Question about Janome Sewing Machines
My Janome 6019 has just started sewing backwards. Could the reverse butten be stuck inside?
I started sewing this morning and for no reason it will only sew in reverse. Help?
SOURCE: Stuck in reverse
The reverse button is attached to link that moves a lever to make the machine sew in reverse. The lever is spring loaded so it returns to forward sewing when the button is released. Either the spring has come off or there is a bind in the lever(oil it). In order to solve the problem, the covers must be removed.
Posted on Oct 27, 2007
  • 82 Answers
SOURCE: sewing backwards
Yes, this is a problem that a trained Viking repairman needs to resolve. It might need to have the zero feed position adjusted.
Posted on Jan 20, 2008
bilabon
  • 46 Answers
SOURCE: Machine sews only in reverse
Be sure you are in the correct stitch pattern...if you are on a buttonhole stitch or a stretch stitch it normal for the machine to sew backwards. Be sure your length is to the right of 0 and not in a strtch stitch model or buttonhole mode.
Bonnie
Posted on Jul 29, 2008
  • 46 Answers
SOURCE: Backward sewing machine
that sounds like the button is stuck. You may need to get it looked at.
Posted on Oct 24, 2008
SOURCE: Janome Excel 5124 reverse lever
If you pull the bottom off the machine (half a dozen screws) there is a cam on the main drive shaft. The cam is probably jammed in the reverse position due to lack of lubrication on the shaft. You can move the cam back manually and it will operate in forward direction. It appears that the shaft needs lubrication.
Posted on May 02, 2009
How do I sew a buttonhole on Janome 6019
most likely by setting the machine to that function ..rereading the instruction manual would be my first option .
Jul 31, 2015 | Janome 6019QC Mechanical Sewing Machine
Why is my janome jr1012 stuck in reverse
Yo need a tech for this, as something inside is jammed.
Jan 13, 2015 | Janome Sewing Machines
Why is my Janome Mystyle 20 stuck on reverse?
It may be in the buttonhole mode, change the stitch selector to straight stitch.
Jul 16, 2014 | Janome Sewing Machines
My friend bought jenome sewing machine. It is working very well except that it only sew in reverse (backwards). Could it be that the reverse button got stuck or is there a setting that needs to be done?
button in centre of stitch length control is probably gummed up and stuck lubricate with penetrating oil and wind stich control backwards and forwards to see if centre knob starts to move. Remove arm top cover and do same to mechanism visible from above
Feb 19, 2014 | Janome Sewing Machines
How do i change the lightbulb on my Janome 6019 sewing machine?
On most sewing machines the light bulb is located inside the faceplate on the left hand side of your machine.
http://www.janome.com/documents/File/ManualFile/6019QC.pdf
The faceplate is part number 17 in this manual.
One that has been removed, the bulb should be visible. You will need to look at the old bulb to see if it a screw type or a bayonet type, in order to replace it with a new one.
If this is not correct try the Janome website for advice, they have a forum and an ask Jan section for problems etc.
http://www.janome.com/index.cfm/LearningCenter/AskJan
http://www.janome.com/fusetalk/forum/
I hope this is helpful to you!
Sep 17, 2010 | Janome 6019QC Mechanical Sewing Machine
Janome machine going backwards instead of forwards. Goes forward if I hold the reverse button down.
sounds like a screw may have become missing to keep the reverse knob in its proper position so it is backwards inside the machine
Dec 13, 2009 | New Home MX-3123 Computerized Sewing...
I own a Sears Kenmore machine that began sewing backwards
Make sure that the reverse button isn't stuck inside. if all else fails, go back to sears and have them look at it.
Jul 02, 2009 | Brother XR-65t Mechanical Sewing Machine
Oct 23, 2008 | Janome D'cor Excel 5018
I have a Janome 8080 that is out of warranty by a month and days. I went to use it and my handwheel will not let me move it backwards. It is not giving me a code that anything is wrong. I can't reach...
You should always move the handwheel forward. On some machines moving it backwards can throw off the timing. Try reverse and doing a couple of stitches to test.
Apr 12, 2008 | Janome 8080 Computerized Sewing Machine
Sewing Machines Logo
21 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
