Question about Microsoft Xbox 360 Console
Xbox 360 what to do when the console won't come on and won't play?
  • yourhelp May 11, 2010
    Can you let me know if there is any red lights or will it not just turn on? What color is the power pack light?
  • 20 Answers
I can fix this problem for you by reflowing the GPU. This is the Graphics Processing Unit located on the motherboard inside the 360. The issue is a loose solder joint between the GPU and the motherboard and it can be fixed by heating up the GPU and underside of the motherboard to the point that the solders between the two flow freely again and make a new secure connection. I charge $40 for the repair, plus you ship both ways. If your console is out of warranty, this is the only way to fix it and I will have it back on it's way to you in one business day. If you are still under warranty, Microsoft will fix it for you, but it will take 6 to 8 weeksd for it to be returned, and the repair will not be done any differently than what I will do. Most likely they will send you a refurbished unit, and not the one you sent to them anyways. Contact me at jj.stevens13645 at gmail dot com for more info.
Posted on Sep 18, 2009
    Problem Solver:
  • 6 Answers
Try checking the cords
Posted on Aug 10, 2009
  • 6,784 Answers
HI, this will occur if the power supply unit has failed. simply replace this failed power supply unit. this will fix you issue.
Click here to order your replacement power supply.
Posted on Jul 28, 2009
  • 4 Answers
Make sure all id plugged in maybe blow down the gaps in the xbox may be a dust build up
Posted on Jul 24, 2009
  • Maidens Jul 24, 2009
    make sure all id plugged in maybe blow down the gaps in the xbox may be a dust build up
First make sure all cables are plugged in. Plug the xbox into different outlets to make sure it is not a problem with your outlet in your house. if it still does not work after that you will have to send it in to xbox and have them check the power supply.
Posted on Jul 22, 2009
  • 30 Answers
If it shows a red ring on your console, you have to call xbox and have them fix it. it happens alot, very common but xbox is stupid enough to make it take like a month to get your xbox back.
Posted on Jun 29, 2009
  • 3 Answers
Check the power chord light to see if it is orange when off, and green when you turn on the xbox
Posted on May 19, 2009
I got a brand new 'lips' Xbox 360 game, put it
You might have a bad game if it is used. If it is not check to see if it plays other games without issues. Your Xbox might need to be repaired lets hope that isnt the case. You may also want to try it on a different console if at all possible. If all else fails you maybe need a new xbox if you are dying to play that game
Dec 24, 2012 | Video Game Consoles & Games
Xbox 360 wireless controller won't connect to console
try getting a play and charge kit thats what i had to do
Nov 12, 2012 | Microsoft Xbox 360 Console
What is the xbox 360 status code 69-C00D3E9A? i get this when sreaming mp4 videos from my pc using traversity through the xbox. some will play others i get this code.
I think the content is too high definition. If you're using component, like i am, it plays the lower resolution videos just fine, but higher resolution videos won't play. But when it's connected to an LCD tv, it works just fine? Must be that.
Dec 13, 2011 | Microsoft Xbox 360 Console
Just changed the disc drive on my xbox 360 now it wont play games only dvd can anyone help thanks
the disc drive on the xbox 360 has a key that matches it to the motherboard. If the key isn't there, or is incorrect, the xbox won't read games. If you (hopefully) still have the original drive, you might be able to get someone to help you with jungleflasher to copy the key over. Good luck!
Sep 07, 2011 | Microsoft Xbox 360 Console
Plays dvd but not games
Any more details then that? I am assuming that you are not the original owner of the Xbox 360? you bought it used?
won't be ebale to try and assist you without more information on the Xbox 360. Has it worked for YOU before? Have you been able to play games on it and it suddenly stopped playing games? Has it been modified? Has it been moved around a lot recently?
Please be specific on your history with the Xbox 360 and we can see what you might have as an issue.
Jul 16, 2011 | Microsoft Xbox 360 Console
Swaping game drives
You have to understand that the xbox dvd drive is married with 360 motherboard by firmware...
when you try to change drives you should backup your original drive firmware...and load it in another drive...it will runs as well in your console...or if you prefer just change the optical lens inside the drive...and you won´t need to re-write firmware....
Sep 11, 2009 | Microsoft Xbox 360 Console
When a game is inserted into the xbox 360 console it won t play the disc. on screen it says please insert xbox game
I had the same problem with my Xbox a while back. Call Microsoft Xbox support. If they tell you that your warranty is no longer valid just keep hassling them until they hook you up. Worked for me!
Sep 01, 2009 | Microsoft Xbox 360 Console
Xbox 360 thinks it`s an Xbox and won`t register a 360 game
Hey,
Strange Issue, but I think its a possible solution to it. I would say the drive and/or laser needs to be changed.
Apr 14, 2009 | Microsoft Xbox 360 Console
Two XBOX 360 Games won't play on original XBOX Console?
Erm, the clue is in the name guys. ORIGINAL XBOX plays ORIGINAL XBOX games. The XBOX 360 plays games designed for the XBOX 360 plus an array of ORIGINAL games. The original console will NOT play 360 games.
Nov 29, 2008 | Microsoft Xbox Console
Microsoft Xbox 360 Console Logo
220 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
