Question about Cooktops
Manual for Lofra Ceramic Cooktop
Need an Installation Guide for this Cooktop.
5 Suggested Answers
  • 619 Answers
SOURCE: Frigidaire Ceramic Cooktop PLEC36S9eca - Turns on but burners won't heat up
Check the power plug is their any separate plug on it / if none check the control panel some switch to power on .
Posted on Jan 05, 2008
  • 111 Answers
SOURCE: whirlpool ceramic cooktop
Scott,
On each of the heating elements there is a thermostat that does two things. It is a high limit safety thermostat and then a different set of contacts turn on the hot surface light. Unfortunately, you can't just replace that part. You will need to isolate which element it is with a mutimeter and replace the entire element.When you turn one of the units on high you will see a dark line under the glass running 1/2 way across the elements. Those are the thermostats... Find the defective one and the rest is pretty simple to replace
Posted on Dec 19, 2008
  • 949 Answers
SOURCE: My ceramic cooktop has cracked. Can I just order
You can get the main glass top, the part number is WB62T10525 and it runs just under $300.00, it is shown here as 51. It does take a bit of dis assembly to install it.
Posted on May 05, 2010
  • 1796 Answers
SOURCE: Need an instruction/installation manual for
Hi!!
I tried the model number on the Omega site and it does not come up. The first link is to the three 60cm cooktops available. Once you identify your cooktop, click on the second link to look for your owner's manual.
http://www.omegaappliances.com.au/Category-42-Width-60-Ceramic.aspx
http://www.omegaappliances.com.au/ProductManuals.aspx
I am pretty sure the installation and operation manual for at least one of them, should work for you.
You can also file a form requesting your manual. It is under Customer Support.
Good Luck!! Don't forget to rate this post!!!
Posted on Sep 15, 2010
Looking for manual for Domain ceramic cooktop CER90-T
Go to RepairClinic.com you can find the answer there.
Sep 20, 2014 | Cooktops
Wiring for Kenmore Elite Induction Cooktop
The white one may just form an earth loop,, I recently had a ceramic plate needing cleaned so we did the whole lot, I think most hobs have 4 wires and they are numbered rather than colour coded..hope this helps
Nov 10, 2013 | Kenmore 30" Induction Cooktop Stainless...
I have a hole in my ceramic thermador induction cooktop
You really can't. Ceramic can be repaired but it can be short term. There may be a sealer they can put in the opening.
Jan 02, 2013 | Thermador 36 In. Silver Induction Cooktop...
I need an installation manual for a cvg4380p Jenn-Air cooktop
Hello Chuck,
Your request is for the Jenn-Air CVG-4280P gas cooktop installation instructions, even though the info at the top of the page states a JED8430 electric cooktop,
If I've got your request correct, here's a link to the installation instructions for the CVG-4280P cooktop.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/CVG4380PII.pdf
If you'd also like the owner's manual for that same cooktop, here's the link for that too:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/CVG4380P.pdf
Hope you find this Very Helpful and best regards!
Merry Christmas!
Dec 13, 2009 | Jenn-Air JED8430 Electric Cooktop
TRYING TO REPLACE THERMADOR CERAMIC TOP OF COOKTOP
much beter to call an technician coz the glass ceramic is no warnaty,if u get wrong instalation or broke the glass u waste ur money,call the person have an expertise for that.dont try to fix by it ur self.coz if the technician fix it,u get an assurance for the waranty if may happen during instalation.
Sep 07, 2009 | Thermador SGS36GS Gas Cooktop
I need to know the ampere raitng or the wattage so I can size the electrical feeder to the cooktop
The installation guide, on page 3, says this cooktop can use up to 9700 watts. It also says to use #8AWG wire and a 40 amp 240 volt breaker. You can download the installation guide here:
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/318201427revA.pdf
Feb 19, 2009 | Frigidaire PLEC36S9EC Stainless Steel...
Frigidaire electric glass cooktop wiring problem
HEllo
I have the following manuals in PDF format,
I will gladly email them to you.
Model: GLEC30S8ESB Owner Guide(English): 318200612en Wiring Diagram: 318046807 Installation Instructions: 318201426 Parts Manual: 5995479655
Eddie Rentas
Tupper Lake NY
Jul 21, 2008 | Frigidaire 31 in. GLEC30S8 Electric...
Remove ceramic cooktop
grouch, kill the power to the cooktop. You are going to have to remove the mounting brackets from undernieth and push the cooktop up. After it's up from it's installation position remove the side and back screws holding the top to the botom. Remove the burner knobs and it should come apart. Sounds like you have a bad burner switch. Catriver..post back
Feb 26, 2007 | Jenn-Air JED8430 Electric Cooktop
Cooktops Logo
Top Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Cooktop Expert? Answer questions, earn points and help others
