Question about Philips HTS3400/37 System
Philips HTS3400/3 I need to replace the main box, where can I find one?
  • 8,596 Answers
Fox International sells the speaker casings. The plastic casing for the main unit would have to be procured by buying a broken HTS3400 off of eBay/other online seller, and replacing from there. Myauctionsonline was once selling a broken one for about $30 including shipping.
-Tha Mp3 Doctor
Posted on Dec 29, 2008
Philips 42pfl7432d/37 power light comes on but nothing else
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sep 02, 2016 | Philips Televison & Video
Philips TV while watching all of a sudden the picture disappears but still it sounds. Restart the TV and the setup box change the HDMI port but no result. Some have any idea what could be the reason.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Aug 28, 2016 | Philips Televison & Video
Need help fixing Philips LCD TV screen that is dark on one side and flickering.
Jun 29, 2016 | Philips Televison & Video
I have philips 39pfl5708/f7 model. Week ago same dark spot apear ob bottum left corner . now tv is total dark. No image at all. Any help
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
May 14, 2016 | Philips Televison & Video
Philips TV freezes or turns on/off continuously
please check on mains chord and plug or even better the plug itself by connecting another lamp to see it flickers meaning something wrong with the AC line in.
1.either replace mains power chord
2. also see solder connections inside TV that is if you know something about mains take care to switch of mains and disconnecting main chord
happy hunting
Sep 12, 2015 | Philips Televison & Video
Why is Philips Boombox not working from mains without batteries?
When you plug a cord into a two pin connector that I assume is on the side of the box, it should disconnect the batteries inside. If taking the batteries out kills the power completely with the cord still attached, then the switch on the power socket in the unit is NOT connecting the built-in power supply.
Feb 15, 2015 | Philips CD Soundmachine Portable AM/FM...
Philips LX8500W rear wireless speakers don't get enough signal and they are not working properly.
if there wireless you need to make sure the two signal strengths are connecting to each other for that there is a testing kit you can get but its very expansive. If these are new and you installed these your self check your main raido and make sure all wires are hooked up properly, it could be the main box giving an issue with the signal.
Nov 26, 2014 | Philips Home Cinema system DivX LX8500...
I have a Philips 47
The boards are different in sets even with the same basic model number- you would also need to check all voltages to board from power supply--PHILIPS HAD DIFFERENT BOARDS IN SETS WITH SAME MODEL NUMBER----POSSIBLE voltage needs to be adjusted or settings in service mode need to be adjusted.
Mar 10, 2012 | Philips Televison & Video
Batteries for HQ 7390
RAZOR replacement battery 2000mAh for men electric shaver philips hq 7390 replacement parts.
Jan 22, 2012 | Philips HQ7390/17 Williams F1 Mains...
We have purchased a Phillips freeview box but am unable to get a signal !! We have the tv arial plugged into the back of the freeview box into the tv and the scart connected from freeview to tv. Do we...
Yes
If the Freeview box is not connected to the main aerial socket, you cannot get a signal.
Also, you will need a digital aerial, if you don't already have one.
Jun 09, 2008 | Philips Televison & Video
Philips HTS3400/37 System Logo
160 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
