Pioneer pdp-ro3u pops up E01 then shuts off - Televison & Video
  • mburcin Oct 28, 2008
    I have tried unplugging it and it still does it
    Brigadier General:
  • 6,966 Answers
Pls confirm if on your Pioneer Media Box PDPRO3U, aside from the E01 error:
  • media receiver light is red;
  • tv light is either green or flashing red.
Should this be the case, then possibilities are:
  • cable connection (component wires in correct order, green-y, blue-pb, and red-pr,);
  • cable box, incoming cable signal/connection;
  • Media Box:
  1. Try completely shutting the TV and components down, (off) taking the top off the media receiver and blowing all the dust away or preferably vacuum clean carefully, make sure the circuits are not loose. Do this very carefully, put it back and plug it in.
  2. (if out of warranty and) you are considering a DIY (do-it-yourself), pls check the set link wire’s from c/b to c/b front right inside media box. There are 12 wire’s in total 11 black 1 red, the red one brings the media box out of red standby to green on. More often, bad contacts This of course require familiarity with electronic components & circuitry, knowledge of safe working practices on electrically powered devices.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 28, 2008
  • Louie  Role
    Louie Role Oct 31, 2008
    Hi again,
    Any development(s)?
  • 728 Answers
You might need to update the software or reinstall the software from the software cd that came withit if one did. And make sure you don't have it on auto time off.
    Scholar:
  • 155 Answers
Reset the device by unpluging the device for somr minutes and then again replug and see if it works.
thanks.
  • fixexpert Oct 28, 2008
    The power supply in the media box looks faulty.dismantle the media box and remove the LARGE power supply board and check for dry solder joints. Sure enough, where the heatsink would be soldered onto the board the joints will in a bad way. It happens due to media boxes for V3 Pio's get very hot - all that expanding and contracting is likely to create dry solder joints. Taking the box apart shouldn't be a problem for anyone.just resolder the joints and (touch wood) it will be proper after that.
    do not have soldering knowledge calling a technician is a better option.but this is the problem.
    thanks.
I have an E01 error message what is it and how do I fix it
I have an E01 error message what is it and how do"tv pioneer pdp-503pe"
Nov 20, 2009 | Pioneer PureVision PDP-503HDE 50 in....
The media receiver shuts off and the plasma screen
Pioneer plasma pdp R03U shuts off and tv shows E01 or action freezes while soun dgoes on and then stops E01
Aug 19, 2009 | Televison & Video
No picture on Pioneer plasma
first of all check out the fuse that mostly get blowned out in this problems.if the fuse is perfect then it could be the faulty capacitor issue check out on the main board with the help of the multimeter and replace the faulty ones and it should work properly.
Dec 10, 2008 | Pioneer PureVision PDP-5030HD 50 in....
Loud pop and tv went off...
Here is a solution from the Pioneer web site:
http://www.pioneerelectronics.com/PUSA/Support/Important%3A+Updated+Information+Regarding+Free+Power+Supply+Replacement+for+Certain+Pioneer+Plasmas
Important: Updated Information Regarding Free Power Supply Replacement for Certain Pioneer Plasmas Pioneer is continuing to offer a free, in-home/office power supply replacement for certain of its second and third generation plasma models listed below for customers who experience a problem with the original power supply. If a model is not listed below, no power supply replacement is needed and no further action needs to be taken.
If you own or use a plasma listed below, please call our toll free hotline at 1-800-421-1404 to arrange a time to have your plasma's power supply upgraded at your residence or office at no charge.
Plasma Models (15 listed):
  • PDP-505HD
  • PDP-503PU
  • PDP-5030HD
  • PDP-5031HD
  • PDP-433PU
  • PDP-4300
  • PDP-4310
  • PDP-4330HD
  • PRO-800HD
  • PRO-800HDI
  • PRO-1000HD
  • PRO-1000HDI
  • PDP-433CMX
  • PDP-502MX
  • PDP-503CMX
The issue with the power supply in the plasmas listed above does not pose any health or safety risk. Pioneer has received reports that the power supply in the affected models may fail. In some cases, a loud popping sound can be heard when a power supply fails. After the power supply fails, the plasma is no longer operable.
Anyone with questions can call Pioneer's toll free hotline at 800-421-1404.
We apologize for any inconvenience.
Aug 09, 2008 | Pioneer PureVision Pro-800HD 43 in. Plasma...
Tv keeps turning off getting code E01
Don't waste time,call 1-800-pioneer!
Best time would be T-Thursday at 7amPST.
Good Luck!
solutiondoct
Jun 02, 2008 | Pioneer PureVision PDP-4340HD 43 in....
Pioneer pro800hd plasma just made a loud pop and then went to black the power button(red led) is flashing. power supply??, flyback xformer??? any ideas. worth fixing??
The affected models of consumer plasmas are listed below. Anyone who owns or uses one of these models may contact Pioneer through its toll free hotline at 800-421-1404 to arrange for the free, in-home upgrade. If a consumer model is not listed below, no power supply replacement is needed and no further action needs to be taken. If consumers are not sure if their plasma is affected, they should call the toll free hotline for confirmation.
Consumer Plasma Models (13 listed): PDP-505HD PDP-4330HD PDP-503PU PDP-4300 PDP-5030HD PDP-4304 PDP-5031HD PDP-4310 PRO-1000HD PRO-800HD PRO-1000HDI PRO-800HDI PDP-433PU
Dec 30, 2007 | Pioneer PureVision Pro-800HD 43 in. Plasma...
Televison & Video Logo
1,035 people viewed this question
Top Televison & Video Experts
