Question about Ricoh 4430NF Laser Fax
How to configure ip on ricoh fax 4430 nf - Ricoh 4430NF Laser Fax
2 Suggested Answers
  • 398 Answers
SOURCE: Ricoh 5510L Network Setup
Go to user tools-key op tools-network-tcp ip- ip address put the appropiate info in.(including gateway address.) then type the ip address into the top portion of a web browser an you should be in web image monitor. you configure the printer there. User name is admin no password. -Carl
Posted on Jul 08, 2009
How do i set up ricoh mp201on wireless network
you will need to plug in to wired network, disable dhcp and configure a ip address within your router range, then make a note of ip, reserve ip in router, removed wired connection and test on wireless.
Thats is all done.
Nov 01, 2013 | Ricoh Aficio CL1000N Printer
I am unable to install hp laserjet M2727 nf MFP in the network. i don't know how to install it on the network? please suggest me the steps .
Hi
This is very easy setup to install the network printer. first to set the your desire network IP address in your printer.follow the mention option enter the Ip address.
  1. Press the Menu button.
  2. Press the Down Arrow to find Configure Device .
  3. Choose Configure Device .
  4. Press the check mark button.
  5. Choose I/O .
  6. Press the check mark button.
  7. Press the EIO (1 or 2) Jetdirect Menu .
  8. Press the check mark button.
  9. Choose TCP/IP .
  10. Press the check mark button.
  11. Choose Configuration Method .
  12. Press the check mark button.
  13. Choose Manual .
  14. Press the check mark button.
  15. Select Manual Settings .
  16. Choose IP address .
  17. Press the check mark button.
  18. Enter IP address with keypad.
  19. Press the check mark button.
  20. Choose Subnet Mask .
  21. Press the check mark button.
  22. Enter Subnet Mask with keypad.
After assign the IP addres in printer. connect to your printer with router or switch. and insert you HP Installation CD in Rom,
Go to the Control Panel and select Printer and Faxes click the "Add Printer"the new Add printer wizard open click next and remove the check mark in " Automatic detect and install the Plug and Play printer" click next, then you get "Select the printer port screen" Click create New port and choose Standard TCP/IP and click next.
You will get another New windows " Standard TCP/IP Add Printer Port" click next and put the Printer IP Address click next and next, Finish.
Now the windows will appear " Add Printer Wizard" click the Have Disk " and choose the .Inf file for your Installation CD, and Click Finish.
Your printer will install and the test will come.
If my solution solve you problem then give me four thumb
Cheer
Jul 12, 2011 | HP Laserjet M2727nf Multifunction Printer
Hi Guys I hae set up IP address and other network related setting. I can't ping to the printer. Not able to get automatic IP address from the DHCP no ping.
Every network printer or print server has a unique IP address associated with it. This address is either configured manually or set using an automatic network protocol such as the boot protocol, reverse address resolution protocol or zeroconf. You can normally find the IP address of a printer on the printer's control panel or by printing the configuration page. Select the printers and faxes tab from the control panel. Right click on the printer those you want to find the IP address and click properties. Then click on the ports tab to display the IP address of your printer.
Nov 25, 2010 | Ricoh Aficio 1515MF All-In-One Laser...
How do I setup/program email addresses in browser to scan to those email addresses?
I found the IP address of the printer, pulled it up in a web browser and went in under administrator mode to configurations then under destination put in the email address for the speed dial.
Jan 19, 2010 | Ricoh FAX5000L Plain Paper Laser
Jul 07, 2009 | Ricoh FAX5000L Plain Paper Laser
Hi! i m using ricoh aficio 3224c as printer n scanner (smb) for my lan, its good, no problems. but when i configure it on the wireless network its not accessing the destination n shows "waiting" in...
The wireless network (router) has a different IP address, than your 'hard-wired" connection, so the destinations will need to be re-programmed to match the new IP address of your server (or individual workstations), depending on how it was set up.
May 03, 2009 | Office Equipment & Supplies
Ricoh FAX5000L - Check: Network Error! [10-40]
Usually this means it was previous;y hooked up to a network, or the network settings have changed and they are mismatched. Do you use it as a printer? If not, in the user settings, (I'm not exactly sure where, but you can download a manual at ricoh.com) just set all the network settings to 0's - for example Ip address, gateway, etc. Otherwise set them correctly in order to print.
Feb 03, 2009 | Ricoh FAX5000L Plain Paper Laser
Ricoh 2050L
1.put the document for sending on the place
2.dial number
3.if you sending to a direct fax press start or send
and all is ok
Feb 06, 2008 | Office Equipment & Supplies
Configuration of LAN fax
The best solution I use is Smart Net Monitor, which is supplied with the Ricoh disks or can be downloaded from www.ricoh-usa.com . First you need to install the lan fax driver, after that then install Smartnet Monitor.
From there click start, and then control panel, then printers and faxes, then right click on the Ricoh LAN fax driver, from there click properties, click ports, then click add a port, under available ports you will see smartnet port (highlite) and then select new port, a new box will come up and then select search, the software will then make the connection and add the port. Besure to click ok and apply and then you are connected
Oct 09, 2007 | Office Equipment & Supplies
Ricoh 4430NF Laser Fax Logo
717 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
