Question about Canon PIXMA iP4300 InkJet Photo Printer
Canon iP2772 The remaining levels of some ink cannot be correctly detected
SOURCE: ERROR U130
The remaining ink level cannot be correctly detected. Replace the ink tank and close the Scanning Unit (Printer Cover). Printing with an ink tank that was once empty may damage the machine. If you want to continue printing in this condition, you need to release the function for detecting the remaining ink level. Press and hold the Stop/Reset button for at least 5 seconds, and then release it. * With this operation, releasing the function for detecting the remaining ink level is memorized. Please be advised that Canon shall not be liable for any machine malfunction or damage caused by refilled ink tanks. See “Replacing an Ink Tank” on page 46.
Posted on May 11, 2008
SOURCE: Refilling Ink in Canon Pixma MP830
Hello, I found this in a repair manual for the MP830. summery is to press and hold the stop/reset button for 5 or more seconds. I copied the info from the manual too. The remaining ink amount unknown. [1683] (Applicable ink tank icon) The remaining level of the following ink cannot be correctly detected. An ink tank which has once been empty is installed. Replace the applicable ink tank with a new one. Printing with a once-empty or refilled ink tank can damage the print head. If printing is continued without replacing the refilled ink tank, press the Stop/Reset button for 5 sec. or longer to record the use of a refilled ink tank. Note: After the above operation, the function to detect the remaining ink amount is disabled.
Posted on Sep 06, 2007
IB4G2008
  • 3587 Answers
SOURCE: Cannon IP1880 Cannot detect Cartridge
hmmm..well..you may find that new drivers help a bit.
get them here
Posted on Mar 20, 2008
SOURCE: "ink cannot be correctly detected" error U130
I had the error message U071 and U130. I pressed the stop/reset, OK, the black and color start buttons all at once and the error message just disappeared.
Posted on May 17, 2008
SOURCE: How to reset the ink level monitor on Canon Prixma MP 160
Desconectar del toma corriente el impresor
Mantener presionado el botton de power mientras se conecta al toma corriente
Manteniendo presionado el mismo boton de power presionar dos veces el boton de reset (circulo con triangulo rojos)
Soltar el boton de power
La impresora se tardara unos 10 segundos en mostrar el vaor numeroco de cero.
Presionar + para que el valor se mueva de 0 a 1.
Cuando el valor este en 1, presionar el boton que esta a la par de reset, de esta manera se encenderan dos luces
una es la de plain papaer y la otra de photo paper, en este momento se coloca papel en la impresora
Se presiona el boton de power una o dos veces (da igual), la impresora imprimira una hoja de prueba
Al imprimir esta hoja el valor en la pantalla regresa al valor de cero, dejarlo asi
Abrir el scan cover (para sacar los cartuchos pero no se sacan), con la tapa abierta desconectar fe la energia al impresor
Sacar los cartuchos, cerrar la tapa y encender el impresor.
Volver a colocar los cartuchos ya refilados en la impresora y LISTO.
Posted on Jun 16, 2008
Pixma 2200 series all in one
Don't use refill kits, they are no good in quality printers. Also the cartridges in the newer models have a chip in them that knows when the cartridge is empty. When it becomes empty, the chip has to be reset, and this is what those mall cartridge fillers do.
E, 1, 3 The ink may have run out. The function for detecting the remaining ink level will be disabled since the ink level cannot be correctly detected. If you want to continue printing without this function, press the machine's Stop (Reset) button for at least 5 seconds. Canon recommends to use new genuine Canon cartridges in order to obtain optimum qualities. Please be advised that Canon shall not be liable for any malfunction or trouble caused by continuation of printing under the ink out condition. Checking the Ink Status Checking the Ink Status with the Ink Lamps on the Operation Panel The ink level detector is mounted on the machine to detect the remaining ink level. The machine considers as ink is full when a new FINE cartridge is installed, and then starts to detect a remaining ink level. If you install a used FINE cartridge, the indicated ink level of it may not be correct. In such case, refer to the ink level information only as a guide. When remaining ink cautions or errors occur, the error code will be displayed on the LED (Light Emitting Diode) to inform you of the error. Check the error code and take appropriate action. -> [ An Error Code Is Displayed on the LED ] See[Checking the Ink Status ]
Oct 27, 2015 | Canon PIXMA Office Equipment & Supplies
Replaced new color ink and getting a u162 error code on my cannon pixma mx340 wireless office all in one inkjet printer
he ink may have run out. Replacing the ink tank is recommended.U162
The Ink may have run out.
