RCA Projection TV : D52W27D Connector BP120 on Power Board ?
Hello, I have a Dead RCA D52 W 27D Tv. upon inspection found blank connector socket BP 120 on Power Board, can Not locate the Ribbon Cable connection to this connector,or matching connector elswhere in tv. Where this BP 120 is connects to..and where is the Cable or matching connector is located..? Could it be the cause of No Power ? Answers will be greatly appreciated as I am puzzled why this BP 120 is unoccupied..
  • Teknofix Feb 23, 2012
    Thanks for clearifying an Empty Socket (BP120) Fuse checks OK, which is the First thing I Looked and Checked. Still No Power !!!
  • 8,617 Answers
BP120 is not used in that model its simply a empty socket that board is used in other versions of the ITC222 chassis in which some use that plug . But your model doesnt use it. Check the fuse on the AC main board which is right next to where the power cord plugs into that board. If the fuse is blown its most likely the flyback and HOT which are causing the blown fuse. If the fuse is good then the deflection board will need replacement. www.tvrepairworld.com has replacement parts and circuit boards for that chassis and also free tech support is available.
Posted on Feb 23, 2012
  • Sonny Berry
    Sonny Berry Feb 25, 2012
    does the power light coe on even briefly. If so there are three capacitors on the deflection power board (lower left looking in rear of set) that are known to fail they are CP150, CP120 and CP114 check if the tops of either one of those caps are domed on top indicating a bad cap. They should be perfectly flat on top.
Model d52w20. The F connector on the rear panel is broken. How can I replace it?
The F connector probably is soldered to a circuit board inside your TV. You would have to disassemble the TV to get access to the board to unsolder the broken connector, remove it, and solder the replacement connector on the board.
Mar 30, 2016 | RCA Televison & Video
RCA rear projection hd tv 52inch comes on sometimes other time green light goes on then off and then flashes and tv does not come on
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this will help in solving the product.....
Jun 22, 2011 | RCA HD52W56 52" Rear Projection HDTV
Hello, my 25" Magnovox (#mt2501c)
Tv fell off about 3 feets or more?Yes,turn on the tv see if u getting any power to the unit?Might have broken main PCB board too.If unit still have power,check see if tv get statics screen have colors shaded in red or mutiples colors,mean the tv CRT(tv tube) yoke is dead and damages scrambles radiation.Or the tv getting power but have high pitch sqeeling noises or rattles noises,tv have the CRT-(tv tube) is crack by the neck or broken totally.CRT have damages problems or dead tv is worthless,beacause of CRT(tv tube) is dead,not fixable even that antena connector input is replaced.
Feb 17, 2011 | Philips Magnavox MT2501C 25" TV
Dead set, HOT transistor keeps shorting
It's the copper coiled magnet on the neck of the crt closest to the front of the tube.
Dec 21, 2008 | RCA 36V430T 36" TV
Tv problem
the tuner will need to be replaced
Oct 26, 2008 | Televison & Video
Power falure
Check second ribbon on deflection board if not pluged in right set will make a small squealing sound and will not come on insert correctly set should then come on/.check and make sure all ribbon connectors are in good.
Oct 11, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W27D The Three Blinks of Death
Check 3 capacitors on deflection board cp150,cp111,cp114 most of the time this is the problem 2200uf16v /330 uf 35v /220uf 35v.
Oct 05, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Help me
If you are decent with soldering iron you can repair it yourself. Remove the back, and remove the signal board from the unit. Unsolder the Tuner from the board( If I've lost you already, call a TV shop for repair) Remove the shields on the tuner and inspect for damage to the tuner itself. If the board is in good shape, replace the RF connector with RCA # 215543. you'l have to unsolder the old ends connector ( the wire thats still there broken ) from the board, then attach the new end, and solder to the board. Then using high heat, solder the Connector to the tuner housing. Replace tuner on board, hook everything back up, and you should be in business.
Jun 01, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Power supply connection for rca
The wires should have a number or letter stamped on the connector that corresponds to the socket on the PC board. Look the plug over real good for a letter or what not stamped on its plug. Hope this helps.
Jan 23, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca d52w19byx1
You could get away with replacing it if you get a 'freeview box' and connect it to the scart socket on the back of the tv and then connect your ariel into the freeview box instead.
Nov 12, 2007 | RCA D52W19 52" Rear Projection Television
Televison & Video Logo
97 people viewed this question
Top Televison & Video Experts
Electro Med Services...
