Question about Casio EV-550 2.5 in. Handheld Television
Digital transition changeover
Will this tv still work when the digital transition goes thru this winter?
  • 24 Answers
Nope. Check this page for information about the portable digital tvs: http://www.ezdigitaltv.com/Portable_Digital_TVs.html
Posted on Jul 20, 2009
Do you think it is a coincidence that a thin vertical blue line appeared both times when the analogue to digital signal transition was occurring? After the first tower changeover finished it disappear
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 15, 2014 | Panasonic Televison & Video
How do I get my to work with an antenna
If its a standard analog tv made before the digital changeover it will no longer work directly connected to an antenna as there are no more analog tv transmissions,to use it you will have to get a digital to analog converter box to connect between the tv & antenna it will convert the incoming digital signal to analog so the tv can work again,the same goes fore vcr's they will no longer record directly from an antenna.Some cable systems still supply the cable signal in analog older tv's will still work without boxes on these systems.
Oct 05, 2014 | Televison & Video
Sound goes off for long periods of time, then comes on unexpectedly. This is happening since yesterday 6/17/09, five days after systems conversion from analog to digital on 6/12/09.
The changeover should not show up this way. Also, the changeover only effected those that use an external antenna. If you have cable or satelite, the changeover should not have effected you at all. If the set is no longer under warranty, you could check for poor solder connections. These tend to be effected by heat. Have you noticed any particular pattern to when the sound goes off? In other words, does the set need to be in use for a long time before the sound cuts out?
Please update this and we'll look further.
If the unit is still under warranty, report the problem as an intermittant one. That way if not completely resolved within the warranty period, the "problem" should be covered anyway.
Dan
Jun 18, 2009 | Panasonic TC-26LX60 26 in. LCD Television
I have a Sony Walkman TV/Weather/FM/AM SRF-M37V. I need to know
The radio won't get TV sound anymore after the switch. And no, nobody is selling a digital receiver for the TV sound yet. All this radio is good for now is regular broadcasting and the weather band.
Jun 01, 2009 | Sony Walkman SRF-M37V AM/FM/Weather/TV...
Local TV channels drop out after a few minutes
We're still hanging on by our toenails waiting for a helpful response from FixYa. We did contact Philips tech support and they basically said that we need a new TV...so they're sending one to replace this one, and we are sending back the "old" one (that we just bought in December '08).
Apr 09, 2009 | Philips 19PFL3403D/27 19 in. LCD TV
Can not get all my local channels
May Be becouse Antenna On Top Of Roof Is to old, Plugging cord in wrong place plug in: In
Mar 25, 2009 | Curtis-Mathis CM19011 TV
Digital tv
Unless it says HDTV it is not digital.
Feb 16, 2009 | Hitachi 60SBX78B 60" Rear Projection...
Hitachi 57G500A DTV & upcoming analog to digital changeover
To answer your direct question, yes it has a digital tuner. To answer your real question, NO it WILL NOT receive the new ATSC (digital) broadcast stations. The tuner itself is a digital one but works only for analog signals. The changeover in February will change the broadcast signals to a new digital format that will require a converter for your set to continue to function. Please note that the converter is only required if you receive your signal from rabbit ears or a rooftop antenna. If connected to cable or satelite, no change will be seen and no converter is needed.
To simplify:
Over air reception = need converter
Cable or satelite = no converter
Dan
Jan 28, 2009 | Hitachi 57G500 57" TV
Tv
The changeover only effects those that use either rabbit ears or a rooftop antenna. It sounds like you have cable TV which will not change. No converter box should be needed if you have cable or satelite.
Dan
Jan 06, 2009 | Televison & Video
Is the sony kv-32v35 digital ready?
if the tv is less than two yrs old than yes.
Dec 20, 2008 | Sony KV-32V35 TV
Casio EV-550 2.5 in. Handheld Television Logo
119 people viewed this question
Top Casio Televison & Video Experts
Henry  Thomas
Henry Thomas
mikeuk
Lawrence Oravetz
Are you a Casio Televison and Video Expert? Answer questions, earn points and help others