If you want to continue printing without this function, press the Stop/Reset button for at least 5 seconds.
NOTE
If the function for detecting the remaining ink level is disabled, the ink cartridge
in grey is displayed in the remaining ink volume screen on the LCD.
Feb 04, 2015 | Cannon Office Equipment & Supplies
Ink cannot be properly detected
If you are using remanufactured or aftermarket print cartridges try using Canon branded ones and see if it still happens.
Dec 06, 2013 | Canon Office Equipment & Supplies
My canon printer mp258 shows me E13 i would like to what this problem is related to?
E13 is Ink level cannot be detected.
Ink may have run out and the function for detecting remaining ink level
will be disabled because level cannot be correctly detected.
You can continue printing by pressing the stop/reset button for 5 seconds.
Jan 02, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
MY ALARM ON MY MP210 IS ON AN MY COLOR INK FLASHES WHAT DO I DO
Check the status of each cartride by using the ink lamp.
You have 3 lamps
(A) Alarm lamp
(B) Black ink lamp
(C) Color ink lamp
Make sure that the LED is on standby mode.
a) If the ink lamp lights.
Cause : Ink is low.
Action :You can continue printing for a while, but we recommend you have a new FINE cartridge available.
b) The Alarm Lamp lights and the ink lamp flashes .
* If "E, 1, 3 " is displayed on the LED, ink has run out.
Cause : Ink level cannot be detected.
Action : Ink may have run out.
If you want to continue printing without this function, press Stop/Resset buttonfor atleast 5 seconds.
* If E,1, 6" is displayed on the LED,
Cause : Ink has run out.
Action. Rreplace the ink cartridge and close the Scanning Unit (Printer Cover).
If printing is in progress, you want to continue printing, press the Stop/Reset button for atleast 5 seconds with the ink cartridge installed. Then printing can continue under the ink out condition.
The function for detecting the remaining ink level will be disabled.
Replace the empty ink cartridge immediately after the printing. The resulting print quality is not satisfactory, if printing is continued under the ink out condition.
c) Only the ink lamp flashes
Cause : The function for detecting the remaining in level is disabled.
Hope this helps.
Please rate my response.
Thanks
Have a good day.
Dec 04, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
E16 error message for for canon pixma 210
E16 must be "Ink remaining unknown".Press and hold the "resume" button for 5 seconds.
Oct 15, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
How to fix problem E16 in my printer canon mp160
E16 – The ink level cannot be correctly recognized or detected.
How to correct, fix: A used ink cartridge may be installed, or the ink cartridge is empty. Press the <Black> or <Color> button, to clear the error and continue printing without replacing the ink cartridge. However, the remaining ink amount cannot be detected properly, so the function to detect the remaining ink amount does not operate.
Sep 03, 2009 | Canon PIXMA MP160 All-In-One InkJet...
My CANON iP4300 printer does not print and has a yellow light that flashes 13 times. What does that mean??
This according to the user's guide:
Replace the ink tank and close the Top Cover.
Printing with an ink tank that was once empty may damage the printer.
If you want to continue printing in this condition, you need to release the function for detecting the remaining ink level. Press and hold the RESUME/CANCEL button for at least 5 seconds, and then release it.
* With this operation, releasing the function for detecting the remaining ink level is memorized. Please be advised that Canon shall not be liable for any printer malfunction or damage caused by refilled ink tanks.
See Replacing an Ink Tank.
May 02, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
ERROR U130
Apr 10, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Jul 17, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA  iP4300 InkJet Photo Printer Logo
old marine
old marine
