Question about Alesis FirePort 1394 (ALEFP1394)
My alesis fireport 1394 dosen't work with a bigger hard driv es .why?when alesis manual sais it should
  • Trent P Mar 14, 2009
    The problem may actually be related to the operating system. If you upgraded to Vista 64 at the same time, Alesis does not make a Vista 64 driver for the Fireport 1394 yet.
  • paulk829 May 26, 2009
    I have installed version 1.05 of FST Connect for Windows Vista. But it will not start. I am using Vista 64 Ultimate.
SOURCE: i need help with running
Either use the legacy drivers for your 1394 interface or do as I did and just download HD24 Tools program until Alesis makes a device that works on modern operating systems! Don't stay up late waiting for Alesis to do that. Ask yourself when the last firmware upgrade for the HD34 was.
Posted on Feb 14, 2011
I need help with running my alesis fireport 1394 with windows 7
Feb 02, 2011 | Alesis Fireport 1394 for ADAT HD24...
Alesis ADAT HD24 Fireport I tried to read the hd24 drive in my pc and now it is corrupted. What can I do to recover the data? Thanks
Try a new or different OS
Use a program called studio
Use an USB cable to IDE and power, download hd24tools and recover your rackshttp://ringbreak.dnd.utwente.nl/~mrjb/hd24tools/download.html
Oct 20, 2010 | Alesis ADAT HD24 Fireport (ALADHDFIR)
Drive no longer recognized by fst
Try updating the drivers and/or go to their website, download and then install the drivers, then restart the system.
May 07, 2010 | Alesis FirePort 1394 (ALEFP1394)
HELP?
hello wats wrong... silverdragon@gmail.com
Mar 21, 2010 | Alesis Fireport 1394 for ADAT HD24...
I cannot get my Alesis ADAT HD24 to work on Windows 7. The Vista drivers do not work and I cannot find anything that will work.
There are some fundamental driver support differences between windows 7 and vista. It doesn't appear that Alesis has release a windows 7 driver for their fireport and im not sure if they will.
Nov 22, 2009 | Alesis EC2 ADAT HD24 AnaloAlesis ADAT HD24...
Howdy, I'm Running vista 64 bit Home Premium. I downloaded the 1.05 version for vista from the alesis website. after installing it i get a "fstConnect.exe-Application Error. The Application failed to...
Use Add/Remove Programs to remove that '1.05' version.
Visit the ALESIS web-site, and click on "get support",
and tell them that the '1.05' version does not work with 64-bit Vista,
and ask them what they recommend.
Oct 27, 2009 | Alesis FirePort 1394 (ALEFP1394)
Usb device not reconized, maybe need driver
You do need the drivers installed. look for the device CD or disc and install it. but if you already have the drivers installed and you still get the same message, its possible that your usb device is bad or there might be bad connection between the usb device and your computer... try to use another usb port or try to plug your device to another computer to try and isolate the problem.
Jul 11, 2009 | Alesis FirePort 1394 (ALEFP1394)
HD24 won't mount drive in Bay 2
Alesis published a patch for the HD24 which involves adding a 2200uF capacitor to the HD24, which solves this problem for some drives that never mounted before. As electrolytic capacitors age, their capacity reduce- which may cause this problem. It may well be you can fix this problem by replacing the existing 2200uF capacitor with a fresh one, keeping the polarity of the capacitor in mind of course.
Oct 24, 2008 | Alesis ADAT HD24 Fireport (ALADHDFIR)
Alesis HD 24
What type computer?, o/s [operating system]?
What did u do to cause the problem? Or what happened before problem?
Apr 28, 2008 | Alesis ADAT HD24 Fireport (ALADHDFIR)
Alesis FirePort 1394 (ALEFP1394) Logo
371 people viewed this question
Top Alesis Televison & Video Experts
Electro Med Services...
Are you an Alesis Televison and Video Expert? Answer questions, earn points and help others
