Toshiba QOSMIO E15-AV101 Notebook Logo
David Rosales Posted on Aug 30, 2006
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have Qosmio E15 and it wont boot
Hi i have my qosmio, and its been working fine for 3 years but now, it wont boot, it just tells me IDE#0Error, i don't know how i can check if its my MOBO or the HD, or if its a software problem, the thing is i lost my restore CD so pls ppl i need some help, i have my tesis there :S
Anonymous
Level 2:
Scholar:
  • Expert 148 Answers
  • Posted on Nov 02, 2006
Anonymous
Expert
Level 2:
Scholar:
Answers
148
Questions
0
Helped
45491
Points
161
Go here: http://www.hitachigst.com/hdd/support/download.htm#DFT And download the drive fitness test, burn it to a .ISO bootable CD, and boot from the disc. Run a FULL SCAN and it will tell you if the HDD is bad, which is highly likely.
1helpful
How to restore toshiba qosmio e15 av101
Unless you have a installation, Win XP?, CD/CD's or Factory Recovery CD/CD's, it will not Restore on a blank HDD. If I understand your question correctly. You must do a FULL installation.
How to do a hard reset on my toshiba e15 av101
hard reset is done by shutting down the computer. Then remove the cables and battery to it, and then press and hold power button for 8 secs. Reinsert the cables and battery into it, then turn it back on..
1helpful
How do i remove back and reinstall fan?
Welcome to Fixya
Here's the procedure:
1. Shutdown the laptop and remove the AC adapter. Disconnect any devices, such as a printer or external DVD-ROM or drive, that are attached to the laptop
2. Remove the laptop battery. Turn the laptop upside down, slide the battery release latch and then pull the battery out of the bay.
3. Unscrew the hard drive cover. Grab the hard drive tab and shift the hard drive to the left to unplug it. Lift the hard drive out of the bay.
4. Unscrew and remove the PCI memory cover, the optical drive cover, and switch cover.
5. Unscrew the two screws that hold the keyboard to the base, these are located in the middle of the rear panel. Flip the laptop over so it is right side up, open and remove the keyboard by using the keyboard release switches located above the keyboard. Next, unplug the Toshiba Qosmio E15-AV101 Fan cable.
6. Close the laptop and turn it over so it is bottom up. Unscrew the display assembly screws located under the laptop screen hinges. Turn the laptop over so it is right side up. Open the laptop and unplug the display assembly cable and disconnect the wireless antenna from the display assembly. Unscrew the display assembly from the laptop base and remove.
7. Unplug the mouse pad cable. Turn the laptop over so the bottom side is up and unscrew the base screws which are located along all four sides of the laptop base. Gently remove the base of the laptop.
8. Turn the laptop over so it is right side up. Unplug the fan cable from the circuit board. Unscrew the screws holding the Toshiba Qosmio E15-AV101 CPU fan assembly to the laptop. Lift the fan assembly out of the laptop.
9. Insert the new Toshiba Qosmio E15-AV101 CPU fan assembly into the lap top. Screw the assembly unit to the lap top and plug the Toshiba Qosmio E15-AV101 CPU cooling fan cable into the circuit board.
10. Reassemble the laptop by repeating the previous steps in reverse order.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Have a Toshiba Qosmio F45-AV411 and downloaded windows 7 last night. worked fine then I put comp in to sleep mode when I tried to turn on today looks like it is booting up and then goes to a black screen...
Try to boot up the computer using safe mode first. Keep on tapping the F8 key the moment you turn on the computer. If your computer wont boot to safe mode then you need to re-install windows 7.
QOSMIO E15-AV101 PC Notebook: just installed windows 7 ultimate, clean install, ...
Okay in some case windows 7 does not pick up the network drivers so you will need to download and install the network drivers for your laptop from another computer and then copy those files to a pen drive and then connect it to your laptop and install it, however I do see that your laptop driver support page does not support other OS other than windows XP32. Please refer the link below and download both the drivers and install it, that is the driver for windows XP it should probably get installed and work for windows 7.
http://support.toshiba.com/support/modelHome?freeText=804518&osId=50
How to rplace cpu fan for toshiba qosmio e15
See the below video for guidance on how to take apart your laptop.
My laptop wont start its a toshiba g15
have you tried pulling each stick of ram individually?
if there is still no boot then its safe to say that the motherboard or one of the two video cards has failed. its a pretty common on the qosmio g series
1helpful
Toshiba qosmio E-10 noises keyboard and start up
Sound like you have a stuck key and the bip noise is the keyboard buffer pverloading.
If you can't unstick this key, you need a new keyboard.
Help with Toshiba Qosmio G35-AV600
go cmos by pressing F2 after powering on then change sitting of FN in cmos...
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
