Question about Epson Stylus Office Equipment & Supplies
How to fix cd/dvd paper jam epson T60
Always cd/dvd paper jam
SOURCE: Fake paper jam
I had the very same problem unitl a moment ago!! I found some A4 card and forced it through the printer. I tried to print a document as usual, as the rollers (inside the printer) lifted, i pushed the card through in an attempt to clear any blockage which wasn't visible to me. It cleared the block and is now working perfectly again !! give it a go.
Posted on Aug 28, 2007
SOURCE: Epson AcuLaser CX11N ADF Paper Jam
Hy everybody... I have the same problem... tried to reset as told above but nothing happened.
When I try to use ADF I hear a little "click" inside it, without any paper advancing.
Any further suggestions?
I already bought last year a new adf due to a fatal error of the previous!
Posted on Apr 01, 2008
Ajkill
  • 2035 Answers
SOURCE: Always Paper Jam in Epson Stylus CX3500
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Nov 26, 2008
futureloginn
  • 734 Answers
SOURCE: Epson Aculaser C900 - Paper Jam Notice, but no Jam?
Step1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step
Turn off the printer.
Step
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step
5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step
6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step
7
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Step
8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step
9
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Posted on Dec 04, 2008
SOURCE: epson workforce 600. says it has paper jam but
FIXES FOR EPSON RX600 PAPER JAM
Posted on Jan 18, 2010
Printer epson t60 the red light are always transferring to sides
you need to reset waste ink pad counter by adjustment program for epson t50 t60 printers
Mar 27, 2015 | Epson STYLUS PHOTO T60 INKJET PRINTER
When doing two sided printing I always get a paper jam indication when none exists. Single sided is OK.
Likely a small peice of paper stuck in the rollers on the paper flipping side, or a bad sensor.
Dec 29, 2014 | Epson Artisan 837 All-in-one Wifi Inkjet...
Epson 810 printer
It seems you have Eprom malfunction there.
You can flash its Eprom with its new Eprom file or just replace its Eprom chip and everything will back as normal. This is a common problem for this printer especially L series.
This type of printer often showing paper jam while there is no a single paper in its tray and the paper's sensor still working fine.
Hope this will answer your question.
Sep 14, 2017 | Epson Artisan 810 All-in-One Color Inkjet...
Communication error 21000068 when resetting my epson t60
i want to resetter my epson stylus printer t60 ink pad counters
Mar 30, 2013 | Epson STYLUS PHOTO T60 INKJET PRINTER
Epson T60, Paper Loading Problem
Jumped through outside the tray? Plz, describe more clearly. Epson T60 is "best design" in paper feeder for A4 size printer. I have a lot.
Jan 23, 2013 | Epson STYLUS PHOTO T60 INKJET PRINTER
Paper jam or cd/dvd tray jam problem
all i did is put some alcohol on the white portion of the tray and wipe it w/ a tissue and walahhh... like magic :)
Oct 26, 2012 | Epson TM-T60 Printer
Epson t60 wont print on pvc id card
Change your driver to R290 instead of T60. Select your T60 as printer (with an R290 driver) when printing. That would take the CD margin off the PVC card your printing on.
Aug 17, 2012 | Epson TM-T60 Printer
Epson t60 paper thickness problem
See http://www.epson.co.in/epson_india/printers_and_all_in_ones/inkjet/product.page?product_name=Epson_Stylus_Photo_T60 for details and specifications of the Epson Stylus Photo T60 printer which includes a list of what paper types can be used with this printer though it does not give paper weight (in grams). . . .12_17_2011_4_38_44_pm.jpg
Dec 17, 2011 | Office Equipment & Supplies
Paper jam
From the reference manual for your Photo Printer
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=60202&prodoid=58654761
"Epson Stylus Photo R220 Series Printers"
The Paper Jams
Press the font29.gif paper button to eject the jammed paper. If the error does not clear, turn the printer off, open the printer cover and the CD/DVD guide. Remove all of the paper inside, including any torn pieces, then close the CD/DVD guide. Reload the paper, then press the font29.gif paper button to resume printing.
r_note.gif Note: r_space.gif If you cannot remove a foreign object easily by yourself, do not use force and do not disassemble the printer. Call Epson for assistance.
If your paper jams frequently, check the following:
  • The paper is smooth, not curled or wrinkled.
  • The paper is of high quality.
  • The printable side of the paper is face up in the sheet feeder.
  • The paper stack was fanned before loading.
  • The paper is not loaded above the triangular load-limit mark on the left edge guide.
  • The paper stack fits under the tabs inside the edge guides.
  • The number of sheets in the paper stack does not exceed the limit specified for that media.
Feb 13, 2011 | Epson STYLUS R230 InkJet Photo Printer
Paper jam
I can not print CD/DVD lable bacause it jam, how can I fixed?
Dec 18, 2007 | Epson Stylus RX580 InkJet Photo Printer
421 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
