heating.or hot tap
P.S. if you're on a prepayment meter check you have gas.
Posted on Nov 08, 2009
Testimonial: "Thank you, very helpful advice. Still got the plumber coming to check everything over but the boiler is up and running for now. Thank you so much"
Hi I have a 24i worcester boiler I have drained the heating to do some work but I need the hot water to still work.I spoke to Bosch and they said I need to put a loop in.I am not a plumber but can get
Hi Steve, I am not a plumber but have done a lot of DIY on my own heating system with Worcester Bosch combi boiler! I believe that you can have the hot water on without the heating system filled, just turn all the settings as for summer use and the thermostat right down so the heating is forced to stay off!
Nov 07, 2014 | Water Heaters
Hello, I have a Worcester 24i boiler and the heating is working fine but the hot water will only stay hot for about a minute at a time in the kitchen sink, the shower is ok but only when the heating is on....
http://homeguides.sfgate.com/flush-out-tankless-hot-water-heater-53060.html
The link is to how to flush a tankless system.
This should be done once a year.
https://www.manualslib.com/manual/554372/Worcester-24i-Rsf.html?page=2#manual
This link is to the manual on the unit.
On my unit, it the hot water is running slow the unit turns off and the hot water goes cold, so for me its run the water on full.
Dec 21, 2017 | Water Heaters
Flashing red light on Worcester 24i junior combi boiler
Nov 08, 2009 | Water Heaters
Hi where can i find a manual for a worchester greenstar 24i junior boiler please
if you go on the worcester bosch web site and contact the service dept they should send one out to you or you may be able to download one from there.
Mar 27, 2009 | Water Heaters
Water Heaters Logo
78 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
