Question about Vacuums
Replace rubber gasket on Hoover Nano Cyclonic Compact Bagless Upright Vacuum
Took apart to clean & dont remember correct way to replace rubber gasket ontop of dustcup
  • 72 Answers
SOURCE: Emptying cylinder
I hope you've found out by now, but, in case you haven't, the latch to remove the canister is right by the handle on top of it, just don't lift until you release the latch with your thumb, it's got a safety to keep you from hitting the release when you're using that handle to carry the vacuum.  (good engineering).
you can download a manual from the dyson site, here:
http://www.dyson.com/customercare/manuals/us/dc07_opmanual_usa.pdf
Posted on Oct 20, 2007
  • 389 Answers
SOURCE: I have a Dyson DC17 Animal Bagless Upright
OK. Lost suction almost always means blockage. You need to check all the pipework, the hose and any bits you can remove at the base of the machine - if I remember right, the DC17 has a sort of U shaped bend at the bottom of the handle that you can remove - also turn it over and inspect the clear flexible plastic tube (if it's not blocked, it can get damaged and leak). As for filters, you do of course need regularly to wash the filter that's above the cannister (wash both the blue sponge and the yellow carrier) and be sure they are dried gently for at least 12 hours before putting them back.  If you need new filters, any vacuum service shop should be able to supply them. I hope this helps. I value your feedback so please remember to rate my response.  Good luck!
Posted on Feb 25, 2009
  • 197 Answers
SOURCE: Hoove Cyclonic Bagless vacuum shuts off after only a few minutes
The motor has a protective overload cutout device to stop it from over heating - this can be caused by a blockage of some sort in the hose or brushroll compartment or blocked filters.
After checking the above and it still cuts out, take it back under gurantee
Posted on Sep 20, 2009
Vac Belts
  • 701 Answers
SOURCE: Hoover U5780-900 Windtunnel Cyclonic Bagless
You probably need to change the belts. Here are the belts you need and the manual:
Hoover 5780-900 Belts
Manual
Posted on Dec 23, 2009
Testimonial: "Replaced the belts-- works GREAT!!! Thanks"
  • 33 Answers
SOURCE: Noisey DC07 Bagless Upright Cyclonic Vacuum; lack of suction...
The washable filters very seldom wear out, they are sponge, but the prefilter on the housing CERTAINLY wears out. You can fix it here:
http://www.ehow.com/how_5870417_modify-dyson-prefilter-suction.html
Posted on Jan 26, 2010
Hoover nano cyclonic shut off while in use/no suction when turned back on
That is more than likely the problem, NEVER put wet or even damp filters back into your vac
Oct 23, 2014 | Hoover Nano Cyclonic Compact Bagless...
Why does it shut off after 10 minutes?
Hi Will! It appears your thermal protector sensor has kicked in and caused your cleaner to power off. This is usually due to a clog or a filter that needs to be cleaned or replaced. Try these steps to get your vacuum back up & running!
1. Remove the dirt cup canister from the vacuum. Twist off the dirt cup lid.
2. Remove the primary foam filter. Hold filter under running water until water runs clear. Allow 24 hours to air dry. If the filter is really dirty it may need to be replaced.
3. Slide the Hepa filter out. Tap the filter against the trash can until dirt stops falling. Replace the Hepa filter. (Do not wash)
4. Remove the hose from both ends. Use a broom stick to gently loosen and clear any clogs from hose.
5. Use a wooden spoon or something similar to loosen and remove any clogs from the lower hose.
Your vacuum should turn back on after it cools off, this can take up to an hour. Hope this helps!
Jul 27, 2014 | Hoover Nano Cyclonic Compact Bagless...
Belt is strech doese not pick up diert
Hi! The brushes are needed to spin on carpet to agitate the carpet fibers and assist the motor with maximum pick up. If the belt is stretched you will need to replace it. This unit takes belt 562633001. Below are step-by-step instructions for replacing the belt on your Nano.
1. Lay the cleaner flat and flip it to expose the
nozzle base. The base should lay flat and face up.
Remove the five (5) screws.
2. Pull and lift the nozzle guard off.
3. Lift and remove the brushroll. Dispose of the
old belt.
4. Slide belt onto motorshaft.
5. Place new belt in area of brushroll without
bristles.
6. With new belt in place, pull and slide brushroll
into nozzle making sure that the brushroll end caps
are in the correct orientation. Rotate brushroll
manually to make sure belt is properly aligned.
7. Reattach nozzle guard.
8. Secure by aligning the three tabs in the
base slots.
9. Replace all five screws to secure nozzle guard.
Follow the link to order a replacement belt for your vacuum. Flat Belt Nano Upright
Hope this helps!
Mar 04, 2014 | Hoover Nano Cyclonic Compact Bagless...
Hoover Platinum Cyclonic Bagless Upright Vacuum, UH70015 squealing sound
have you checked the belt for the brushbar it may av stretched and needs replaceing here is the manual on link below
http://hoover.com/file/556/
Feb 16, 2013 | Hoover U5780-900 Windtunnel Cyclonic...
I am trying to find out a part number for a rubber gasket that goes on the inside of a Hoover Windtunnel Cyclonic Platinum BAgless upright. It is a very thin, light-weight gasket made of rubber that helps...
Hi There,
I'm not sure exactly which part you are asking about, so I went ahead and uploaded the parts schematic of your vacuum cleaner, that will diagram all the parts, and part numbers.
If you need to purchase this gasket, please feel free to contact me, and I'll be more then happy to ship this directly to you for free.
Here's the Part Schematic:
Parts Diagram & Schematic For The Hoover Platinum Collection Bagless Upright Model UH70015
I hope this helped you. I look forward to hearing from, and if you have any follow up questions, please feel free use the comment field here on Fixya. If this was helpful, please be so kind and rate the repair, or leave feedback for me. This is greatly appreciated by the Fixya community when you are able to solve your problem.
Thanks again,
Chris Jones
http://www.govacuum.com
May 14, 2010 | Hoover UH70015 Bagless Upright Cyclonic...
Windtunnel quits picking up
clean or replace the main filter. this filter is non washable. the best way to clean is to use a paint brush or compressed air. hope this helps
Jul 25, 2009 | Hoover U8147-900 WindTunnel V2 Bagless...
Vacuums Logo
112 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
