My transonic 15 inch lcd tv turns off seconds after turning it on
15 inch lcd
headstrong
  • 233 Answers
SOURCE: 23 inch lcd tv by dell wont turn on as if no power
if this is a DELL W3201C read this.
Have the same model and same problem
probably It is a bad inverter board, in my case one of the 16 transformers is burnt out on the inverter board. still trying to find a replacement component. if not replacing the board is the only option or getting the inverter board repaired.
by the way, this TV has a Samsung panel: model LTA320W2-L03. so it needs parts for a Samsong not a DELL.
DELL does not manufacture or fix them becuase they don't make them
Posted on Dec 28, 2007
SOURCE: 8 month old Symphonic 20 inch lcd tv turns off itself every 3-5 seconds
I have the same problem with mine and its 5 years old I took it apart cause i blew a fuse. I fixed the fuse and got this problem. So my fix was take the tv out back and put 43 7.61mm round in it. The tv is really messed up now but I feel a lot better and know not to buy symphonic any more.
Posted on Sep 13, 2008
  • 458 Answers
SOURCE: 37 inch LG LCD won't turn on due to power failure
Power failures can cause all types of problems, have you firstly checked the fuse in the mains plug? If that is ok then it may have blown an internal fuse in the power supply board, these are there to protect the rest of the circuit from power surges.
Posted on Mar 24, 2009
dave1645
  • 834 Answers
SOURCE: My LCD TV EW 20S5 C shots off after 15 seconds,
one of the ballist transfomers is failing on the inverter board your should have a tech replace the bad one easy to find the bad one by a process of elimination
unplug all but one lamp turn the unit on and watch for the lamp to light for a second if it does go to the next by pluging it in may sure you umplug the one you already tested go through one at a time
Posted on Nov 28, 2009
  • 8457 Answers
SOURCE: We have a Sharp Aquos LCD TV 42 inch. When I
Call Sharp for warrenty repair.This problem very common in Sharp tv.Picture will come on turn power on/off button few times will work.But still under Wareenty call to Sharp to replaced the main Tuner Signal board.
Posted on Jan 15, 2010
Testimonial: "Have tried turning on/off a few times but still doesn't work. thanks anyway"
HI, MY NAME IS S. A. ANSARI, I HAVE A SHARP AQUOS LC-32A66M LCD TV. ONE DAY SUDDENLY GOES INTO STAND BY MODE. NOW WHENEVER WE TRIED TO TURNED IT ON, IT ON FOR 30 SECOND I.E. WE CAN SEE PICTURE, HEAR SOUND...
Hi Ansari
It sounds like a main board problem. The control voltage that goes to back-light inverter board; from the main board, goes down. Contact any service technician. This is not a user repairable fault. Gopakumar Gopalan Google
Feb 27, 2014 | Sharp LC-32A66M 32 inch Multi-System Full...
VIORE 32"LCD lc32vh70 Has sound but the screen turned in black
Does it turn black after about 10-15 seconds? My 40" Viore had the same problem. After trial and error, I finally fixed the problem. There is a motherboard with a cable wire coming from one end to another motherboard. 3 wires. If you remove this wire and kind of jiggle it it in, barely touching the contact points, you will see the image stay on longer than 15 seconds. You have to cut one of the wires on the board with all the inputs, VGA, HDMI, power cord, etc. I have taken pics but have not taken them out of the camera yet. If interested, post back here and I'll (hopefully) get them out. But a word of caution: my 40" inch TV motherboard may be different than your 32" inch.
Feb 08, 2014 | Televison & Video
Smart T.V Sumsung Got Stuck
It sounds that your TVs' timer function is set to 'ON' for 15 minutes time. Check it, and make it 'Off'. Refer its user manual for details.
Jul 21, 2013 | Samsung UN55ES6500 55 Inch 3D 1080p Smart...
I have a 15 inch Advent LCD TV in my kitchen. I turned it on today and have no picture. When I switch stations I get a picture for a minute then it is replaced with vertical lines or a blank screen with...
U have vertical lines for a few second.That mean u tv have a dead board call the T-CON decoders is board.This T-CON decoders board sit at the bottom wright in the middle of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decoders board for the replacement.
Dec 11, 2010 | Advent LC-20H15A 20 in. EDTV-Ready LCD TV
I have a Poleroid 19 inch flat screen. I turn it on and the picture is great but after 15 seconds there's a little pop sound and the screen turns black but you can still hear the sound perfectly. If I...
The tv have 1 or 2 long boards call the LCD inverter boards.These 1 or 2 long inverter boards are dead.That why the LCD screen not getting a backlight to produced a picture.Replaced those 1 or 2 long LCD inverter boards,will get a baklight back and have picture.Tries websites like Shopjimmy.com,Ebay.com buy those refurbishes 1 or 2 long LCD inverter boards for the replacement.
Aug 18, 2010 | Polaroid TLA-01901C 19 in. LCD TV
My lcd tv well not come on
Power supply problem. Any light coming on at all? in the front panel or visible from the back through the case?
May 07, 2010 | LG 42LG50 42 in. LCD HDTV
My sharp 15" LC-AV4U TV turns off within 5 seconds of when it is turned on any help
Jan 26, 2010 | Sharp LC-15AV4U 15 in. LCD Television
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Electro Med Services...
