Simpson enduro 701 washing machine
Machine set to wash on 17 minute cycle to wash but does not start to wash time ,switch rotates to next index cycle still no wash (,ie moter does not start )so wash is not done, water is drained off, timer completes cycle to end .this only happens every 3 or 4 washesso i know the machine works ok when it does the wash ,any ideas at will help , the timer switch was replaced with a new one 6 months ago ,but this has not fixed the problem . thanks gary
You have a faulty brake motor. It pulls in and releases the brake. When pulled right it it contacts a switch which lets the other actions like washing and spinning to occur. $77 to $86 off ebay or appliance stores. turn off ac. remove back off machine. reach around left side of frame at the bottom of the tub and push the brake forward manually and let the little plastic retainer turn sideways and release the wire rope retainer that comes out of the brake motor. remove the power cable to the brake motor by pulling out the connector on the right side under the tub. remove the two 8mm screws retaining the brake motor and remove the brake motor. reverse procedure with new item.
enjoy uninterrupted washes!
Posted on Jun 21, 2010
After the water pumps out on each of the cycles the spin does not go or start and it gets stuck there.
Posted on Apr 13, 2010
Simpson Enduro 801
turn the timer to a setting and pull out on the knob once
Apr 09, 2015 | Simpson Washing Machines
Simpson enduro 501 wont agitate. Everything except the Wash cycle works...
check the cam dogs in agitator and check the water pressure switch with a meter it controls when machine goes into wash cycle
Feb 04, 2015 | Simpson Washing Machines
SImpson Enduro 701 - motor going slow
u must check capasitor usually so good luck
Nov 20, 2010 | Washing Machines
Hi, our simpson enduro 701 washing machine does not spin back and forward in the deep rinse cycle. but operates ok and spins in spin cycle. thankyou Tina.
Hi Tina just read your posting. From the information in your posting the machine fills, then when the machine is full of water the agitator moves clockwise then anticlockwise until it gets to the rinse cycle then drains the water ,then it fills for the rinse cycle but does not move the agitator in the rinse cycle.Then it drains and spins the clothes dry .Is this assessment of your posting correct.If it is not 100% correct please reply to tell me what the machine is doing or not doing.If it is correct then the problem with your machine is the control board.Is your model the electronic one with the push buttons?Looking forward to your reply.
Jun 26, 2010 | Washing Machines
Locating the fusebox
The breaker box is located on the wall of your house. There is not a fuse in this machine.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 05, 2009 | Washing Machines
Simpson enduro 701 very slow to fill and timer sticks
Hi my name is joyce, sounds like you have trash in you water filter that is in your water line that comes in your machine in the back of washer, this may be the cause for the slow water and the timer will cause the machine not to advance to the next cycle, if you would like I will help to find a service techincian.
Joyce
Feb 06, 2009 | Roper RAS6233KQ Top Load Washer
Washing Machines Logo
484 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
