Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
No picture or sound.
Came in from work today & my Philips61" rear projection has no sound or picture. It was working fine this morning before I went to work. Please advise shonkhadley@bellsouth.net
  • shonkhadley Nov 02, 2008
    The television does have power to it, but no picture or sound. The RED led lights up when the power is on, however there is no picture. Now the screen has a red tint to it also. Any suggestions?
  • Philips Master
  • 5,568 Answers
In the absence of sound and video, I post the following suggestion:
If it just fails to turn on, the main power supply is probably at fault and without some technical background and a couple of test instruments, you will not be able to do the repair yourself.
What you can do though is; unplug the set, let it stand overnight or at least several hours, remove the back panel and look for a separate board with mostly larger components on it; it will have a ferrite core transformer on it and several larger capacitors which are cylindrical and mounted vertically to the board.
Before touching anything inside, especially on that board, allow several hours to be safe since the larger capacitors can hold a painful voltage charge for some hours.
If you see signs of overheating such as discoloration of the board material, it may not be repairable but if you can find a part number on the board, you might be able to buy the power supply and install it yourself.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
If you choose to replace or have it done, the power supply still may not be at fault since most are capable of switching on and off if a downstream problem is causing an overload.
Posted on Oct 31, 2008
  • Steve Allison
    Steve Allison Nov 02, 2008
    It may still be a power supply problem but the fact that you have some kind of light from the screen makes the problem more difficult to diagnose.
    All of our consumer stuff has supplies with multiple outputs and the output that services the chain of video and audio circuits could fail and still allow some kind of screen activity.
    Doing a search on the model number showed results that indicate that it is a problematic set that is showing a variety of problems, unfortunate since I kind of favor DLP sets.
    Repair is apparently not cheap since eBay currently has a listing including four of them with various problems for a price of $800 for the group of model 60PP9202;
    4 Philips DLP sets
I have a JVC model HD-52G886 tv. that loses sound.
Replace or have replaced the Audio board in the set----a lot of them fail.
Mar 12, 2012 | JVC HD-52G786 52" Rear Projection HDTV
My toshiba 57h93 worked fine this morning power went out
Ur DM power board is dead,must be replaced.Try this
website for the board.Tv repair World.com.
Oct 20, 2009 | Toshiba 57H93 57" Rear Projection HDTV
No sound, and no picture today. Everything was fine yesterday. 3 years old
is the tv a rear projection if so it the bulb you will need to replace it
May 30, 2009 | Panasonic Televison & Video
Sound works no picture
t.v sounds comes on picture not working can watch pip . sometimes when you turn the t.v the timer light in front flashes can u help
Jan 12, 2009 | Akai PT5492S 54" Rear Projection...
Sound but no picture
It's most probable that your lamp is busted, since the tv didn't went out completely. Replace the lamp and you'll be fine :)
Sep 01, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Mitsubishi 57" HDTV - has sound and timer light flashes
I had the same problem and my local repair guy soldered a defective sensor so that it goes around that problem. I also had to buy a new bulb. Now my picture is "cloudy" and the repairman has no idea why. I am waiting for them to call back on it.
Mar 20, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Trouble!!
sounds like a loose video cable. Check your connections
Mar 03, 2008 | Mitsubishi VS-60601 60" Rear Projection...
Mitsubishi WD-62327 no pix and no sound
First do the self diagnosis test, search threads here or go to www.ctechnicians.com
Dec 03, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Working fine next day red light on solid
Shorted hori output transistor and bad 1200pf 2k volt capacitor.
Sep 15, 2007 | Sony KP-53V80 53" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
