Question about Sony PlayStation 2 (PS2) Console
Ps2 scph 77001 won't play backups on swap magic 3.6
I've been having problems booting my back up games through swap magic 3.6 dvd disc i use to own 2 other ps2's that i used the same disc on but with this ps2 they won't seem to boot swap magic loads fine but when i switch disc and put in the back game and press x it doesn't do anything ive tryed lots of my backups and get the same thing please help hope this is minor prob got alot of backups
  • nightwish08 Oct 31, 2008
    thanks you were right on the money lol should've known lol
  • Don Joe Apr 20, 2009
    ps2 scph 50004 won't play backups on swap magic 3.6 - seems like it only loads 1 copy a week... if not at all. swap magic dvd loads fine, insert bigger toc fine, insert own program disc press x to load, then browser pops up showing memory card and by then i know i've got no hope. please help because i'm now considering getting my ps2 chipped, which would mean the swap magic was a complete waste of cash. please tell me there's a solution
    Scholar:
  • 64 Answers
This is a problem that has too many IF's in it lol. Let's take it from the top shall we?
When you said that you owned other PS2's were they the thick ones or the slim ones. Swap magic works best in the "thick older" models. In these new slimline ones it's got issues. That model number you posted belongs to a slimline model.
So since you're using a slimline model, I have to ask, Have you blocked the 2 sensors that you need to block in order to use swap magic. The slimline models are not like the older thick models. You need to block two sensors under the flip top so when you open the flip top the PS2 still thinks there is no swapping going on. If you have not blocked these sensors head over to youtube.com and start watchin vids with seach "how to block slim PS2 sensors" or "how to block slimline PS2 sensors" out of the three sensors you only really need to block two. If you have not done this at all, that is reason why it's not working. On older PS2 models you used a slidecard or some form of a flip top to swap out your disks. Nothing has changed on these slimline models. The PS2 still needs to be tricked out so it doesn't think you're swapping disks in and outa the system.
Hope that helps,
9x|
Posted on Oct 29, 2008
Swap Magic Problems
TOC disk error normaly occurs when tool 1 of the set that goes in the small square hole at the front left of the drive bay above the power switch is missing or installed wrong
have a look at this
http://www.mod-chip.com/Lite/Magic_Key_2_PS2_Install_Lite.pdf
Apr 24, 2008 | Sony PlayStation 2 Slimline Console
Tip
Make a SONY PS2 multiregion with SCPH 1000 firmware.
NOTE: this will only work on the earlier models with the SCPH 1000 bios 22/9/2004
1. Press and hold Circle , Right and L1
2. Press and hold L3 and push the stick hard
3. Boot into the PS2 browser without a CD/DVD in the tray
4. Press circle and R1 on the DVD
5. Hold right until an menu appears
6. Press circle and R1 again.
If this fails try this
1. Load the DVD into the PS2 that you want to play.
2. At the browser screen select the CD icon press and hold circle and square until the DVD menu appears.
3. Either select the movie select icon or the play icon.
If these two fail you will need a Messiah chip OR magic chip 2 installed
on Dec 14, 2009 | Video Game Consoles & Games
I have a silver slim ps2 model number SCPH-77001. Everytime I play a ps1 game on it (which it has no problems with) it wont read my ps1 memory card. I've tried it on both slots, tried 4-5 other ps1...
You shouldnt have too. I think I know the problem. Turn on your ps2 without a game in it and it would take you to the home screen. After that go to browser with your ps1 memory card and select it. And then it should give you an option to format it. Hope this helps
Dec 06, 2012 | Video Game Consoles & Games
I want to play duplicate dvds on my ps2 but i am not able to do what should i do can i do it at home
  1. If you have backed up a game for ps2, you're going to need a mod chip or swap magic for your ps2 so it can read the disc, so first things first, BUY A MODIFICATION TOOL!!!
  2. 2You should try using Swap Magic, because it's the easiest, and you won't need to modify your PlayStation too much.
  3. 3But if you use SWAP MAGIC, you will also need a special mod chip, SLIDE TOOL, or a FLIP TOP COVER, you can learn more about those on the swapmagic website
  4. 4Read directions on the installation of mod chip, and swap magic before you do anything (you don't want to mess up, or else your ps2 won't work properly).
  5. 5Install your modchip/flip top cover/slide tool. (This is important, because it allows the disc to be removed and "swapped" without the PlayStation knowing).
  6. 6Follow directions that came with your swap magic discs, and you're basically ready to go!
  7. 7HOW TO USE SWAP MAGIC,Note you must have Swap magic 3.6 to boot on slimline ps2 and you need to do a none solder modding(no soldering)
Purchase a flip top (recommended). Let's assume you have the flip top and a copied ps2 game
  1. 1Now Insert the swap magic disc into the ps2,
  2. 2Press power on button until screens comes up.
    • With option that says load cd open the top cover of the flip top.
    • And take out the cd when it stops spinning.
  3. 3Now insert your Copied game and click Load CD.
  4. 4its that easy
May 30, 2011 | Video Game Consoles & Games
Playstation 2 won't play DVDs
if it's a fat PS2 and
model SCPH 30001, SCPH 35001
(not including the models with an 'R' after the model #.
these models need the following to play DVDs:
- PS2 DVD remote with IR unit
- PS2 DVD disc player (sold with DVD remote w/ IR unit)
- PS2 memory card
you copied the DVD disc to the memory card. you used the memory card to play DVDs.
later models didn't need the memory card to play DVDs.
hope this helps :D
Jul 16, 2009 | Sony PlayStation 2 (PS2) Console
FAT PS2 with Flip Top and Swap Magic 3.6 not loading backups
1. when you're burning your dvds, burn at the lowest speed possible, and use high quality media like sony
2. clean your lens
3. if that doesn't work, clean out the whole ps2
i use swap magic on the same model ps2, and occasionally get this message on lower quality media
Jan 14, 2009 | Sony PlayStation 2 (PS2) Console
Disc reads "There is no data"
For one nobody plays this game any more
I don't know how to fix it sorry''''''''''!!!!!!!!!!!!!!!!!!!
lol Ha Ha Very funny
Nov 10, 2008 | Sony PlayStation 2 (PS2) Console
Ps1 games
your slimline might not normally play the games Use swap magic it should have two discs one for booting PS2 games and one for booting PS1 games you simply put the appropriate swap magic disc and then the game you want to play
http://www.swapmagic3.com
This is what it states under What games support Swap Magic 3?
Swap Magic 3 support almost all SEGA ROMS, SNES ROMS, PS1 & PS2 Games!!
Feb 23, 2008 | Sony PlayStation 2 Slimline Console
Sony PlayStation 2 (PS2) Console Logo
1,705 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
