Question about HP Photosmart C4580 All-in-One InkJet Printer
Printer carriage jam remove cardboard inside device
    New Friend:
Did you fix it? Because I have the same problem and I don't know what to do........please aneswer if you can!
Posted on Jan 10, 2013
3 Suggested Answers
  • 1751 Answers
SOURCE: HP Photosmart C4480 all in one printer scanner
you have not install cartridge correctly
check cartridge if are fully inside the carrier
Posted on May 02, 2010
efs_perpends
  • 1996 Answers
SOURCE: It reads carriage jam remove all cardboard.
Click here
Posted on Apr 10, 2009
Hp officejet 4630 carriage jam
Check first:
Are you printing correctly? Are the papers in their correct position? Look the picture below, is it 100% identical to how your printer looks right now?
hp-officejet-4630-carriage-jam-g3kwcv4s0uxqjd0jsmqlsidv-5-0.png There are a few ways:
1. Open the cartridge access door and remove any obstruction in the movement of the cartridges.
2. Re-install cartridges.
3. Plug the printer electric source directly into the wall outlet.
4. Check the picture above and check your alignments again.
Jul 11, 2015 | HP Officejet 4630 e-All-in-One Printer
My HP 8500 a909a states there is a carriage jam. However there is not paper jam. I've tried resetting it and turning off, pluging into wall outlet, removing and replacing the printheads. I think...
Hi, please try this:
1. Remove all media from the output tray.
2. Check the duplexer.
a. Push the button on either side of the duplexer, and then remove the panel or unit.
b. Locate any jammed media inside the device, grasp it with both hands and then pull it towards you.
c. If the jam is not there, push the latch on the top of the duplexer and lower its cover. If the jam is inside, carefully remove it. Close the cover.
d. Reinsert the duplexer into the device.
3. Open the top cover and remove any debris.
4. If you have not found the jam and have Tray 2 installed, pull out the tray and remove the jammed media, if possible. If not, do the following:
a. Ensure the device is turned off and disconnect the power cord.
b. Lift the device off Tray 2.
c. Remove the jammed media from the bottom of the device or from Tray 2.
d. Reposition the device on top of Tray 2.
5. Open the print carriage access door. If there is paper remaining inside the device, ensure the carriage has moved to the right of the device, free any paper scraps or wrinkled media, and pull the media towards you through the top of the device.
6. After clearing the jam, close all covers, turn on the device (if you turned it off) and resend the print job.
Aug 23, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
My hp 8500 is saying paper jam but there never was one
This is based on the HP 8500 manual. I hope this helps.
Aug 22, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Stylus CX9400 Photo Printer: paper jammed inside printer...
May 18, 2010 | Epson Stylus CX9400 Photo Printer
What is a carriage jam
here are some solutions for your carriage jam error.
1. Clear any jam...remove loose paper.
2.Clear the jam from the back of the printer
turn off the printer...remove the rear access door..
pull the paper out of the roller and return the rear access door.
3. Clear the paper jam from the front of the printer..while printer is on..open the carriage access door..
disconnect the power cable from the back.. remove the paper output tray.
look inside the product..check for torn papers..gently pull out the paper fromthe roller...return the paper output tray and the carriage access door. plugthe power corn and turn on..
4. Make sure the carriages move freely...while the printer is on.. open the carriageaccess door.
disconnect the power cord from the back..remove the paper output tray...lookinside if the carriage is stuck and if there is no papers or object that restrictthe carriage to move..return the output tray.. return the carriage accessdoor...
And lastly after doing this steps try to reset the printer and try to print..
To reset the printer....press the power button to turn on theprinter..disconnect the power cord from the product..disconnect the power cordfrom the wall outlet.. wait for 15 seconds.. plug the power cord to the wallsocket....plug the power cord at the back of the printer.. press the power onof the printer.. try to print the test page...
http://www.fixya.com/support/t6088190-hp_7400_displayshttp://www.fixya.com/support/t6088190-hp_7400_displays
Good luck! hope this solve the problem
Much appreciated if you rate this help.. thanks
May 10, 2010 | Office Equipment & Supplies
Printer
Please perform the below steps.
1. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Jun 03, 2008 | Office Equipment & Supplies
HP Officejet 5110 - Carriage Jam Message
I have an Hp Officejet 5110. I have an error message saying "Open door,clear carriage jam, then press enter". But where is its door? How can I clear the carriage jam?
I tried pressing the # & 6 at the same time, but the error message still there.
Mar 09, 2008 | HP OfficeJet 5110 All-In-One InkJet...
HP Photosmart C4580 All-in-One InkJet Printer Logo
475 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
